NRF MESH provisioner node - appKey error
I am in the process of provisioning and configuring a 2-element light switch server node and a common light switch server. I am using the orginal exemple for the provisioner and common light switch server and a modified 2-element light switch server node.
When I start the configuration with the 2-element node it works but the following configuration freezes while searching for the appKey. (Terminal_provisioner_view)
In the reverse order everything works normally.
I have attached debug terminal from each point of view.
Thanks.
(using nrf52840-DK / Mesh v4.1.0 / SDK v16.0.0)
<t:     300644>, main.c,  174, Configuration of device 0 successful
<t:     300651>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
<t:     328492>, provisioner_helper.c,  168, UUID : 07C5A7ED6C9D4B869FAB8C12A2DFE0F6
<t:     328495>, provisioner_helper.c,  171, ^RSSI: -40
<t:     328497>, provisioner_helper.c,  177, ^URI Hash: 74F97940
<t:     328512>, node_setup.c,  768, true<t:     328513>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
<t:     328516>, provisioner_helper.c,  183, URI hash matched to ¹URI for LS Server example. Provisioning ...
<t:     335229>, provisioner_helper.c,  300, Provisioning link established
<t:     350923>, provisioner_helper.c,  295, Static authentication data provided
<t:     364631>, provisioner_helper.c,  233, Provisioning completed received
<t:     364634>, provisioner_helper.c,  238, Adding device address, and device keys
<t:     364658>, provisioner_helper.c,  251, Addr: 0x0201 addr_handle: 1 netkey_handle: 0 devkey_handle: 3
<t:     370193>, provisioner_helper.c,  192, Local provisioning link closed: prov_state: 2  remaining retries: 2
<t:     370201>, main.c,  194, Provisioning successful
<t:     370207>, provisioner_helper.c,  216, Provisioning complete. ¹URI for LS Server example - address: 0x0201 elements: 2
<t:     370211>, node_setup.c,  742, Configuring Node: 0x0201
<t:     370214>, node_setup.c,  638, Config client setup: devkey_handle:3 addr_handle:1
<t:     370218>, node_setup.c,  413, Getting composition data
<t:     373735>, main.c,  247, Config client event
<t:     373738>, node_setup.c,  422, Updating network transmit: count: 2 steps: 1
<t:     376261>, main.c,  247, Config client event
<t:     376263>, node_setup.c,  433, Adding appkey
<t:     381330>, main.c,  247, Config client event
<t:     381332>, node_setup.c,  273, opcode status field: 0
<t:     381335>, node_setup.c,  472, App key bind: Health server on element address 0x0201
<t:     383875>, main.c,  247, Config client event
<t:     383877>, node_setup.c,  273, opcode status field: 0
<t:     383894>, node_setup.c,  491, Setting publication address for Health server to 0x0001
<t:     391050>, main.c,  247, Config client event
<t:     391053>, node_setup.c,  273, opcode status field: 0
<t:     391055>, node_setup.c,  472, App key bind: Generic OnOff server on element address 0x0201
<t:     393513>, main.c,  247, Config client event
<t:     393515>, node_setup.c,  273, opcode status field: 0
<t:     393526>, node_setup.c,  577, Adding subscription to address 0xC002 for Generic OnOff server on element address 0x0201
<t:     395878>, main.c,  247, Config client event
<t:     395880>, node_setup.c,  273, opcode status field: 0
<t:     395883>, node_setup.c,  443, Adding next element
<t:     395885>, node_setup.c,  472, App key bind: Generic OnOff server on element address 0x0202
<t:     398339>, main.c,  247, Config client event
<t:     398341>, node_setup.c,  273, opcode status field: 0
<t:     398352>, node_setup.c,  577, Adding subscription to address 0xC003 for Generic OnOff server on element address 0x0202
<t:     400886>, main.c,  247, Config client event
<t:     400888>, node_setup.c,  273, opcode status field: 0
<t:     400891>, main.c,  174, Configuration of device 1 successful
<t:     400898>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
<t:     496372>, main.c,  219, Node 0x0100 alive with 0 active fault(s), RSSI: -51
<t:     498792>, main.c,  219, Node 0x0100 alive with 0 active fault(s), RSSI: -51
<t:     713860>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -41
<t:     716373>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -41
<t:     823925>, main.c,  219, Node 0x0100 alive with 0 active fault(s), RSSI: -49
<t:     826680>, main.c,  219, Node 0x0100 alive with 0 active fault(s), RSSI: -49
<t:    1041723>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -33
<t:    1043935>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -33
<t:    1048962>, provisioner_helper.c,  168, UUID : B6942EF07507481AA0DFBF5FEEB35AFD
<t:    1048965>, provisioner_helper.c,  171, ^RSSI: -40
<t:    1048968>, provisioner_helper.c,  177, ^URI Hash: 74F97940
<t:    1048982>, node_setup.c,  768, true
<t:    1048984>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
<t:    1048987>, provisioner_helper.c,  183, URI hash matched to ¹URI for LS Server example. Provisioning ...
