Cap sense using single pin per sensor
  I'm using the nRF52840 dev kit for a BLE-based application.  I need to implement a capacitive touch button for detecting button presses and releases (no sliding).  I only have 1 analog input pin connected to my sensor.  I've looked at the nrf52-capsense-example project here, but it is based on SDK-12.
  Is this still the recommended method to follow when only a single pin is connected to the touch sensor?
  Are there any issues using this method along with BLE (SoftDevice S140)?
  Is there any way to use the csense library in this configuration?
  Thanks...
Brian
  • Hi Brian,
    No. A very important point is that regardless of which SW implementation you use, this will only work as a demo, and is not suitable for production due to nRF52832 erratum 84. This erratum does not exist for other nRF52 series devices, but that is not because the issue is fixed, but because the feature was removed from the product specification.
    It should be possible to make this work with a SoftDevice as measurements are done using PPI and SW is not time-critical. (I have not tested it, though.)
    The example you refer to was written before the Capacitive Sensor library was available, and I recomend you refer to that instead. That also supports using two pints to measure the discharge time of the sensor cap. You should note that the library is not particularly advanced though, and may not function well in a practical product which is used in an environment with varying air humidity, etc. So you should consider the SDK code as proof of concept more than anything else.
    Einar
  • Hi Einar,
      Thanks for the quick response!
      I have looked at the capacitive sensor library in SDK16.  From what I could tell, my sensor needs to be hooked up to 2 pins to implement a capacitive sensor button.  My sensor is only connected to one pin (AIN3).  Is it possible to use the newer Capacitive Sensor library with a sensor only connected to one pin?
      Also, does the erratum 84 only apply to the nRF52832?  I'm using the nRF52840.
    Thanks...
    Brian
  • Hi Brian,
    Yes, the capsense driver supports both methods. Please see this page for details.
    In practice, erratum 84 applies to all nrF52 devices. Formally, it does not, since the nRF52840 does not have this support at all if you refer to the product specification. And that is because it uses the same implementation as nRF52832, which is non-functional (as you can see from erratum 84).
    Einar
  • Yes, you can use a single pin for capacitive sensing. The trick is to first use the pin to charge (or discharge, depending on whether the capacitive sensor is between pin and Gnd or pin and Vcc). Then turn the pin around to an analogue input and measure the decaying falling (rising) voltage which will be at a rate controlled by capacitance and resistance. Something like this, in this case assuming a capacitor connected to Gnd and Vcc via a charging resistor:
    #define CAPSENSE_PIN 5
      // Number of samples depends on how accurate the rising CR curve should be measured
      int16_t CapCharge[50];
      // Get ready to discharge the cap
      nrf_gpio_pin_clear(CAPSENSE_PIN);
      // Discharge cap
      nrf_gpio_cfg(CAPSENSE_PIN, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0S1, NRF_GPIO_PIN_NOSENSE);
      // Wait long enough for cap to discharge
      nrf_delay_us(20);
      // Turn around to analogue input to read the charging voltage
      nrf_gpio_cfg(CAPSENSE_PIN, NRF_GPIO_PIN_DIR_INPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_S0S1, NRF_GPIO_PIN_NOSENSE);
      for (uint32_t i = 0; i < sizeof(CapCharge) / sizeof(CapCharge[0]); i++)
        CapCharge[i] = SAADC_Measure(CAPSENSE_PIN);
        // Experiment with number of samples and delay between each, depends on CFR
        nrf_delay_us(50);
    You can use SAADC pull-up (160k-ish) as a charging resistor if you want to save a component and use only a capacitor; accuracy in that case  is low but often good enough discrimination of movement. Values of C and R depend on sensitivity and response time; C is not a real capacitor in most cases, just a foil contact in the case of a touch sensor. Now that is what I'd call a zero component capacitive sensor, no C or R.
    I should add that you can just compare the voltage with a comparator instead of the SAADC, or even rely on the ill-defined logic high input level on an i/o pin in input mode feeding a timer if simple presence/absense is required, and not an more precise measurement. SAADC or comparator should be in ratiometric mode, if charging voltage is Vcc then reference should also be Vcc and not a fixed reference.
