Zigbee: Usage ZB_ZCL_DECLARE_POWER_CONFIG_ATTRIB_LIST macro with single battery
Hi
I have an question about use ZB_ZCL_DECLARE_POWER_CONFIG_ATTRIB_LIST macro in case when only one battery used.
I'm trying to declare Power Configuration like this
 * Power configuration cluster attributes list
typedef struct zb_zcl_power_config_battery_attrs_s
    zb_uint8_t voltage;
    zb_uint8_t size;
    zb_uint8_t quantity;
    zb_uint8_t rated_voltage;
    zb_uint8_t alarm_mask;
    zb_uint8_t voltage_min_threshold;
} zb_zcl_power_config_battery_attrs_t;
static zb_zcl_power_config_battery_attrs_t m_power_config_attr_list;
ZB_ZCL_POWER_CONFIG_BATTERY_ATTRIB_LIST(
        power_config_attr_list,
 	&m_power_config_attr_list.voltage,
 	&m_power_config_attr_list.size,
 	&m_power_config_attr_list.quantity,
 	&m_power_config_attr_list.rated_voltage,
 	&m_power_config_attr_list.alarm_mask,
 	&m_power_config_attr_list.voltage_min_threshold
But when build this code I get error from preprocessor
macro "ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_POWER_CONFIG_BATTERY_VOLTAGE_ID" requires 2 arguments, but only 1 given
When I've investigated what happens when macro expanded I seen that ZB_ZCL_DECLARE_POWER_CONFIG_ATTRIB_LIST uses
ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_POWER_CONFIG_BATTERY_VOLTAGE_ID, (voltage))
which is expand into
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_POWER_CONFIG_BATTERY_VOLTAGE_ID(data_ptr, bat_num) \
  ZB_ZCL_ATTR_POWER_CONFIG_BATTERY##bat_num##_VOLTAGE_ID,       \
  ZB_ZCL_ATTR_TYPE_U8,                                          \
  ZB_ZCL_ATTR_ACCESS_READ_ONLY,                                 \
  (zb_voidp_t) data_ptr                                         \
So final expression requires battery number but ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_POWER_CONFIG_BATTERY_VOLTAGE_ID, (voltage)) doesnt suppose battery number.
Anymore if even battery number was assigned in any manner there is no identifier in header file for attribute BatteryVoltage for battery with id 0 or 1...
  /** @brief BatteryVoltage attribute, ZCL spec 3.3.2.2.3.1 */
  ZB_ZCL_ATTR_POWER_CONFIG_BATTERY_VOLTAGE_ID               = 0x0020,
  /*! @brief Battery Information 2 attribute set, ZCL spec 3.3.2.2.5 */
  ZB_ZCL_ATTR_POWER_CONFIG_BATTERY2_VOLTAGE_ID = 0x0040,
  /*! @brief Battery Information 3 attribute set, ZCL spec 3.3.2.2.7 */
  ZB_ZCL_ATTR_POWER_CONFIG_BATTERY3_VOLTAGE_ID = 0x0060,
