NRF MESH provisioner node - appKey error
I am in the process of provisioning and configuring a 2-element light switch server node and a common light switch server. I am using the orginal exemple for the provisioner and common light switch server and a modified 2-element light switch server node.
When I start the configuration with the 2-element node it works but the following configuration freezes while searching for the appKey. (Terminal_provisioner_view)
In the reverse order everything works normally.
I have attached debug terminal from each point of view.
Thanks.
(using nrf52840-DK / Mesh v4.1.0 / SDK v16.0.0)
<t:     300644>, main.c,  174, Configuration of device 0 successful
<t:     300651>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
<t:     328492>, provisioner_helper.c,  168, UUID : 07C5A7ED6C9D4B869FAB8C12A2DFE0F6
<t:     328495>, provisioner_helper.c,  171, ^RSSI: -40
<t:     328497>, provisioner_helper.c,  177, ^URI Hash: 74F97940
<t:     328512>, node_setup.c,  768, true<t:     328513>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
<t:     328516>, provisioner_helper.c,  183, URI hash matched to ¹URI for LS Server example. Provisioning ...
<t:     335229>, provisioner_helper.c,  300, Provisioning link established
<t:     350923>, provisioner_helper.c,  295, Static authentication data provided
<t:     364631>, provisioner_helper.c,  233, Provisioning completed received
<t:     364634>, provisioner_helper.c,  238, Adding device address, and device keys
<t:     364658>, provisioner_helper.c,  251, Addr: 0x0201 addr_handle: 1 netkey_handle: 0 devkey_handle: 3
<t:     370193>, provisioner_helper.c,  192, Local provisioning link closed: prov_state: 2  remaining retries: 2
<t:     370201>, main.c,  194, Provisioning successful
<t:     370207>, provisioner_helper.c,  216, Provisioning complete. ¹URI for LS Server example - address: 0x0201 elements: 2
<t:     370211>, node_setup.c,  742, Configuring Node: 0x0201
<t:     370214>, node_setup.c,  638, Config client setup: devkey_handle:3 addr_handle:1
<t:     370218>, node_setup.c,  413, Getting composition data
<t:     373735>, main.c,  247, Config client event
<t:     373738>, node_setup.c,  422, Updating network transmit: count: 2 steps: 1
<t:     376261>, main.c,  247, Config client event
<t:     376263>, node_setup.c,  433, Adding appkey
<t:     381330>, main.c,  247, Config client event
<t:     381332>, node_setup.c,  273, opcode status field: 0
<t:     381335>, node_setup.c,  472, App key bind: Health server on element address 0x0201
<t:     383875>, main.c,  247, Config client event
<t:     383877>, node_setup.c,  273, opcode status field: 0
<t:     383894>, node_setup.c,  491, Setting publication address for Health server to 0x0001
<t:     391050>, main.c,  247, Config client event
<t:     391053>, node_setup.c,  273, opcode status field: 0
<t:     391055>, node_setup.c,  472, App key bind: Generic OnOff server on element address 0x0201
<t:     393513>, main.c,  247, Config client event
<t:     393515>, node_setup.c,  273, opcode status field: 0
<t:     393526>, node_setup.c,  577, Adding subscription to address 0xC002 for Generic OnOff server on element address 0x0201
<t:     395878>, main.c,  247, Config client event
<t:     395880>, node_setup.c,  273, opcode status field: 0
<t:     395883>, node_setup.c,  443, Adding next element
<t:     395885>, node_setup.c,  472, App key bind: Generic OnOff server on element address 0x0202
<t:     398339>, main.c,  247, Config client event
<t:     398341>, node_setup.c,  273, opcode status field: 0
<t:     398352>, node_setup.c,  577, Adding subscription to address 0xC003 for Generic OnOff server on element address 0x0202
<t:     400886>, main.c,  247, Config client event
<t:     400888>, node_setup.c,  273, opcode status field: 0
<t:     400891>, main.c,  174, Configuration of device 1 successful
<t:     400898>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
<t:     496372>, main.c,  219, Node 0x0100 alive with 0 active fault(s), RSSI: -51
<t:     498792>, main.c,  219, Node 0x0100 alive with 0 active fault(s), RSSI: -51
<t:     713860>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -41
<t:     716373>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -41
<t:     823925>, main.c,  219, Node 0x0100 alive with 0 active fault(s), RSSI: -49
<t:     826680>, main.c,  219, Node 0x0100 alive with 0 active fault(s), RSSI: -49
<t:    1041723>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -33
<t:    1043935>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -33
<t:    1048962>, provisioner_helper.c,  168, UUID : B6942EF07507481AA0DFBF5FEEB35AFD
<t:    1048965>, provisioner_helper.c,  171, ^RSSI: -40
<t:    1048968>, provisioner_helper.c,  177, ^URI Hash: 74F97940
<t:    1048982>, node_setup.c,  768, true
<t:    1048984>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
<t:    1048987>, provisioner_helper.c,  183, URI hash matched to ¹URI for LS Server example. Provisioning ...