  • I work with Brian at Simplexity and we were able to get the capacitive touch button working with a second GPIO that stimulates the pad through a 1M resistor.  This leverages the existing csense driver.  I've attached source code here, in case anyone else wants to leverage it.
     * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    // When we update the SDK, we'll need to add these changes to
    // get the cap sensor code working since the embedded current
    // source is broken.  TODO: trim down this complex code and
    // put it in the main code branch so we don't have to update
    // vendor-supplied files
    #define SIMPLEXITY_CHANGES
    #include "sdk_common.h"
    #if NRF_MODULE_ENABLED(NRF_DRV_CSENSE)
    #include "nrf_drv_csense.h"
    #include "nrf_peripherals.h"
    #include "nrf_gpio.h"
    #include "app_error.h"
    #include "nrf_assert.h"
    #include "string.h"
    #include <stdio.h>
    #if defined(__CORTEX_M) && (__CORTEX_M < 4)
    #ifndef ARM_MATH_CM0PLUS
    #define ARM_MATH_CM0PLUS
    /*lint -save -e689 */
    #include "arm_math.h"
    /*lint -restore */
    #if USE_COMP
    #include "nrf_drv_comp.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #ifdef SIMPLEXITY_CHANGES
    #include "nrfx_gpiote.h"
    #endif //USE_COMP
    #if USE_COMP == 0
    #ifdef ADC_PRESENT
    #include "nrfx_adc.h"
     * @defgroup adc_defines ADC defines to count input voltage.
    #define ADC_RES_10BIT           1024
    #define ADC_INPUT_PRESCALER     3
    #define ADC_REF_VBG_VOLTAGE     1.2
    /* ADC channel used to call conversion. */
    static nrfx_adc_channel_t adc_channel = NRFX_ADC_DEFAULT_CHANNEL(NRF_ADC_CONFIG_INPUT_0);
    #elif defined(SAADC_PRESENT)
    #include "nrf_drv_saadc.h"
     * @defgroup saadc_defines SAADC defines to count input voltage.
    #define SAADC_RES_10BIT           1024
    #define SAADC_INPUT_PRESCALER     3
    #define SAADC_REF_VBG_VOLTAGE     0.6
    /* SAADC channel used to call conversion. */
    static nrf_saadc_channel_config_t saadc_channel = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    #endif //ADC_PRESENT
    #endif //USE_COMP
    #if USE_COMP
    /* Number of channels required by PPI. */
    #define PPI_REQUIRED_CHANNELS 5
    #else
    #define PPI_REQUIRED_CHANNELS 3
    /* Array of PPI channels. */
    static nrf_ppi_channel_t m_ppi_channels[PPI_REQUIRED_CHANNELS];
     * @defgroup timer_instances Timer instances.
    static const nrf_drv_timer_t m_timer0 = NRF_DRV_TIMER_INSTANCE(TIMER0_FOR_CSENSE);
    static const nrf_drv_timer_t m_timer1 = NRF_DRV_TIMER_INSTANCE(TIMER1_FOR_CSENSE);
    static nrfx_gpiote_out_config_t m_gpiote = NRFX_GPIOTE_CONFIG_OUT_TASK_HIGH;
    #endif //USE_COMP
    /* Configuration of the capacitive sensor module. */
    typedef struct
        volatile nrfx_drv_state_t       module_state;                       /**< State of the module. */
        nrf_drv_csense_event_handler_t  event_handler;                      /**< Event handler for capacitor sensor events. */
        uint16_t                        analog_values[MAX_ANALOG_INPUTS];   /**< Array containing analog values measured on the corresponding COMP/ADC channel. */
        volatile bool                   busy;                               /**< Indicates state of module - busy if there are ongoing conversions. */
        volatile uint8_t                cur_chann_idx;                      /**< Current channel to be read if enabled. */
        volatile uint8_t                adc_channels_input_mask;            /**< Enabled channels. */
        uint8_t                         output_pin;                         /**< Pin to generate signal charging capacitors. */
        uint8_t                         channels_to_read;                   /**< Mask of channels remaining to be read in the current measurement. */
        volatile bool                   timers_powered_on;                  /**< Flag to indicate if timers were already started. */
    }csense_t;
    static csense_t m_csense;
     * @brief Function for determining the next analog channel to be read.
