I am trying to read ADC values for 8 different channel, in order. It's just to test if the ADC and its API.
I successfully receive the ADC binding (it returns 0), and the channel setup also return 0 for all 8 channels.
However, the adc_read() returns -EINVAL (-22). I don't see why. Any help would be nice!
int16_t sampleBuffer[64]; const struct adc_sequence_options options = { 0, NULL, 0 }; const struct adc_sequence sequence = { .options = &options, .channels = BIT(0), .buffer = &sampleBuffer, .buffer_size = sizeof(sampleBuffer), .resolution = 10, .oversampling = 0, .calibrate = false, }; int ret = adc_read(adc_dev, &sequence); printk("Reading ADC %u : %i : %i\n", 0, ret, sampleBuffer[0]);
I have initialized the channels like this:
adc_dev = device_get_binding("ADC_0"); if (!adc_dev) { printk("Failed to bind ADC\n"); } static struct adc_channel_cfg adc_channel_cfg = { .gain = ADC_GAIN_1_6, .reference = ADC_REF_INTERNAL, .acquisition_time = ADC_ACQ_TIME_DEFAULT, .channel_id = 0, }; printk("Setting up ADC channel %u: %i...\n", 0, adc_channel_setup(adc_dev, &adc_channel_cfg));
And my prj.conf contains
CONFIG_ADC=y