<t:    1056118>, provisioner_helper.c,  300, Provisioning link established
<t:    1068742>, provisioner_helper.c,  295, Static authentication data provided
<t:    1082830>, provisioner_helper.c,  233, Provisioning completed received
<t:    1082833>, provisioner_helper.c,  238, Adding device address, and device keys
<t:    1082857>, provisioner_helper.c,  251, Addr: 0x0202 addr_handle: 2 netkey_handle: 0 devkey_handle: 4
<t:    1088688>, provisioner_helper.c,  192, Local provisioning link closed: prov_state: 2  remaining retries: 2
<t:    1088696>, main.c,  194, Provisioning successful
<t:    1088702>, provisioner_helper.c,  216, Provisioning complete. ¹URI for LS Server example - address: 0x0202 elements: 2
<t:    1088706>, node_setup.c,  742, Configuring Node: 0x0202
<t:    1088709>, node_setup.c,  638, Config client setup: devkey_handle:4 addr_handle:2
<t:    1088713>, node_setup.c,  413, Getting composition data
<t:    1111177>, main.c,  247, Config client event
<t:    1111180>, node_setup.c,  422, Updating network transmit: count: 2 steps: 1
<t:    1113811>, main.c,  247, Config client event
<t:    1113813>, node_setup.c,  433, Adding appkey
<t:          0>, main.c,  336, ----- BLE Mesh Light Switch Server Demo -----
<t:      12559>, main.c,  304, Initializing and adding models
<t:      12563>, main.c,  171, App OnOff Model Handle: 3
<t:      12616>, main.c,  282, Node Address: 0x0205
<t:      12619>, mesh_app_utils.c,   66, Device UUID (raw): B6942EF07507481AA0DFBF5FEEB35AFD
<t:      12623>, mesh_app_utils.c,   67, Device UUID : B6942EF0-7507-481A-A0DF-BF5FEEB35AFD
<t:      12651>, main.c,  383,
		 Button/RTT 1) LED state will toggle and inform clients about the state change.
		 Button/RTT 4) Clear all the states to reset the node.
<t:      55199>, main.c,  287, Successfully provisioned
<t:      55204>, main.c,  282, Node Address: 0x0201
<t:      66570>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:          0>, main.c,  296, ----- BLE Mesh Light Switch Server Demo -----
<t:      12760>, main.c,  264, Initializing and adding models
<t:      12764>, main.c,  139, App OnOff Model Handle: 2
<t:      17540>, mesh_app_utils.c,   66, Device UUID (raw): 5E612FCB7BA041B6A40B5663B8F9DA2D
<t:      17543>, mesh_app_utils.c,   67, Device UUID : 5E612FCB-7BA0-41B6-A40B-5663B8F9DA2D
<t:      17556>, main.c,  343,
<t:     115352>, main.c,  247, Successfully provisioned
<t:     115357>, main.c,  242, Node Address: 0x0204
<t:     161186>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:     195024>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:     263057>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:     399591>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:     672302>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:    1218544>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:    2092800>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t:    2638085>, config_server.c,  630, dsm_appkey_add(appkey_handle:0 appkey_index:0)
  • Hi Loulou,
    Could you debug and check what's the value of the return code when config_client_appkey_add() called in the provisioner ?
    What's the output of the log on the client ? has it receive the app_key adding packet ?
    The node_setup.c is designed with some specific scenario so it might not work out of the box when you add more element into the server. The node_setup.c might need to be modified, I'm not sure.
    If you configure 2 servers each with 2 elements would it work ?
    This function returns 0 in any case. (bug and not)
    No problem with the client, its configuration is a success every time.
    I can understand that senario are quite rigid but an unconfigured element should not cause probleme.
    It depends, sometimes yes, sometimes no. It's very difficult to study this kind of random bug. That's why I found a case where it crashes every time: configuring a node with 2 elements and then a node with 1 element.
    Thanks
    BR
  • Could you provide us the server code so we can reproduce the issue here ?
  • Thank you for your quick responses.
    I had time to retry your question : "If you configure 2 servers each with 2 elements would it work ?" I have attached the full terminal with one succes and one failure. I tried around 10 times and it had succed 3, it seems random.
    <t:          0>, main.c,  467, ----- BLE Mesh Static Provisioner Demo -----
    <t:       8810>, main.c,  397, Initializing and adding models
    <t:       8845>, main.c,  449, Setup defaults: Adding keys, addresses, and bindings
    <t:       9024>, provisioner_helper.c,  383, netkey_handle: 0
    <t:       9074>, main.c,  495, <start>
    <t:       9083>, main.c,  503,
    		 Button/RTT 1) Initiate provisioning and configuration of unprovisioned devices.
    <t:      10307>, main.c,  483, Starting application ...