    __STATIC_INLINE void calculate_next_channel(void)
        m_csense.cur_chann_idx = 31 - __CLZ(m_csense.channels_to_read);
     * @brief Function for handling conversion values.
     * @param[in] val                Value received from ADC or COMP.
    static void conversion_handler(uint16_t val)
        nrf_drv_csense_evt_t event_struct;
    #if USE_COMP == 0
        nrf_gpio_pin_set(m_csense.output_pin);
    #endif //USE_COMP
        m_csense.analog_values[m_csense.cur_chann_idx] = val;
        event_struct.read_value = val;
        event_struct.analog_channel = m_csense.cur_chann_idx;
        m_csense.channels_to_read &= ~(1UL<<m_csense.cur_chann_idx);
        // decide if there will be more conversions
        if (m_csense.channels_to_read == 0)
            m_csense.busy = false;
    #if USE_COMP == 0 && defined(SAADC_PRESENT)
            nrf_saadc_disable();
        m_csense.event_handler(&event_struct);
        if (m_csense.channels_to_read > 0)     // Start new conversion.
            ret_code_t err_code;
            calculate_next_channel();
            err_code = nrf_drv_csense_sample();
            if (err_code != NRF_SUCCESS)
                return;
    #if USE_COMP
     * @brief Timer0 interrupt handler.
     * @param[in] event_type Timer event.
     * @param[in] p_context  General purpose parameter set during initialization of
     *                       the timer. This parameter can be used to pass
     *                       additional information to the handler function, for
     *                       example, the timer ID.
    static void counter_compare_handler(nrf_timer_event_t event_type, void* p_context)
        if (event_type == NRF_TIMER_EVENT_COMPARE0)
            uint16_t val =  nrf_drv_timer_capture_get(&m_timer1, NRF_TIMER_CC_CHANNEL1);
            nrf_drv_timer_pause(&m_timer1);
            nrf_drv_timer_clear(&m_timer1);
            /* Handle finished measurement. */
            conversion_handler(val);
     * @brief Dummy handler.
    static void dummy_handler(nrf_timer_event_t event_type, void* p_context){}
     * @brief Function for initializing timers.
     * @retval NRF_ERROR_INTERNAL            If there were error initializing timers.
     * @retval NRF_SUCCESS                   If timers were initialized successfully.
    static ret_code_t timer_init(void)
        //set first timer in timer mode to get period of relaxation oscillator
        nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
        timer_config.mode = NRF_TIMER_MODE_TIMER;
        err_code = nrf_drv_timer_init(&m_timer1, &timer_config, dummy_handler);
            return NRF_ERROR_INTERNAL;
        //set second timer in counter mode and generate event on tenth period
        timer_config.mode = NRF_TIMER_MODE_COUNTER;
        err_code = nrf_drv_timer_init(&m_timer0, &timer_config, counter_compare_handler);
        nrf_drv_timer_extended_compare(&m_timer0, NRF_TIMER_CC_CHANNEL0, MEASUREMENT_PERIOD, (nrf_timer_short_mask_t)(NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK | NRF_TIMER_SHORT_COMPARE0_STOP_MASK), true);
        return NRF_SUCCESS;
     * @brief Function for initializing and enabling PPI channels.
     * @retval NRF_ERROR_INTERNAL            If there were error initializing or enabling PPI channels.
