Keil uVision doesn't seem to be building files properly
I have my BLE services arranged in different .c files. If I change anything in these files and compile (using Keil uVision 5) and load the program, it seems like the changes I made to the code did not happen. E.g. I have an ADC Service, ble_adcs.c, if I change the UUID of one of the characteristics and view the characteristic on the Master Control Panel Android app, the UUID hasn't changed. I am certain that Keil is in fact loading the newly built program onto the nRF51822. If I change something in main.c it seems to take effect. The compiler detects erors in ble_adcs.c and other Service files, so I'm really unsure why the changes I make to these files aren't taking effect.
Update It seems that the changes take after a build every once in a while. i.e. I change some part of the code, press rebuild in Keil, download the code to the chip and there is no change. But sometimes there is. This is very strange behaviour
Kind regards
Jack
  • It seems that Charles is right, the Master Control Panel app was caching the characteristic information, so that changes in the code of the nRF51822 were not apparent on the Master Control Panel app. To overcome this, I bonded with the nRF51822, unbonded and then discovered services. This seemed to do the trick. You could also reinstall the Master Control Panel instead.
    Thanks for the help, I thought I was going mad