    <t:      10309>, main.c,  484, Provisioned Nodes: 0, Configured Nodes: 0
    <t:      10313>, main.c,  486, Dev key : 248D70C4FDA3649A217ACD0091AF1EEF
    <t:      10316>, main.c,  487, Net key : 084C9D3A28B8C58D2EEB573A1D63460A
    <t:      10319>, main.c,  488, App key : DAA6049C089205A5F3AA3529C5DD2D4F
    <t:      10322>, main.c,  489, Press Button 1 to start provisioning and configuration process.
    <t:     206104>, main.c,  351, Button 1 pressed
    <t:     206106>, main.c,  274, Start provisioning procedure ...
    <t:     206109>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
    <t:     238185>, provisioner_helper.c,  168, UUID : B6942EF07507481AA0DFBF5FEEB35AFD
    <t:     238188>, provisioner_helper.c,  171, ^RSSI: -55
    <t:     238191>, provisioner_helper.c,  177, ^URI Hash: 74F97940
    <t:     238205>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
    <t:     238208>, provisioner_helper.c,  183, URI hash matched to �URI for LS Server example. Provisioning ...
    <t:     244596>, provisioner_helper.c,  300, Provisioning link established
    <t:     394074>, provisioner_helper.c,  295, Static authentication data provided
    <t:     407533>, provisioner_helper.c,  233, Provisioning completed received
    <t:     407536>, provisioner_helper.c,  238, Adding device address, and device keys
    <t:     407560>, provisioner_helper.c,  251, Addr: 0x0201 addr_handle: 0 netkey_handle: 0 devkey_handle: 2
    <t:     413531>, provisioner_helper.c,  192, Local provisioning link closed: prov_state: 2  remaining retries: 2
    <t:     413539>, main.c,  194, Provisioning successful
    <t:     413544>, provisioner_helper.c,  216, Provisioning complete. �URI for LS Server example - address: 0x0201 elements: 2
    <t:     413549>, node_setup.c,  738, Configuring Node: 0x0201
    <t:     413552>, node_setup.c,  633, Config client setup: devkey_handle:2 addr_handle:0
    <t:     413555>, node_setup.c,  413, Getting composition data
    <t:     417289>, main.c,  247, Config client event
    <t:     417292>, node_setup.c,  270, opcode statuspassed
    <t:     417294>, node_setup.c,  658, Call config_step_execute with step : 3
    <t:     417297>, node_setup.c,  422, Updating network transmit: count: 2 steps: 1
    <t:     419676>, main.c,  247, Config client event
    <t:     419678>, node_setup.c,  270, opcode statuspassed
    <t:     419681>, node_setup.c,  658, Call config_step_execute with step : 4
    <t:     419683>, node_setup.c,  433, Adding appkey
    <t:     424772>, main.c,  247, Config client event
    <t:     424774>, node_setup.c,  273, opcode status field: 0
    <t:     424776>, node_setup.c,  658, Call config_step_execute with step : 5
    <t:     424779>, node_setup.c,  471, App key bind: Health server on element address 0x0201
    <t:     459435>, main.c,  247, Config client event
    <t:     459437>, node_setup.c,  273, opcode status field: 0
    <t:     459440>, node_setup.c,  658, Call config_step_execute with step : 24
    <t:     459457>, node_setup.c,  490, Setting publication address for Health server to 0x0001
    <t:     487617>, main.c,  247, Config client event
    <t:     487619>, node_setup.c,  273, opcode status field: 0
    <t:     487621>, node_setup.c,  658, Call config_step_execute with step : 6
    <t:     487624>, node_setup.c,  471, App key bind: Generic OnOff server on element address 0x0201
    <t:     522151>, main.c,  247, Config client event
    <t:     522154>, node_setup.c,  273, opcode status field: 0
    <t:     522156>, node_setup.c,  658, Call config_step_execute with step : 25
    <t:     522173>, node_setup.c,  524, Setting publication address to 0xC005 for Generic OnOff server on element address 0x0201
    <t:     529703>, main.c,  247, Config client event
    <t:     529706>, node_setup.c,  273, opcode status field: 0
    <t:     529708>, node_setup.c,  658, Call config_step_execute with step : 27
    <t:     529719>, node_setup.c,  573, Adding subscription to address 0xC003 for Generic OnOff server on element address 0x0201
    <t:     532141>, main.c,  247, Config client event
    <t:     532143>, node_setup.c,  273, opcode status field: 0
    <t:     532146>, main.c,  174, Configuration of device 0 successful
    <t:     532153>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
    <t:     547470>, provisioner_helper.c,  168, UUID : EBE7B9A1188946E5830AD48A2E36B120
    <t:     547473>, provisioner_helper.c,  171, ^RSSI: -67
    <t:     547476>, provisioner_helper.c,  177, ^URI Hash: 74F97940
    <t:     547490>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
    <t:     547493>, provisioner_helper.c,  183, URI hash matched to �URI for LS Server example. Provisioning ...
