App_timer (RTC) measuring Timer periodic interrupts - unexpected results
While working with a bare metal (no SoftDevice or OS) test application to prove code functionalities, I ran out in a weird behaviour that I cannot explain.
I'm using a HW Timer (NRFX_TIMER) to trigger periodically some routines.
Since I wanted to prove the periodicity of the operation, I re-used an RTC that I init and start at the boot to count the ticks difference in a period.
We all know the max resolution of RTC is just 30.5us, so I expected some error, but I've actually found out that the difference I see is around 3ms every 100ms, which is impossible to happen with a working configuration.
I'm sure that this is a problem of how I'm configuring stuff, so I reproduced the problem on a dev kit (PCA10040).
I took as a base the timer peripheral application, which is using a Timer (https://infocenter.nordicsemi.com/topic/sdk_nrf5_v16.0.0/nrf_dev_timer_example.html) to blink LEDs.
I modified it in the below points:
Function timer_led_event_handler:
 * @brief Handler for timer events.
void timer_led_event_handler(nrf_timer_event_t event_type, void* p_context)
    static uint32_t prev = 0;
    uint32_t now = 0;
    uint32_t diff = 0;
    static uint32_t i;
    uint32_t led_to_invert = ((i++) % LEDS_NUMBER);
    switch (event_type)
        case NRF_TIMER_EVENT_COMPARE0:
            now = app_timer_cnt_get();
            diff = app_timer_cnt_diff_compute(now, prev);
            NRF_LOG_INFO("Ticks Elapsed %d", diff);
            NRF_LOG_FLUSH();
            prev = now;
            bsp_board_led_invert(led_to_invert);
            //Do nothing.
Then in the main:
    uint32_t time_ms = 1000; //Time(in miliseconds) between consecutive compare events.
    uint32_t time_ticks;
    uint32_t err_code = NRF_SUCCESS;
    //Configure all leds on board.
    err_code = NRF_LOG_INIT(NULL);
    /* Create logging task if no errors */
    if (NRF_SUCCESS == err_code)
    err_code = nrf_drv_clock_init();
    //while(false == nrfx_clock_lfclk_is_running()){};
    err_code = app_timer_init();
    err_code = app_timer_create(&executionTimer, APP_TIMER_MODE_SINGLE_SHOT, AppTimerTimeout_Cback);
        err_code = app_timer_start(executionTimer, TEST_TIMEOUT, NULL);
    NRF_LOG_INFO("Test started");
    NRF_LOG_FLUSH();
Of course I also included in the project all the dependencies needed to compile and modified sdk_config on purpose.
If I set time_ms to 100ms, I see as output:
00> <info> app: Ticks Elapsed 3230
00>
00>
00>
00> <info> app: Ticks Elapsed 3229
00>
00>
00>
00>
So elapsed time is around 98.5ms.
With 500ms:
00> <info> app: Ticks Elapsed 16151
00>
00> <info> app: Ticks Elapsed 16148
00>
00> <info> app: Ticks Elapsed 16154
00>
00> <info> app: Ticks Elapsed 16156
00>
00> <info> app: Ticks Elapsed 16155
00>
00> <info> app: Ticks Elapsed 16153
00>
00> <info> app: Ticks Elapsed 16152
00>
00> <info> app: Ticks Elapsed 16159
00>
00> <info> app: Ticks Elapsed 16160
So elapsed time is around 493ms.
This is continuing linearly, since when time_ms is 1000 the elapsed time detected with RTC is around 986ms.
It may be something very stupid, but may I ask if someone understands where the problem may be?
Information about the system:
  • running on nRF52 Dev Kit (PCA10040)
  • RTC frequency is 32768 Hz
  • CLOCK_CONFIG_LF_SRC/NRFX_CLOCK_CONFIG_LF_SRC is set to XTAL
  • NRFX_TIMER_DEFAULT_CONFIG_FREQUENCY is 16MHZ, with NRFX_TIMER_DEFAULT_CONFIG_BIT_WIDTH of 16bit
  • All interrupts are using priority 6 (default) - since this is the only thing happening in the system I doubt that this is affecting anything
Please let me know if you need any more information to investigate this fully.
Thanks!
D
  • The 16MHz Timer may be using the RC high-frequency clock instead of the 32MHz crystal, as it is set separately to the 32kHz crystal; try this:
      // Start HFCLK from crystal oscillator, this will give the Timer higher accuracy
      while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
    There is an nrf library call to do this as well, though I forget offhand what that is.
  • Hi hmolesworth,
    thanks!
    OK, this is something I already tried originally and it didn't work.
    As a matter of fact, I then tried to run the same application on another dev kit (still PCA10040)...and with your suggestion things magically start to work as expected! I now have to prove this on my application...
    Anyway I now start thinking that it could be a problem of this particular board - is there anyone that could suggest why I could see something like this? At pure HW level, can the XTAL malfunction is such a subtle way?
    This would be a good lesson learned to detect similar problems in the future.
    D
  • I effectively proved that also on my application things run correctly on another PCA10040.
    I just would like to understand from the official support what could be the root cause of such an issue in order to avoid the same in the final product.
    Best,
    D
  • Would be interesting to know the value of NRF_CLOCK->LFCLKSTAT register here when "failing" and "working" here. A 3% error on an external XTAL seems very odd, maybe loaded xtal very wrong? Or using a xtal that is out of specifications?
