CoAP utils (coap_utils.h) cause stack overflow
The situation is very simple; I try to use the CoAP Utils library to simplify CoAP usage in an application running on the nRF9160 DK (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/include/net/coap_utils.html)
When I run the program and it reaches coap_init(AF_INET) I get a stack overflow issue in the output. I suspect there is a Zephyr stack config I need to set in order to avoid this issue. I can see that a stack size is defined in CoAP utils, here: https://github.com/nrfconnect/sdk-nrf/blob/master/subsys/net/lib/coap_utils/coap_utils.c#L27
...but I'm unable to figure out why I get this stack overflow issue at runtime.
Here is a more detailed debug output:
[00:00:10.980,590] [1;31m<err> os: ***** HARD FAULT *****[0m
[00:00:10.980,590] [1;31m<err> os:   Fault escalation (see below)[0m
[00:00:10.980,590] [1;31m<err> os: ***** USAGE FAULT *****[0m
[00:00:10.980,590] [1;31m<err> os:   Stack overflow (context area not valid)[0m
[00:00:10.980,621] [1;31m<err> os: r0/a1:  0xffffffff  r1/a2:  0x0002f661  r2/a3:  0xffffffff[0m
[00:00:10.980,621] [1;31m<err> os: r3/a4:  0xffffffff r12/ip:  0xffffffff r14/lr:  0x20028ff8[0m
[00:00:10.980,621] [1;31m<err> os:  xpsr:  0x00036a00[0m
[00:00:10.980,651] [1;31m<err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000[0m
[00:00:10.980,651] [1;31m<err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000[0m
[00:00:10.980,682] [1;31m<err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000[0m
[00:00:10.980,682] [1;31m<err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000[0m
[00:00:10.980,682] [1;31m<err> os: fpscr:  0x00000000[0m
[00:00:10.980,712] [1;31m<err> os: Faulting instruction address (r15/pc): 0x00000000[0m
[00:00:10.980,712] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0[0m
[00:00:10.980,712] [1;31m<err> os: Current thread: 0x200218e0 (unknown)[0m
[00:00:11.117,523] [1;31m<err> os: Halting system[0m
I currently use the following configs in prj.conf:
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192
CONFIG_HW_STACK_PROTECTION=y
Thanks!
