NCS - Very short range even with Coded PHY
We are currently trying the Long Range (Coded PHY) on our advertised message, but we can't see any improvement (range of about 50meters). The range can even be smaller while using Coded PHY, which seems odd.
We are using NCS and Zephyr and not the SoftDevice.
The configuration of the advertiser is
CONFIG_BT=y
CONFIG_BT_SMP=y
CONFIG_BT_SIGNING=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_ATT_PREPARE_COUNT=2
CONFIG_BT_PRIVACY=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_CTLR_TX_PWR_PLUS_8=y
CONFIG_BT_EXT_ADV=y
CONFIG_BT_EXT_ADV_LEGACY_SUPPORT=y
CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
CONFIG_BT_EXT_ADV_MAX_ADV_SET=3
CONFIG_BT_LL_NRFXLIB=y
The advertiser parameters are:
BT_LE_ADV_PARAM(
		BT_LE_ADV_OPT_EXT_ADV | BT_LE_ADV_OPT_CODED,
		BT_GAP_ADV_FAST_INT_MIN_2 * 2,
		BT_GAP_ADV_FAST_INT_MAX_2 * 2, NULL)
The scanner scans the packet with the correct PHY:
[DEVICE]: 54:7c:02:d1:fc:a8 (random),
RSSI -47
Prim: LE Coded,
Secn: LE Coded
What could explain having such small range? What configuration can I set to increase the range?
Regards
Giuliano