    <t:     556506>, provisioner_helper.c,  300, Provisioning link established
    <t:     570915>, provisioner_helper.c,  295, Static authentication data provided
    <t:     585198>, provisioner_helper.c,  233, Provisioning completed received
    <t:     585201>, provisioner_helper.c,  238, Adding device address, and device keys
    <t:     585224>, provisioner_helper.c,  251, Addr: 0x0202 addr_handle: 1 netkey_handle: 0 devkey_handle: 3
    <t:     590846>, provisioner_helper.c,  192, Local provisioning link closed: prov_state: 2  remaining retries: 2
    <t:     590854>, main.c,  194, Provisioning successful
    <t:     590860>, provisioner_helper.c,  216, Provisioning complete. �URI for LS Server example - address: 0x0202 elements: 2
    <t:     590864>, node_setup.c,  738, Configuring Node: 0x0202
    <t:     590867>, node_setup.c,  633, Config client setup: devkey_handle:3 addr_handle:1
    <t:     590871>, node_setup.c,  413, Getting composition data
    <t:     594668>, main.c,  247, Config client event
    <t:     594670>, node_setup.c,  270, opcode statuspassed
    <t:     594672>, node_setup.c,  658, Call config_step_execute with step : 3
    <t:     594675>, node_setup.c,  422, Updating network transmit: count: 2 steps: 1
    <t:     597109>, main.c,  247, Config client event
    <t:     597111>, node_setup.c,  270, opcode statuspassed
    <t:     597113>, node_setup.c,  658, Call config_step_execute with step : 4
    <t:     597116>, node_setup.c,  433, Adding appkey
    <t:     809394>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -51
    <t:     812105>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -50
    <t:     874431>, main.c,  247, Config client event
    <t:     874433>, node_setup.c,  273, opcode status field: 0
    <t:     874435>, node_setup.c,  658, Call config_step_execute with step : 5
    <t:     874438>, node_setup.c,  471, App key bind: Health server on element address 0x0202
    <t:     877250>, main.c,  247, Config client event
    <t:     877252>, node_setup.c,  273, opcode status field: 0
    <t:     877255>, node_setup.c,  658, Call config_step_execute with step : 24
    <t:     877272>, node_setup.c,  490, Setting publication address for Health server to 0x0001
    <t:     884855>, main.c,  247, Config client event
    <t:     884857>, node_setup.c,  273, opcode status field: 0
    <t:     884860>, node_setup.c,  658, Call config_step_execute with step : 6
    <t:     884863>, node_setup.c,  471, App key bind: Generic OnOff server on element address 0x0202
    <t:     887429>, main.c,  247, Config client event
    <t:     887431>, node_setup.c,  273, opcode status field: 0
    <t:     887434>, node_setup.c,  658, Call config_step_execute with step : 25
    <t:     887451>, node_setup.c,  524, Setting publication address to 0xC004 for Generic OnOff server on element address 0x0202
    <t:     894458>, main.c,  247, Config client event
    <t:     894460>, node_setup.c,  273, opcode status field: 0
    <t:     894463>, node_setup.c,  658, Call config_step_execute with step : 27
    <t:     894474>, node_setup.c,  573, Adding subscription to address 0xC002 for Generic OnOff server on element address 0x0202
    <t:     897238>, main.c,  247, Config client event
    <t:     897240>, node_setup.c,  273, opcode status field: 0
    <t:     897243>, main.c,  174, Configuration of device 1 successful
    <t:     897249>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
    <t:    1137366>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -52
    <t:    1139745>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -53
    <t:    1207489>, main.c,  219, Node 0x0202 alive with 0 active fault(s), RSSI: -67
    <t:    1209850>, main.c,  219, Node 0x0202 alive with 0 active fault(s), RSSI: -67
    <t:    1465015>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -65
    <t:    1467551>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -66
    <t:    1535179>, main.c,  219, Node 0x0202 alive with 0 active fault(s), RSSI: -63
    <t:    1537474>, main.c,  219, Node 0x0202 alive with 0 active fault(s), RSSI: -63
    <t:    1792739>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -52
    <t:    1795248>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -51
    <t:    1860235>, main.c,  351, Button 4 pressed
    <t:    1860238>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
    <t:    1860381>, main.c,  331, ----- Node reset  -----
    <t:       8830>, main.c,  397, Initializing and adding models
    <t:       8866>, main.c,  449, Setup defaults: Adding keys, addresses, and bindings
    <t:       9059>, provisioner_helper.c,  383, netkey_handle: 0
    <t:       9109>, main.c,  495, <start>
    <t:       9119>, main.c,  503,
    <t:      10345>, main.c,  483, Starting application ...
