Testing of Current time service
I am unable to test current time service example.I followed all the steps mentioned to test CTS Example.But, below are the log messages:
Again if I try to reset and try to connect to the device.The log messages are as below:
Please suggest me to rectify the errors and also the right way to test CTS example with 1SDK and mobile application.
Thanks & Regards,
Swathi P.
  • Hello Swathi P,
    Did you follow the Setup and Testing section of the CTS Example Documentation?
    From your error logs, it seems that the Current Time Service is not found on the central device, which causes the peripheral to auto-disconnect.
    You need to make sure that the central is providing this service.
    Which smartphone application and OS are you using?
    If you are using the nRF Connect application, you will need to configure your GATT server to include the Current Time Service, with the Current Time characteristic. The initial value of the characteristic should be C2 07 0B 0F 0D 25 2A 06 FE 08, as detailed in the CTS Example documentation referenced above.
    Please let me know if this resolves your issue,
    Karl
    Thank you for the reply.
    In example provided it has already advertising current time service,I think this means central is provided with service.
    I am using Oppo A71,it is android.
    I have configured Server on the mobile.
    To write the initial value the service is not getting discovered.
    Can you also please let me know,what content the initial value of characteristic "C2 07 0B 0F 0D 25 2A 06 FE 08" is holding?
    Thanks & Regards,
    Swathi P
  • Hello Swanthi P,
     No problem at all, I am happy to help!
    What do you mean by this? The unmodified example will query the central for the current time, using the centrals current time service - you will have to ensure that the central you connect to has this service.
    If you are building your own BLE central application for the smartphone, then you will need to configure the server to include the CTS service.
    I do not personally have experience with developing Android applications, but you may find this github repository useful to have a look at.
    You may see the description for the contents of all standard characteristics in the GATT Specification Supplement. Section 3.45 covers CTS and its contents.
    The value of the initial value for the CTS example from the SDK is as written in the example documentation:
    Saturday the 15th of November 1986, 13:37:42, adjusted for daylight savings time.
    Karl
    What I did was just opened cts example from the folder  and configured gatt from .ncs file on the mobile side and started testing next step then I could see  that the BSP_INDICATE_CONNECTED state is indicated.I am unable to continue the next steps due to previously mentions erorrs.Do I need to modify the example.Then please let me know what modifications I have to do?And here central is nRF Chip,Am I right?
    Thanks & Regards,
    Swathi P
  • Hello Swathi P.
    No, the device that is programmed with the CTS peripheral example is the peripheral, and it will query the central device(your smartphone) for the date and time.
    This is because your smartphone application(central) is not configured to provide the Current Time Service.
    To see this example working I would suggest downloading the nRF Connect smartphone application - just to verify that the example is working as intended on your device.
    So, if you download the nRF Connect smartphone application and go into the "Configure GATT Server" menu, then you should add the Current Time Service, and give it a Current Time characteristic - in which you input the initial value as specified in the CTS example documentation.
    Then, you connect to your nRF device running the CTS example(while having the nRF device connected to a serial monitor), and then you press button 1 to have it read out the CTS value to your serial terminal.
    After having verified this, I would go back to your custom smartphone application.
    Then you will need to setup the service in your custom application just as you configured the GATT server in the nRF Connect smartphone application.
    Karl