<t:    1056118>, provisioner_helper.c,  300, Provisioning link established
<t:    1068742>, provisioner_helper.c,  295, Static authentication data provided
<t:    1082830>, provisioner_helper.c,  233, Provisioning completed received
<t:    1082833>, provisioner_helper.c,  238, Adding device address, and device keys
<t:    1082857>, provisioner_helper.c,  251, Addr: 0x0202 addr_handle: 2 netkey_handle: 0 devkey_handle: 4
<t:    1088688>, provisioner_helper.c,  192, Local provisioning link closed: prov_state: 2  remaining retries: 2
<t:    1088696>, main.c,  194, Provisioning successful
<t:    1088702>, provisioner_helper.c,  216, Provisioning complete. ¹URI for LS Server example - address: 0x0202 elements: 2
<t:    1088706>, node_setup.c,  742, Configuring Node: 0x0202
<t:    1088709>, node_setup.c,  638, Config client setup: devkey_handle:4 addr_handle:2
<t:    1088713>, node_setup.c,  413, Getting composition data
<t:    1111177>, main.c,  247, Config client event
<t:    1111180>, node_setup.c,  422, Updating network transmit: count: 2 steps: 1
<t:    1113811>, main.c,  247, Config client event
<t:    1113813>, node_setup.c,  433, Adding appkey
<t:          0>, main.c,  336, ----- BLE Mesh Light Switch Server Demo -----
<t:      12559>, main.c,  304, Initializing and adding models
<t:      12563>, main.c,  171, App OnOff Model Handle: 3
<t:      12616>, main.c,  282, Node Address: 0x0205
<t:      12619>, mesh_app_utils.c,   66, Device UUID (raw): B6942EF07507481AA0DFBF5FEEB35AFD
<t:      12623>, mesh_app_utils.c,   67, Device UUID : B6942EF0-7507-481A-A0DF-BF5FEEB35AFD
<t:      12651>, main.c,  383,
		 Button/RTT 1) LED state will toggle and inform clients about the state change.
		 Button/RTT 4) Clear all the states to reset the node.
<t:      55199>, main.c,  287, Successfully provisioned
<t:      55204>, main.c,  282, Node Address: 0x0201
<t:      66570>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:          0>, main.c,  296, ----- BLE Mesh Light Switch Server Demo -----
<t:      12760>, main.c,  264, Initializing and adding models
<t:      12764>, main.c,  139, App OnOff Model Handle: 2
<t:      17540>, mesh_app_utils.c,   66, Device UUID (raw): 5E612FCB7BA041B6A40B5663B8F9DA2D
<t:      17543>, mesh_app_utils.c,   67, Device UUID : 5E612FCB-7BA0-41B6-A40B-5663B8F9DA2D
<t:      17556>, main.c,  343,
<t:     115352>, main.c,  247, Successfully provisioned
<t:     115357>, main.c,  242, Node Address: 0x0204
<t:     161186>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:     195024>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:     263057>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:     399591>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:     672302>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:    1218544>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:    2092800>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:    2638085>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
    I tried your code here but I didn't see the crash. I assume you saw the provisioner crashed ?
    Yes, on my side it crashes during the second configuration.
    I did something similare with the senario file but it seems like the previous random bug.
    #define CONFIG_SCENARIO_LIGHT_SWITCH_SERVER_EXAMPLE    \
        CONFIG_SCENARIO_COMMON,                            \
        CONFIG_ONOFF_SERVER,                               \
        NODE_SETUP_GET_NEXT_ELEMENT,                         \
        NODE_SETUP_DONE
    If you say that you can't see the crash, I will try to reset my setup.
  • Yes, please debug deeper and find why it crashes/stop continuing. Testing on a fresh copy of the SDK could be a good idea.
    I downloaded again the both sdk and added 1 element on the server boards. I'm facing the same error.
    15/06/20 11:20 - first try with new sdk - failed
    <t:          0>, main.c,  467, ----- BLE Mesh Static Provisioner Demo -----
    <t:      12485>, main.c,  397, Initializing and adding models
    <t:      12513>, main.c,  449, Setup defaults: Adding keys, addresses, and bindings
    <t:      12693>, provisioner_helper.c,  383, netkey_handle: 0
    <t:      12743>, main.c,  495, <start>
    <t:      12752>, main.c,  503,
    		 Button/RTT 1) Initiate provisioning and configuration of unprovisioned devices.