    <t:      10347>, main.c,  484, Provisioned Nodes: 0, Configured Nodes: 0
    <t:      10351>, main.c,  486, Dev key : 23AC95434D8BE81BDFE3B982EBC2D558
    <t:      10354>, main.c,  487, Net key : EDB0ECF2D82FEF518860A56ECB01D918
    <t:      10357>, main.c,  488, App key : 5C70B755FAF74C4164FC1EA17C678CB7
    <t:      10360>, main.c,  489, Press Button 1 to start provisioning and configuration process.
    <t:     309826>, main.c,  351, Button 1 pressed
    <t:     309828>, main.c,  274, Start provisioning procedure ...
    <t:     309830>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
    <t:     330943>, provisioner_helper.c,  168, UUID : B6942EF07507481AA0DFBF5FEEB35AFD
    <t:     330946>, provisioner_helper.c,  171, ^RSSI: -57
    <t:     330949>, provisioner_helper.c,  177, ^URI Hash: 74F97940
    <t:     330963>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
    <t:     330966>, provisioner_helper.c,  183, URI hash matched to �URI for LS Server example. Provisioning ...
    <t:     338220>, provisioner_helper.c,  300, Provisioning link established
    <t:     352951>, provisioner_helper.c,  295, Static authentication data provided
    <t:     367072>, provisioner_helper.c,  233, Provisioning completed received
    <t:     367075>, provisioner_helper.c,  238, Adding device address, and device keys
    <t:     367099>, provisioner_helper.c,  251, Addr: 0x0201 addr_handle: 0 netkey_handle: 0 devkey_handle: 2
    <t:     372665>, provisioner_helper.c,  192, Local provisioning link closed: prov_state: 2  remaining retries: 2
    <t:     372673>, main.c,  194, Provisioning successful
    <t:     372678>, provisioner_helper.c,  216, Provisioning complete. �URI for LS Server example - address: 0x0201 elements: 2
    <t:     372683>, node_setup.c,  738, Configuring Node: 0x0201
    <t:     372686>, node_setup.c,  633, Config client setup: devkey_handle:2 addr_handle:0
    <t:     372689>, node_setup.c,  413, Getting composition data
    <t:     375613>, main.c,  247, Config client event
    <t:     375615>, node_setup.c,  270, opcode statuspassed
    <t:     375617>, node_setup.c,  658, Call config_step_execute with step : 3
    <t:     375620>, node_setup.c,  422, Updating network transmit: count: 2 steps: 1
    <t:     378395>, main.c,  247, Config client event
    <t:     378397>, node_setup.c,  270, opcode statuspassed
    <t:     378400>, node_setup.c,  658, Call config_step_execute with step : 4
    <t:     378403>, node_setup.c,  433, Adding appkey
    <t:     383398>, main.c,  247, Config client event
    <t:     383400>, node_setup.c,  273, opcode status field: 0
    <t:     383403>, node_setup.c,  658, Call config_step_execute with step : 5
    <t:     383405>, node_setup.c,  471, App key bind: Health server on element address 0x0201
    <t:     385545>, main.c,  247, Config client event
    <t:     385547>, node_setup.c,  273, opcode status field: 0
    <t:     385550>, node_setup.c,  658, Call config_step_execute with step : 24
    <t:     385567>, node_setup.c,  490, Setting publication address for Health server to 0x0001
    <t:     413159>, main.c,  247, Config client event
    <t:     413161>, node_setup.c,  273, opcode status field: 0
    <t:     413164>, node_setup.c,  658, Call config_step_execute with step : 6
    <t:     413167>, node_setup.c,  471, App key bind: Generic OnOff server on element address 0x0201
    <t:     415687>, main.c,  247, Config client event
    <t:     415689>, node_setup.c,  273, opcode status field: 0
    <t:     415692>, node_setup.c,  658, Call config_step_execute with step : 25
    <t:     415708>, node_setup.c,  524, Setting publication address to 0xC005 for Generic OnOff server on element address 0x0201
    <t:     423612>, main.c,  247, Config client event
    <t:     423614>, node_setup.c,  273, opcode status field: 0
    <t:     423617>, node_setup.c,  658, Call config_step_execute with step : 27
    <t:     423628>, node_setup.c,  573, Adding subscription to address 0xC003 for Generic OnOff server on element address 0x0201
    <t:     458118>, main.c,  247, Config client event
    <t:     458120>, node_setup.c,  273, opcode status field: 0
    <t:     458123>, main.c,  174, Configuration of device 0 successful
    <t:     458130>, provisioner_helper.c,  326, Scanning For Unprovisioned Devices
    <t:     473382>, provisioner_helper.c,  168, UUID : EBE7B9A1188946E5830AD48A2E36B120
    <t:     473385>, provisioner_helper.c,  171, ^RSSI: -61
    <t:     473387>, provisioner_helper.c,  177, ^URI Hash: 74F97940
    <t:     473401>, provisioner_helper.c,  332, Stop Scanning For Unprovisioned Devices
    <t:     473404>, provisioner_helper.c,  183, URI hash matched to �URI for LS Server example. Provisioning ...
