s140_nrf52_7.0.1_softdevice fault @ 0x25B96
Dear Nordic,
Running BLE mesh sensor network with multiple servers and a single client linked to a gateway.
SDK: 16.0.0_98a08e2
SDK Mesh: v4.0.0
nRF52840
The client sporadically faults @ address 0x25B96. The servers are rock solid.
Can you kindly give me a clue as to why it faults at that address.
Thanks!
-John
    Could you give me more details about your issue?
    What have you done so far(step-by-step)?
    Have you tried debugging through your code? Do you get any error codes?
    Have you created your custom application?
  • Hi, and thank you for your response and attention.
    In brief, I've built BLE sensor mesh network based on the components I list above. The server and client implementations are based primarily on the SDK mesh light switch example with a bit of the Thingy52 Mesh example thrown in for the model creation. The servers simply read sensors, package the data into a JSON string, and transmit that string through the mesh to the client. The client receives those JSON strings, does some minor processing, and then transmits them over a UART connection to the gateway. Pretty simple. The issue I have is that the client occasionally faults @ 0x25B96 in its address space. I run emStudio on the client and can tell when it does. Since I don't have the source code, or even a map, for the S140 Softdevice, I have no idea what's going on. I imagine this is a popular topic for the Nordic forum.
    Questions for you:
    1. What strategies can I implement to better handle and recover from softdevice faults? I've seen references to softdevice_fault_handlers in older versions of the SDKs as well as the Thingy52 SDK; are there examples of how to use or implement those? Are there other methods?
    2. In terms of the client receiving asynchronous messages from a large number of servers, does Nordic recommend an architectural approach for handling those incoming messages without violating BLE timing? Are there examples where the incoming messages are buffered and processed in a non time critical way?
    Thanks again for your help and support.
    -John
  • I looked into the address of the softdevice fault. It seems to be a timing issue. The application did not end the timeslot in time, it used more than allocated time before closing the timeslot. Might have used too much time in the callback handler.
    Softdevice faults are asserts that need a reset of the device. So there could be no recovery on the softdevice side, but the app can modify the app_fault hander and save some state data before calling NVIC_SystemReset()
    Regarding your second question, I have forwarded this to our Mesh team. I will come back to you with an update.
    Are you doing UART communication within the client status callback? If yes, most likely that is causing the assertion. User applications should never do any time-consuming task in the mesh callback contexts. Otherwise, they will cause timeslot violations and trigger Softdevice assert.
    Try to move out UART communication from the mesh client callback.
    To handle large number of incoming status message and to transport them over UART, an application should implement some queuing mechanism that can push the messages in some buffer. This buffer can then be transferred byte-by-byte by using UART interrupts. Alternatively, refer to serial example and see how serial bearer is constructed using bare-metal bearer event scheduler.
  • Thank you for your help! I'll give your suggestions a try.
    -John