     * @retval NRF_SUCCESS                   If PPI channels were initialized and enabled successfully.
    static ret_code_t ppi_init(void)
        uint8_t i;
        if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_MODULE_ALREADY_INITIALIZED))
        for (i = 0; i < PPI_REQUIRED_CHANNELS ; i++)
            err_code = nrf_drv_ppi_channel_alloc(&m_ppi_channels[i]);
            if (NRF_SUCCESS != err_code)
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channels[0], nrf_drv_comp_event_address_get(NRF_COMP_EVENT_CROSS), nrf_drv_timer_task_address_get(&m_timer0, NRF_TIMER_TASK_COUNT));
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channels[1], nrf_drv_timer_event_address_get(&m_timer0, NRF_TIMER_EVENT_COMPARE0), nrf_drv_timer_task_address_get(&m_timer1, NRF_TIMER_TASK_CAPTURE1));
        err_code = nrf_drv_ppi_channel_fork_assign(m_ppi_channels[1], nrf_drv_comp_task_address_get(NRF_COMP_TASK_STOP));
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channels[2], nrf_drv_comp_event_address_get(NRF_COMP_EVENT_READY), nrf_drv_timer_task_address_get(&m_timer0, NRF_TIMER_TASK_CLEAR));
        err_code = nrf_drv_ppi_channel_fork_assign(m_ppi_channels[2], nrf_drv_timer_task_address_get(&m_timer1, NRF_TIMER_TASK_CLEAR));
        // Simplexity added: To compensate for the failing current source,
        // we use the UP and DOWN events from the COMP block to reset/set a GPIO
        // in the GPIOTE block
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channels[3], nrf_drv_comp_event_address_get(NRF_COMP_EVENT_UP), nrfx_gpiote_clr_task_addr_get(NRF_CSENSE_OUTPUT_PIN));
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channels[4], nrf_drv_comp_event_address_get(NRF_COMP_EVENT_DOWN), nrfx_gpiote_set_task_addr_get(NRF_CSENSE_OUTPUT_PIN));
            err_code = nrf_drv_ppi_channel_enable(m_ppi_channels[i]);
        return NRF_SUCCESS;
     * @brief Dummy handler for COMP events.
     * @param[in] event         COMP event.
    static void comp_event_handler(nrf_comp_event_t event){}
     * @brief Function for initializing COMP module in relaxation oscillator mode.
     * @note The frequency of the oscillator depends on threshold voltages, current source and capacitance of pad and can be calculated as f_OSC = I_SOURCE / (2C·(VUP-VDOWN) ).
     * @retval NRF_ERROR_INTERNAL                If there were error while initializing COMP driver.
     * @retval NRF_SUCCESS                       If the COMP driver initialization was successful.
    static ret_code_t comp_init(void)
        nrf_drv_comp_config_t m_comp_config = NRF_DRV_COMP_DEFAULT_CONFIG(NRF_COMP_INPUT_0);
        /* Workaround for Errata 12 "COMP: Reference ladder is not correctly calibrated" found at the Errata document
           for your device located at https://infocenter.nordicsemi.com/ */
        *(volatile uint32_t *)0x40013540 = (*(volatile uint32_t *)0x10000324 & 0x00001F00) >> 8;
        // since the current source isn't working, we use thresholds relative to external reference
        // This is simply 1/3 and 2/3 of VDD respectively
        m_comp_config.threshold.th_down = NRFX_VOLTAGE_THRESHOLD_TO_INT(1.0,3.0);
        m_comp_config.threshold.th_up   = NRFX_VOLTAGE_THRESHOLD_TO_INT(2.0,3.0);
    #else
        m_comp_config.isource = NRF_COMP_ISOURCE_Ien10uA;
        err_code = nrf_drv_comp_init(&m_comp_config, comp_event_handler);
        return NRF_SUCCESS;
     * @brief Function for initializing GPIOTE module in relaxation oscillator mode.
    static ret_code_t gpiote_init(void)
        // initialize basic block
        err_code = nrfx_gpiote_init();
        // configure task for low to high if OUT[] called, SET[] and CLR[] work as usual
        err_code = nrfx_gpiote_out_init(NRF_CSENSE_OUTPUT_PIN, &m_gpiote);
        nrfx_gpiote_out_task_enable(NRF_CSENSE_OUTPUT_PIN);
        return NRF_SUCCESS;
    #endif //SIMPLEXITY_CHANGES
    #endif //USE_COMP
    #if USE_COMP == 0
    #ifdef ADC_PRESENT
     * @brief ADC handler.