    <t:     480809>, provisioner_helper.c,  300, Provisioning link established
    <t:     562479>, provisioner_helper.c,  295, Static authentication data provided
    <t:     576136>, provisioner_helper.c,  233, Provisioning completed received
    <t:     576139>, provisioner_helper.c,  238, Adding device address, and device keys
    <t:     576163>, provisioner_helper.c,  251, Addr: 0x0202 addr_handle: 1 netkey_handle: 0 devkey_handle: 3
    <t:     581767>, provisioner_helper.c,  192, Local provisioning link closed: prov_state: 2  remaining retries: 2
    <t:     581775>, main.c,  194, Provisioning successful
    <t:     581781>, provisioner_helper.c,  216, Provisioning complete. �URI for LS Server example - address: 0x0202 elements: 2
    <t:     581785>, node_setup.c,  738, Configuring Node: 0x0202
    <t:     581788>, node_setup.c,  633, Config client setup: devkey_handle:3 addr_handle:1
    <t:     581792>, node_setup.c,  413, Getting composition data
    <t:     584979>, main.c,  247, Config client event
    <t:     584981>, node_setup.c,  270, opcode statuspassed
    <t:     584983>, node_setup.c,  658, Call config_step_execute with step : 3
    <t:     584986>, node_setup.c,  422, Updating network transmit: count: 2 steps: 1
    <t:     652352>, main.c,  247, Config client event
    <t:     652354>, node_setup.c,  270, opcode statuspassed
    <t:     652356>, node_setup.c,  658, Call config_step_execute with step : 4
    <t:     652359>, node_setup.c,  433, Adding appkey
    <t:     735419>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -53
    <t:     738125>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -53
    <t:    1062896>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -60
    <t:    1065369>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -59
    <t:    1390639>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -54
    <t:    1393139>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -54
    <t:    1718259>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -55
    <t:    1720783>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -55
    <t:    2046108>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -56
    <t:    2048786>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -55
    <t:    2373845>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -50
    <t:    2376533>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -52
    <t:    2618456>, main.c,  247, Config client event
    <t:    2618458>, node_setup.c,  682, Acknowledged message status not received
    <t:    2618461>, node_setup.c,  686, Retry ...
    <t:    2618463>, node_setup.c,  433, Adding appkey
    <t:    2701465>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -57
    <t:    2703984>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -56
    <t:    3029203>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -61
    <t:    3031526>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -63
    <t:    3356779>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -59
    <t:    3358939>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -59
    <t:    3684425>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -55
    <t:    3686907>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -55
    <t:    4012299>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -58
    <t:    4014894>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -58
    <t:    4339836>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -52
    <t:    4342554>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -52
    <t:    4584561>, main.c,  247, Config client event
    <t:    4584563>, node_setup.c,  682, Acknowledged message status not received
    <t:    4584566>, node_setup.c,  686, Retry ...
    <t:    4584568>, node_setup.c,  433, Adding appkey
    <t:    4667600>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -54
    <t:    4670156>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -54
    <t:    4995356>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -58
    <t:    4997868>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -58
    <t:    5323034>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -54
    <t:    5325458>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -54
    <t:    5650516>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -57
    <t:    5653191>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -58
    <t:    5978296>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -58
    <t:    5980631>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -59
    <t:    6305929>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -53
    <t:    6308572>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -53
    <t:    6550666>, main.c,  247, Config client event
    <t:    6550668>, node_setup.c,  682, Acknowledged message status not received
    <t:    6550672>, main.c,  187, Configuration of device 1 failed. Press Button 1 to retry.
    <t:    6633549>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -56
    <t:    6635816>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -56
    <t:    6961300>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -57
    <t:    6963754>, main.c,  219, Node 0x0201 alive with 0 active fault(s), RSSI: -57
    My modifications of the server are inspired by this. However, I have attached my modified files.
    Any modification on the provisioner exemple.
     **\nrf5_SDK_for_Mesh_v4.1.0_src\examples\light_switch\client\src\main.c
    /* Copyright (c) 2010 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
     * list of conditions and the following disclaimer.