    <t:      14297>, main.c,  483, Starting application ...
    <t:      14299>, main.c,  484, Provisioned Nodes: 0, Configured Nodes: 0
    <t:      14302>, main.c,  486, Dev key : 520F6F56B141232B8C361B92E96AE0B7
    <t:      14306>, main.c,  487, Net key : 6C25384C079742942C84F20F69B1499D
    <t:      14309>, main.c,  488, App key : 2A419ABD243DCCB89331D04EFE5CD895
    <t:      14312>, main.c,  489, Press Button 1 to start provisioning and configuration process.
    <t:     108208>, main.c,  351, Button 1 pressed
    <t:     108210>, main.c,  274, Start provisioning procedure ...
    <t:     108213>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
    <t:     162405>, provisioner_helper.c,  168, UUID : EBE7B9A1188946E5830AD48A2E36B120
    <t:     162408>, provisioner_helper.c,  171, ^RSSI: -67
    <t:     162410>, provisioner_helper.c,  177, ^URI Hash: 74F97940
    <t:     162424>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
    <t:     162427>, provisioner_helper.c,  183, URI hash matched to ¹URI for LS Server example. Provisioning ...
    <t:     170111>, provisioner_helper.c,  300, Provisioning link established
    <t:     184285>, provisioner_helper.c,  295, Static authentication data provided
    <t:     198722>, provisioner_helper.c,  233, Provisioning completed received
    <t:     198725>, provisioner_helper.c,  238, Adding device address, and device keys
    <t:     198748>, provisioner_helper.c,  251, Addr: 0x0201 addr_handle: 0 netkey_handle: 0 devkey_handle: 2
    <t:     204751>, provisioner_helper.c,  192, Local provisioning link closed: prov_state: 2  remaining retries: 2
    <t:     204759>, main.c,  194, Provisioning successful
    <t:     204764>, provisioner_helper.c,  216, Provisioning complete. ¹URI for LS Server example - address: 0x0201 elements: 2
    <t:     204769>, node_setup.c,  736, Configuring Node: 0x0201
    <t:     204772>, node_setup.c,  632, Config client setup: devkey_handle:2 addr_handle:0
    <t:     204775>, node_setup.c,  412, Getting composition data
    <t:     208269>, main.c,  247, Config client event
    <t:     208271>, node_setup.c,  421, Updating network transmit: count: 2 steps: 1
    <t:     210607>, main.c,  247, Config client event
    <t:     210609>, node_setup.c,  432, Adding appkey
    <t:     234535>, main.c,  247, Config client event
    <t:     234537>, node_setup.c,  272, opcode status field: 0
    <t:     234540>, node_setup.c,  470, App key bind: Health server on element address 0x0201
    <t:     236977>, main.c,  247, Config client event
    <t:     236979>, node_setup.c,  272, opcode status field: 0
    <t:     236996>, node_setup.c,  489, Setting publication address for Health server to 0x0001
    <t:     244656>, main.c,  247, Config client event
    <t:     244658>, node_setup.c,  272, opcode status field: 0
    <t:     244661>, node_setup.c,  470, App key bind: Generic OnOff server on element address 0x0201
    <t:     247040>, main.c,  247, Config client event
    <t:     247042>, node_setup.c,  272, opcode status field: 0
    <t:     247058>, node_setup.c,  523, Setting publication address to 0xC005 for Generic OnOff server on element address 0x0201
    <t:     253992>, main.c,  247, Config client event
    <t:     253994>, node_setup.c,  272, opcode status field: 0
    <t:     254005>, node_setup.c,  572, Adding subscription to address 0xC003 for Generic OnOff server on element address 0x0201
    <t:     256596>, main.c,  247, Config client event
    <t:     256598>, node_setup.c,  272, opcode status field: 0
    <t:     256601>, main.c,  174, Configuration of device 0 successful
    <t:     256607>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
    <t:     297426>, provisioner_helper.c,  168, UUID : B6942EF07507481AA0DFBF5FEEB35AFD
    <t:     297429>, provisioner_helper.c,  171, ^RSSI: -60
    <t:     297432>, provisioner_helper.c,  177, ^URI Hash: 74F97940
    <t:     297446>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
    <t:     297449>, provisioner_helper.c,  183, URI hash matched to ¹URI for LS Server example. Provisioning ...
