Using Older library with new products
Hello im an Android developer and we have an app that uses an older library but still works with are older products.
we currently use
implementation 'no.nordicsemi.android:dfu:1.8.1'
Works great with are older products but we currently started a new product with all latest chips and libraries..
so we need to make a BLE update in app.we currently do it for all of our products but for this one i fail at reconnecting to DFU device?
Start load device in DFU then try to reconnect but just hangs..
i noticed our library is really old put if i update that i need to update the entire app and the older devices might not work anymore..
is there a patch i can do for this?
scanning part
private fun getScanDfuDeviceObservable(): Observable<Boolean> {
        addLog("getScanDfuDeviceObservable")
        this._currentConnectionManager.disconnect()
        this._updateStateObservable.onNext(WssBleFirmwareUpdateState.SCANNING_DEVICE_IN_DFU)
        val settings = ScanSettings.Builder()
                .setScanMode(ScanSettings.SCAN_MODE_LOW_LATENCY) // change if needed
                .setCallbackType(ScanSettings.CALLBACK_TYPE_ALL_MATCHES) // change if needed
                .build()
        val observable = Observable.create<Boolean> {
            this._deviceScanObservableEmitter = it
        this.forceDeviceDisconnection()
        this._scanDisposable?.dispose()
        return observable.doOnSubscribe {
            this._scanDisposable =
                    //We wait 3 seconds
                    Observable.just(true).delay(2, TimeUnit.SECONDS).concatMap {
                        this.rxBleClient.scanBleDevices(settings)
                    }.subscribe({
                        //Should we validate macAddress as well?
                        if (it.bleDevice.name.equals(DFU_TARG, true)) {
                            this._scanDisposable = null
                            addLog("getScanDfuDeviceObservable", "Found the device")
                            this._rxBleDeviceDfu = it.bleDevice
                            if (!this._deviceScanObservableEmitter.isDisposed) {
                                this._deviceScanObservableEmitter.onNext(true)
                                this._deviceScanObservableEmitter.onComplete()
                            this._deviceScanObservableEmitter.onError(it)
        }.timeout(5, TimeUnit.SECONDS, Observable.error(TimeoutException()))
                .doOnError {
                .retry(5)
                .take(1)
                .delay(5, TimeUnit.SECONDS) // If we are too fast, the update won't work
                .onErrorResumeNext { it: Throwable ->
                    addLog("getScanDfuDeviceObservable", "Error: ${getThrowableMessage(it)}")
                    if (it is TimeoutException) {
                        Observable.error(WssBleFirmwareUpdateException(WssBleFirmwareUpdateExceptionType.UNABLE_TO_FIND_DFU_DEVICE))
                    } else {
                        Observable.error(WssBleFirmwareUpdateException(WssBleFirmwareUpdateExceptionType.ERROR_SCANNING_FOR_DFU_DEVICE, it))
and then the upload
        if (Build.VERSION.SDK_INT >= Build.VERSION_CODES.O) {
            DfuServiceInitiator.createDfuNotificationChannel(this.context)
        this._updateStateObservable.onNext(WssBleFirmwareUpdateState.INITIALIZING_DFU)
            _dfuObservableEmitter = it
        this is from the forum.gives me the same results
//        var numberOfPackets: Int
//        try {
//            numberOfPackets = 12
//        } catch (e: NumberFormatException) {
//            numberOfPackets = DfuServiceInitiator.DEFAULT_PRN_VALUE
//https://devzone.nordicsemi.com/f/nordic-q-a/50163/android-kotlin-sample-code-for-dfu
//        return observable.delay(6, TimeUnit.SECONDS).doOnSubscribe {
//        val starter = DfuServiceInitiator(this.deviceMacAddress)
//                .setDeviceName(this._deviceName)
//                .setKeepBond(false)
//                .setForceDfu(true)
//                .setPacketsReceiptNotificationsEnabled(false)
//                .setPacketsReceiptNotificationsValue(numberOfPackets)
//                .setUnsafeExperimentalButtonlessServiceInSecureDfuEnabled(true)
//        starter.setZip(this._downloadedFwUri!!)
//        starter.start(this.context.applicationContext, DfuService::class.java)
//                    }.retry(4).take(1)
//                .onErrorResumeNext { it: Throwable ->
//                    this.disposeDfuServiceController()
//                    addLog("getUploadFirmwareObservable", "Error: ${getThrowableMessage(it)}")
//                    Observable.error(WssBleFirmwareUpdateException(WssBleFirmwareUpdateExceptionType.ERROR_UPLOADING_FIRMWARE, it))
            addLog("getUploadFirmwareObservable", "Trying to start the service")
            Timber.d("getDfuObservable - doOnSubscribe - MacAddress ${deviceMacAddress}")
            this._dfuServiceController = DfuServiceInitiator(this.deviceMacAddress)
                    .setForeground(true)
                    .setForceDfu(true)
                    .setKeepBond(false)
        }.retry(4).take(1)
  • Hi Techker,
    Please provide information on:
    - Which SDK and softdevice version you used in your legacy product ?
    - Which SDK and softdevice version you used in your new product ?
    - Please described what exactly you did in your step and at which step the device didn't behave as it should ?
    - If you use nRF Connect/Toolbox app to do DFU can do you DFU for the new product?
  • Hello, im waiting on Hardware team to reply for hardware used
    on my side we have the nordic DFU library no.nordicsemi.android:dfu:1.8.1
    On product i only have info on new hardware  BLE CPU\nRF52833
    i think(no news yet) nRF52832
    for Android issue: we update the firmware of the BLE with our app
    we connect -->set device in dfu-->upload fw then success
    new product we stop at set device in dfu we cannot reconnect to the device, it find the DFUTag but connect reconnect
    with Nrf tool box i dont see were to put device in dfu so i use a tool we did internal to set it to DFU. With the toolbox then we can reconnect and update the BLE fw. both old and new.
    im thinking its our library we are using that is to old?
    Update : new product
               SDK: nRF5_SDK_16.0.0_98a08e2;
               s140_nrf52_7.0.1_softdevice.
    BLE card of Older device:
    -          nRF5_SDK_11.0.0_89a8197;
    -          s132_nrf52_2.0.1_softdevice.
  • "new product we stop at set device in dfu we cannot reconnect to the device, it find the DFUTag but connect reconnect" => I assume you meant "it find the DFUTag but can not reconnect" ?
    In nRFToolbox the app detects if the application has the DFU buttonless service or not and if it has it can automatically switch the application to DFU mode when you start DFU. So it will be one single step to switch the device to DFU mode and start DFU after that.
    Have you tried to test using nRFToolbox to update your new product ? To see if you have the same problem as with your app ?
  • Correct
    i have tried the nRFToolbox  to update works fine.but again the library is updated..
    thats my issue im stuck on 1.8.1
    just seen the soure on GitHub but i only see were to upload to dfu not to set device in dfu?