    #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    #include "simple_hal.h"
    #include "app_timer.h"
    /* Core */
    #include "nrf_mesh_config_core.h"
    #include "nrf_mesh_gatt.h"
    #include "nrf_mesh_configure.h"
    #include "nrf_mesh.h"
    #include "mesh_stack.h"
    #include "device_state_manager.h"
    #include "access_config.h"
    #include "proxy.h"
    /* Provisioning and configuration */
    #include "mesh_provisionee.h"
    #include "mesh_app_utils.h"
    /* Models */
    #include "generic_onoff_server.h"
    /* Logging and RTT */
    #include "log.h"
    #include "rtt_input.h"
    /* Example specific includes */
    #include "app_config.h"
    #include "example_common.h"
    #include "nrf_mesh_config_examples.h"
    #include "light_switch_example_common.h"
    #include "app_onoff.h"
    #include "ble_softdevice_support.h"
     * Definitions
    #define ONOFF_SERVER_0_LED          (BSP_LED_0)
    #define ONOFF_SERVER_1_LED          (BSP_LED_1) // changed - add
    #define APP_ONOFF_ELEMENT_INDEX     (0)
    /* Controls if the model instance should force all mesh messages to be segmented messages. */
    #define APP_FORCE_SEGMENTATION      (false)
    /* Controls the MIC size used by the model instance for sending the mesh messages. */
    #define APP_MIC_SIZE                (NRF_MESH_TRANSMIC_SIZE_SMALL)
     * Forward declaration of static functions
    static void app_onoff_server_set_cb(const app_onoff_server_t * p_server, bool onoff);
    static void app_onoff_server_get_cb(const app_onoff_server_t * p_server, bool * p_present_onoff);
    static void app_onoff_server_transition_cb(const app_onoff_server_t * p_server,
                                                    uint32_t transition_time_ms, bool target_onoff);
    static void app_onoff_server_set_cb_1(const app_onoff_server_t * p_server, bool onoff);
    static void app_onoff_server_get_cb_1(const app_onoff_server_t * p_server, bool * p_present_onoff);
     * Static variables
    static bool m_device_provisioned;
    /* Generic OnOff server structure definition and initialization */
    APP_ONOFF_SERVER_DEF(m_onoff_server_0,
                         APP_FORCE_SEGMENTATION,
                         APP_MIC_SIZE,
                         app_onoff_server_set_cb,
                         app_onoff_server_get_cb,
                         app_onoff_server_transition_cb)
     APP_ONOFF_SERVER_DEF(m_onoff_server_1,
                         APP_MIC_SIZE,
                         app_onoff_server_set_cb_1,
                         app_onoff_server_get_cb_1,
    /* Callback for updating the hardware state */
        /* Resolve the server instance here if required, this example uses only 1 instance. */
        hal_led_pin_set(ONOFF_SERVER_0_LED, onoff);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setting GPIO value: %d Server id : %d\n", onoff,p_server->server.model_handle)
        hal_led_pin_set(ONOFF_SERVER_1_LED, onoff);
    /* Callback for reading the hardware state */
        *p_present_onoff = hal_led_pin_get(ONOFF_SERVER_0_LED);
       *p_present_onoff = hal_led_pin_get(ONOFF_SERVER_1_LED);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Transition time: %d, Target OnOff: %d\n",
                                           transition_time_ms, target_onoff);
    static void app_model_init(void)
        ERROR_CHECK(app_onoff_init(&m_onoff_server_1, APP_ONOFF_ELEMENT_INDEX + 1)); // changed - add
        /* Instantiate onoff server on element index APP_ONOFF_ELEMENT_INDEX */
        ERROR_CHECK(app_onoff_init(&m_onoff_server_0, APP_ONOFF_ELEMENT_INDEX));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App OnOff Model Handle: %d\n", m_onoff_server_0.server.model_handle);
    static void node_reset(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
        /* This function may return if there are ongoing flash operations. */
        mesh_stack_device_reset();
    static void config_server_evt_cb(const config_server_evt_t * p_evt)
        if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
            node_reset();
    #if NRF_MESH_LOG_ENABLE
    static const char m_usage_string[] =
        "\n"
        "\t\t-------------------------------------------------------------------------------\n"
        "\t\t Button/RTT 1) LED state will toggle and inform clients about the state change.\n"
        "\t\t Button/RTT 4) Clear all the states to reset the node.\n"
        "\t\t-------------------------------------------------------------------------------\n";
    static void button_event_handler(uint32_t button_number)
        /* Increase button number because the buttons on the board is marked with 1 to 4 */
        button_number++;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
        switch (button_number)
            /* Pressing SW1 on the Development Kit will result in LED state to toggle and trigger
            the STATUS message to inform client about the state change. This is a demonstration of
            state change publication due to local event. */
            case 1:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "User action \n");
                hal_led_pin_set(ONOFF_SERVER_0_LED, !hal_led_pin_get(ONOFF_SERVER_0_LED));// led
                app_onoff_status_publish(&m_onoff_server_0);
            case 2:
                hal_led_pin_set(BSP_LED_2,1);
            case 3:
                 hal_led_pin_set(BSP_LED_2,0);
            /* Initiate node reset */
            case 4:
                /* Clear all the states to reset the node. */
                if (mesh_stack_is_device_provisioned())
    #if MESH_FEATURE_GATT_PROXY_ENABLED
                    (void) proxy_stop();
                    mesh_stack_config_clear();
                    node_reset();
