VDD decoupling caps maximum values
I read your white paper nWP-030 about selecting the decouping caps. But I didn't find any explanation why you also specify maximum values for the caps. Especially CVDD effective capacitance 5.5 uF max. would be a little problematic as we are using external FEM from Skyworks that requires quite large currents and a 4u7 decoupling cap is recommended very close it also. If we'll have about 5 uF effective on VDD pins of nRF527840 and ~3 uF in front of FEM,we'll go over the maximum recommended value.
Also, we'll need to deliver power over a long cable and would like to have lots of capacitance on the nRF end of the cable, tens of uF:s, to avoid voltage drop issues on power peaks.
Our powering scheme is meant to be versatile meaning an installer person may use either VDD(+VDDH) or VDDH to supply power. Also internal regulators may be configured on the field either to LDO or SMPS mode depending on installation case and power source.
So could open little more why there are those maximum limitations and in what cases (powering schemes) they need to be respected?
