How to use GPIOTE_IRQHandler for multiple interrupt request ?
I have an issue in using GPIOTE_IRQHandler.
Let me give an explanation about our implementaiton.
we have nRF controller which is connected to STM32 controller.
Currently the GPIO pin P0.17 on nRF is used as a interrupt pin for NRF for some purpose.
Now i am planning to implement system off mode on nRF side, i am using GPIO P0.20 as nRF interrupt to wake up from the system off mode.
But how i can use GPIO interrupt handler GPIOTE_IRQHandler for the above two interrupt.
Can you please guide me on this and share some examples for the same.
Regards, Anand
  • For your information , For the GPIO pin P0.17 I have configured it has "NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_PORT_Set << GPIOTE_INTENSET_PORT_Pos;"
    How I can configure the P0.20 ?
    what is the difference between Enable interrupt on PORT event and Enable interrupt on IN[3] event ? which one I can use in my case.
    Regards, Anand
  • Hi ,
    I am using nRF 51822 version 3.1(32KB RAM variant) and SDK 6
    Regards, Anand
  • soft device used: s110_nrf51822_7.0.0_softdevice
  • Hi Anand,
    Could you upload your full code ?
    To configure a GPIO pin to work as input interrupt for GPIOTE Port event, besides enabling "NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_PORT_Set << GPIOTE_INTENSET_PORT_Pos;"
    You would also need to configure the PIN_CNF[] register for that pin to set the SENSE level (high or low). You can have a look at chapter 14 in the nRF51 Reference Manual.
    You can use this API: nrf_gpio_cfg_sense_input() to configure a pin as input for SENSE signal.
    So if you have that configured for pin P0.17 you can apply the same for pin P0.20.
    PORT event and IN[] are different in the sense that for PORT event there is only one interrupt for all pins with Sense signal. IN events, you have 4 separated event for each, but you have maximum 4 pins can be used at a time when PORT event can have no limit pins with Sense signal. PORT event consume much less power (1uA) compare to IN event that can comsume upto 1mA. Also IN event can't wake system up from SystemOFF.
  • Hi ,
    I cannot share the full code due to confidentiality. But I can give some hint on that.
    for GPIO pin P0.17 .
    static void function_1(void) {
    	  NRF_GPIO->PIN_CNF[IO1_NRF] = (GPIO_PIN_CNF_SENSE_Low << GPIO_PIN_CNF_SENSE_Pos)
    	                                        | (GPIO_PIN_CNF_DRIVE_S0S1 << GPIO_PIN_CNF_DRIVE_Pos)
    	                                        | (NRF_GPIO_PIN_NOPULL << GPIO_PIN_CNF_PULL_Pos)
    	                                        | (GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos)
    	                                        | (GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos);
    // Set correct IRQ priority and clear any possible pending interrupt. NVIC_SetPriority(GPIOTE_IRQn, SPI1_TWI1_IRQ_PRI); NVIC_ClearPendingIRQ(GPIOTE_IRQn); NVIC_EnableIRQ(GPIOTE_IRQn); NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_PORT_Set << GPIOTE_INTENSET_PORT_Pos; }
    void GPIOTE_IRQHandler(void) {
    // Event causing the interrupt must be cleared if ((NRF_GPIOTE->EVENTS_PORT != 0)) { NRF_GPIOTE->EVENTS_PORT = 0; }
    nrf_gpio_pin_clear(P0.12);
    Now i am using GPIO P0.20 for nRF wake up from system sleep mode.
    How i can configure this pin to wake up from system off mode and how i can handle interrupt handler GPIOTE_IRQHandler. Please give some line of code for the same to test.
    Regards, Anand
1 2
