When I try to compile the gps nrf9160 sample with the SUPL enable, the compilation crash each time.
I get the error "Assertion failed: CONFIG_FP_SOFTABI is not supported".
I have download and unzip the SUPL lib and enable the "CONFIG_SUPL_CLIENT_LIB" in prj.conf.
Including boilerplate (Zephyr base): /home/thomas/Documents/ncs/zephyr/cmake/app/boilerplate.cmake -- Application: /home/thomas/Documents/ncs/nrf/samples/nrf9160/gps -- Zephyr version: 2.3.0-rc1 (/home/thomas/Documents/ncs/zephyr) -- Found Python3: /usr/bin/python3.8 (found suitable exact version "3.8.2") found components: Interpreter -- Board: nrf9160dk_nrf9160ns -- Found toolchain: zephyr (/home/thomas/zephyr-sdk) -- Found west: /home/thomas/.local/bin/west (found suitable version "0.7.2", minimum required is "0.7.1") -- Found dtc: /home/thomas/zephyr-sdk/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6") -- Found BOARD.dts: /home/thomas/Documents/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts nrf9160dk_nrf9160ns.dts.pre.tmp:394.32-398.5: Warning (simple_bus_reg): /soc/cryptocell-sw: missing or empty reg/ranges property nrf9160dk_nrf9160ns.dts.pre.tmp:93.42-105.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000) nrf9160dk_nrf9160ns.dts.pre.tmp:342.19-348.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000) -- Generated zephyr.dts: /home/thomas/Documents/ncs/nrf/samples/nrf9160/gps/build/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /home/thomas/Documents/ncs/nrf/samples/nrf9160/gps/build/zephyr/include/generated/devicetree_unfixed.h Parsing /home/thomas/Documents/ncs/zephyr/Kconfig Loaded configuration '/home/thomas/Documents/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig' Merged configuration '/home/thomas/Documents/ncs/nrf/samples/nrf9160/gps/prj.conf' Configuration saved to '/home/thomas/Documents/ncs/nrf/samples/nrf9160/gps/build/zephyr/.config' Kconfig header saved to '/home/thomas/Documents/ncs/nrf/samples/nrf9160/gps/build/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 9.2.0 -- The CXX compiler identification is GNU 9.2.0 -- The ASM compiler identification is GNU -- Found assembler: /home/thomas/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -- Cache files will be written to: /home/thomas/.cache/zephyr CMake Error at /home/thomas/Documents/ncs/zephyr/cmake/extensions.cmake:1457 (message): Assertion failed: CONFIG_FP_SOFTABI is not supported Call Stack (most recent call first): ../../../ext/lib/bin/supl/CMakeLists.txt:16 (assert) -- Configuring incomplete, errors occurred! See also "/home/thomas/Documents/ncs/nrf/samples/nrf9160/gps/build/CMakeFiles/CMakeOutput.log". See also "/home/thomas/Documents/ncs/nrf/samples/nrf9160/gps/build/CMakeFiles/CMakeError.log".