    <t:     303795>, provisioner_helper.c,  300, Provisioning link established
    <t:     319362>, provisioner_helper.c,  295, Static authentication data provided
    <t:     332733>, provisioner_helper.c,  233, Provisioning completed received
    <t:     332736>, provisioner_helper.c,  238, Adding device address, and device keys
    <t:     332759>, provisioner_helper.c,  251, Addr: 0x0202 addr_handle: 1 netkey_handle: 0 devkey_handle: 3
    <t:     338156>, provisioner_helper.c,  192, Local provisioning link closed: prov_state: 2  remaining retries: 2
    <t:     338164>, main.c,  194, Provisioning successful
    <t:     338169>, provisioner_helper.c,  216, Provisioning complete. ¹URI for LS Server example - address: 0x0202 elements: 2
    <t:     338174>, node_setup.c,  736, Configuring Node: 0x0202
    <t:     338177>, node_setup.c,  632, Config client setup: devkey_handle:3 addr_handle:1
    <t:     338181>, node_setup.c,  412, Getting composition data
    <t:     341523>, main.c,  247, Config client event
    <t:     341526>, node_setup.c,  421, Updating network transmit: count: 2 steps: 1
    <t:     344299>, main.c,  247, Config client event
    <t:     344302>, node_setup.c,  432, Adding appkey
    <t:     567227>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -67
    <t:     569834>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -67
    <t:     894649>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -73
    <t:     897192>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -73
    <t:    1222821>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -69
    <t:    1225151>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -69
    <t:    1550489>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -66
    <t:    1552899>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -66
    <t:    1877917>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -72
    <t:    1880238>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -73
    <t:    2205716>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -77
    <t:    2208178>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -77
    <t:    2310399>, main.c,  247, Config client event
    <t:    2310401>, node_setup.c,  680, Acknowledged message status not received
    <t:    2310404>, node_setup.c,  684, Retry ...
    <t:    2310406>, node_setup.c,  432, Adding appkey
    <t:    2533559>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -68
    <t:    2535777>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -69
    15/06/20 11:28 - provisioning 2 elements on each board - failed
    <t:      12541>, main.c,  397, Initializing and adding models
    <t:      12568>, main.c,  449, Setup defaults: Adding keys, addresses, and bindings
    <t:      12746>, provisioner_helper.c,  383, netkey_handle: 0
    <t:      12796>, main.c,  495, <start>
    <t:      12804>, main.c,  503,
    <t:      14350>, main.c,  483, Starting application ...
    <t:      14352>, main.c,  484, Provisioned Nodes: 0, Configured Nodes: 0
    <t:      14356>, main.c,  486, Dev key : A0198BB7A0C7DBEE98C352B2F2DCFC06
    <t:      14359>, main.c,  487, Net key : 88D7A1243A1FCE87496889F147C6FEB6
    <t:      14362>, main.c,  488, App key : 093BC6C412EFD36CFD92DE4036D9BCB7
    <t:      14365>, main.c,  489, Press Button 1 to start provisioning and configuration process.
    <t:      90043>, main.c,  351, Button 1 pressed
    <t:      90045>, main.c,  274, Start provisioning procedure ...
    <t:      90048>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
    <t:     292227>, provisioner_helper.c,  168, UUID : EBE7B9A1188946E5830AD48A2E36B120
    <t:     292230>, provisioner_helper.c,  171, ^RSSI: -58
    <t:     292232>, provisioner_helper.c,  177, ^URI Hash: 74F97940
    <t:     292246>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
    <t:     292249>, provisioner_helper.c,  183, URI hash matched to ¹URI for LS Server example. Provisioning ...
