I would like to compare GPS antenna sensitivity between DK board and a custom board. What AT command achieves it? Thanks.
Hi!
I believe you can use %XRFTEST to read this information. Take a look and let me know if this is what you were looking for.
Heidi
%XRFTEST=2,1,0,0
This command indicates <param0> is set to 0, which means gain is −105 dBm. Is this standard value? If not, what value should be standard?
Hi, yes -105 dBm is the default gain.
I'm trying to measure the GPS sensitivity, but not sure the value is correct
in at command datasheet, example snr value is positive
%XRFTEST=2,1,0,0 %XRFTEST: 514,-19968 OK # %XRFTEST: <snr>,<antenna_power>
However, when I receive the data, the value is always negative, although A-GPS works properly. Do I miss any setting to get the GPS SNR?
<input at commands>
AT+CFUN=0 AT%XSYSTEMMODE=1,0,1,0 AT%XMAGPIO=1,0,0,1,1,1574,1577 AT%XCOEX0=1,1,1570,1580 AT+CFUN=31 AT%XRFTEST=2,1,0,0
<output>
%XRFTEST: -93,-22680
I'm not sure why you're getting a high SNR value. It could be because of high noise levels, but I will ask about it internally to be sure.