                    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "The device is unprovisioned. Resetting has no effect.\n");
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, m_usage_string);
    static void app_rtt_input_handler(int key)
        if (key >= '1' && key <= '4')
            uint32_t button_number = key - '1';
            button_event_handler(button_number);
    static void device_identification_start_cb(uint8_t attention_duration_s)
        hal_led_mask_set(LEDS_MASK, false);
        hal_led_blink_ms(BSP_LED_2_MASK  | BSP_LED_3_MASK,
                         LED_BLINK_ATTENTION_INTERVAL_MS,
                         LED_BLINK_ATTENTION_COUNT(attention_duration_s));
    static void provisioning_aborted_cb(void)
        hal_led_blink_stop();
    static void unicast_address_print(void)
        dsm_local_unicast_address_t node_address;
        dsm_local_unicast_addresses_get(&node_address);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
    static void provisioning_complete_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
    #if MESH_FEATURE_GATT_ENABLED
        /* Restores the application parameters after switching from the Provisioning
         * service to the Proxy  */
        gap_params_init();
        conn_params_init();
        unicast_address_print();
        hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
    static void models_init_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
        app_model_init();
    static void mesh_init(void)
        mesh_stack_init_params_t init_params =
            .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
            .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
            .core.p_uuid             = NULL,
            .models.models_init_cb   = models_init_cb,
            .models.config_server_cb = config_server_evt_cb
        uint32_t status = mesh_stack_init(&init_params, &m_device_provisioned);
        switch (status)
            case NRF_ERROR_INVALID_DATA:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Data in the persistent memory was corrupted. Device starts as unprovisioned.\n");
    			__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reset device before start provisioning.\n");
            case NRF_SUCCESS:
                ERROR_CHECK(status);
    static void initialize(void)
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_FRIEND, LOG_LEVEL_DBG1, LOG_CALLBACK_DEFAULT);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Server Demo -----\n");
        ERROR_CHECK(app_timer_init());
        hal_leds_init();
    #if BUTTON_BOARD
        ERROR_CHECK(hal_buttons_init(button_event_handler));
        ble_stack_init();
        gap_params_init();
        conn_params_init();
        mesh_init();
    static void start(void)
        rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
        if (!m_device_provisioned)
            static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
            mesh_provisionee_start_params_t prov_start_params =
                .p_static_data    = static_auth_data,
                .prov_sd_ble_opt_set_cb = NULL,
                .prov_complete_cb = provisioning_complete_cb,
                .prov_device_identification_start_cb = device_identification_start_cb,
                .prov_device_identification_stop_cb = NULL,
                .prov_abort_cb = provisioning_aborted_cb,
                .p_device_uri = EX_URI_LS_SERVER
            ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
        mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
        ERROR_CHECK(mesh_stack_start());
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
        initialize();
        start();
        for (;;)
            (void)sd_app_evt_wait();
    **\nrf5_SDK_for_Mesh_v4.1.0_src\examples\light_switch\server\include\nrf_mesh_config_app.hnrf_mesh_config_app.h
    I hope you can reproduce the issue.
    (using 3 x nrf52840-DK / Mesh v4.1.0 / SDK v16.0.0)
  • Hi LouLou,
    I tried your code here but I didn't see the crash. I assume you saw the provisioner crashed ?
    However, I had a look at the provisioner and it seems that the provisioner was not designed to provision the 2nd element of the server.
    If you look at the config_scenarios.h you can find how it's defined. For example the light switch client will be configured as follow:
    #define CONFIG_SCENARIO_LIGHT_SWITCH_CLIENT_EXAMPLE    \
        CONFIG_SCENARIO_COMMON,                            \
        CONFIG_ONOFF_CLIENT,                               \
        NODE_SETUP_DONE
    You can find that there are 2 CONFIG_ONOFF_CLIENT being configured. And on top of each CONFIG_ONOFF_CLIENT  there is a NODE_SETUP_GET_NEXT_ELEMENT . The reason for this is that the config_onoff_client is not located on the first element but located on the 2nd and 3rd element.
    It's a little bit different in your 2 elements server case. Your first server model is located on the 1st element with other model for example the Health model.
    So what I did to modify the configuration scenario is to add CONFIG_ONOFF_SERVER2 as follow:
    #define CONFIG_SCENARIO_LIGHT_SWITCH_SERVER_EXAMPLE    \
        CONFIG_ONOFF_SERVER,                               \
        CONFIG_ONOFF_SERVER2,                               \
        NODE_SETUP_DONE
    #define CONFIG_ONOFF_SERVER2                      \
        NODE_SETUP_GET_NEXT_ELEMENT,                 \
        NODE_SETUP_CONFIG_APPKEY_BIND_ONOFF_SERVER,  \
        NODE_SETUP_CONFIG_PUBLICATION_ONOFF_SERVER,  \
        NODE_SETUP_CONFIG_SUBSCRIPTION_ONOFF_SERVER
    Attached is the config_scenatios.h I used. Note that I haven't modified the subscription address for the 2nd server, so it subscribe to the same group as the 1st server.
    config_scenarios.h