    <t:     300576>, provisioner_helper.c,  300, Provisioning link established
    <t:     315943>, provisioner_helper.c,  295, Static authentication data provided
    <t:     329749>, provisioner_helper.c,  233, Provisioning completed received
    <t:     329752>, provisioner_helper.c,  238, Adding device address, and device keys
    <t:     329775>, provisioner_helper.c,  251, Addr: 0x0201 addr_handle: 0 netkey_handle: 0 devkey_handle: 2
    <t:     335572>, provisioner_helper.c,  192, Local provisioning link closed: prov_state: 2  remaining retries: 2
    <t:     335580>, main.c,  194, Provisioning successful
    <t:     335585>, provisioner_helper.c,  216, Provisioning complete. ¹URI for LS Server example - address: 0x0201 elements: 2
    <t:     335590>, node_setup.c,  736, Configuring Node: 0x0201
    <t:     335593>, node_setup.c,  632, Config client setup: devkey_handle:2 addr_handle:0
    <t:     335596>, node_setup.c,  412, Getting composition data
    <t:     339421>, main.c,  247, Config client event
    <t:     339423>, node_setup.c,  421, Updating network transmit: count: 2 steps: 1
    <t:     342159>, main.c,  247, Config client event
    <t:     342161>, node_setup.c,  432, Adding appkey
    <t:     347238>, main.c,  247, Config client event
    <t:     347240>, node_setup.c,  272, opcode status field: 0
    <t:     347243>, node_setup.c,  470, App key bind: Health server on element address 0x0201
    <t:     349515>, main.c,  247, Config client event
    <t:     349517>, node_setup.c,  272, opcode status field: 0
    <t:     349534>, node_setup.c,  489, Setting publication address for Health server to 0x0001
    <t:     376970>, main.c,  247, Config client event
    <t:     376972>, node_setup.c,  272, opcode status field: 0
    <t:     376975>, node_setup.c,  470, App key bind: Generic OnOff server on element address 0x0201
    <t:     379721>, main.c,  247, Config client event
    <t:     379723>, node_setup.c,  272, opcode status field: 0
    <t:     379740>, node_setup.c,  523, Setting publication address to 0xC005 for Generic OnOff server on element address 0x0201
    <t:     407700>, main.c,  247, Config client event
    <t:     407703>, node_setup.c,  272, opcode status field: 0
    <t:     407713>, node_setup.c,  572, Adding subscription to address 0xC003 for Generic OnOff server on element address 0x0201
    <t:     410039>, main.c,  247, Config client event
    <t:     410042>, node_setup.c,  272, opcode status field: 0
    <t:     410044>, node_setup.c,  470, App key bind: Generic OnOff server on element address 0x0202
    <t:     412442>, main.c,  247, Config client event
    <t:     412445>, node_setup.c,  272, opcode status field: 0
    <t:     412461>, node_setup.c,  523, Setting publication address to 0xC005 for Generic OnOff server on element address 0x0202
    <t:     419843>, main.c,  247, Config client event
    <t:     419846>, node_setup.c,  272, opcode status field: 0
    <t:     419856>, node_setup.c,  572, Adding subscription to address 0xC003 for Generic OnOff server on element address 0x0202
    <t:     422133>, main.c,  247, Config client event
    <t:     422136>, node_setup.c,  272, opcode status field: 0
    <t:     422139>, main.c,  174, Configuration of device 0 successful
    <t:     422145>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
    <t:     470594>, provisioner_helper.c,  168, UUID : B6942EF07507481AA0DFBF5FEEB35AFD
    <t:     470597>, provisioner_helper.c,  171, ^RSSI: -53
    <t:     470599>, provisioner_helper.c,  177, ^URI Hash: 74F97940
    <t:     470613>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
    <t:     470616>, provisioner_helper.c,  183, URI hash matched to ¹URI for LS Server example. Provisioning ...
    <t:     476782>, provisioner_helper.c,  300, Provisioning link established
    <t:     491902>, provisioner_helper.c,  295, Static authentication data provided
    <t:     505843>, provisioner_helper.c,  233, Provisioning completed received
    <t:     505846>, provisioner_helper.c,  238, Adding device address, and device keys
    <t:     505869>, provisioner_helper.c,  251, Addr: 0x0202 addr_handle: 1 netkey_handle: 0 devkey_handle: 3
    <t:     511559>, provisioner_helper.c,  192, Local provisioning link closed: prov_state: 2  remaining retries: 2
    <t:     511567>, main.c,  194, Provisioning successful
    <t:     511572>, provisioner_helper.c,  216, Provisioning complete. ¹URI for LS Server example - address: 0x0202 elements: 2
    <t:     511577>, node_setup.c,  736, Configuring Node: 0x0202
    <t:     511580>, node_setup.c,  632, Config client setup: devkey_handle:3 addr_handle:1
    <t:     511583>, node_setup.c,  412, Getting composition data
    <t:     515100>, main.c,  247, Config client event
    <t:     515102>, node_setup.c,  421, Updating network transmit: count: 2 steps: 1
    <t:     517651>, main.c,  247, Config client event
    <t:     517653>, node_setup.c,  432, Adding appkey
    <t:     698534>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -58
    <t:     701241>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -58
    <t:    1026335>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -59
    <t:    1028942>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -59
    I can't believe this is working for the first time for you. I can't see my mistake.
  • Hi Loulou,
    Now when I test with 2 servers (2 elements each) I could see the issue on the 2nd server. I have forwarded this to the Mesh team for investigation. Will get back to you when we find the bug.
  • Thank you for your time. I look forward to your reply.
    Br