     * @param[in] p_event                Pointer to analog-to-digital converter driver event.
    void adc_handler(nrfx_adc_evt_t const * p_event)
        uint16_t val;
        val = (uint16_t)(p_event->data.sample.sample *
                         ADC_REF_VBG_VOLTAGE * 1000 *
                         ADC_INPUT_PRESCALER / ADC_RES_10BIT);
     * @brief Function for initializing ADC.
    static ret_code_t adc_init(void)
        adc_channel.config.config.input = NRF_ADC_CONFIG_SCALING_INPUT_ONE_THIRD;
        nrfx_adc_config_t const adc_config = NRFX_ADC_DEFAULT_CONFIG;
        err_code = nrfx_adc_init(&adc_config, adc_handler);
        return NRF_SUCCESS;
     * @brief SAADC handler.
    void saadc_handler(nrf_drv_saadc_evt_t const * p_event)
        uint16_t val;
        (void)nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
        val = (uint16_t)(*p_event->data.done.p_buffer *
                          SAADC_REF_VBG_VOLTAGE * 1000 *
                          SAADC_INPUT_PRESCALER / SAADC_RES_10BIT);
     * @brief Function for initializing SAADC.
    static ret_code_t saadc_init(void)
        static nrf_saadc_value_t saadc_value;
        saadc_channel.gain = NRF_SAADC_GAIN1_3;
       err_code = nrf_drv_saadc_init(NULL, saadc_handler);
        err_code = nrf_drv_saadc_channel_init(0, &saadc_channel);
        err_code = nrf_drv_saadc_buffer_convert(&saadc_value, 1);
        return NRF_SUCCESS;
    #endif //USE_COMP
    ret_code_t nrf_drv_csense_init(nrf_drv_csense_config_t const * p_config, nrf_drv_csense_event_handler_t event_handler)
        ASSERT(m_csense.module_state == NRFX_DRV_STATE_UNINITIALIZED);
        ASSERT(p_config->output_pin <= NUMBER_OF_PINS);
        if (p_config == NULL)
            return NRF_ERROR_INVALID_PARAM;
        if (event_handler == NULL)
    #if USE_COMP == 0
        m_csense.output_pin = p_config->output_pin;
        nrf_gpio_cfg_output(m_csense.output_pin);
    #endif //COMP_PRESENT
        m_csense.event_handler = event_handler;
    #if USE_COMP
        err_code = gpiote_init();
            return err_code;
        err_code = comp_init();
            return err_code;
        err_code = timer_init();
            return err_code;
        err_code = ppi_init();
            return err_code;
    #else
    #ifdef ADC_PRESENT
        err_code = adc_init();
            return err_code;
        err_code = saadc_init();
            return err_code;
    #endif //USE_COMP
        m_csense.module_state = NRFX_DRV_STATE_INITIALIZED;
        return NRF_SUCCESS;
    ret_code_t nrf_drv_csense_uninit(void)
        ASSERT(m_csense.module_state != NRFX_DRV_STATE_UNINITIALIZED);
        nrf_drv_csense_channels_disable(0xFF);
    #if USE_COMP
        uint8_t i;
        nrf_drv_timer_uninit(&m_timer0);
        nrf_drv_timer_uninit(&m_timer1);
        nrf_drv_comp_uninit();
        for (i =0; i < 3; i++)
            err_code = nrf_drv_ppi_channel_free(m_ppi_channels[i]);
                return err_code;
        err_code = nrf_drv_ppi_uninit();
            return err_code;
    #else
    #ifdef ADC_PRESENT
        nrfx_adc_uninit();
        nrf_drv_saadc_uninit();
    #endif //USE_COMP
        m_csense.module_state = NRFX_DRV_STATE_UNINITIALIZED;
        memset((void*)&m_csense, 0, sizeof(m_csense));
        return NRF_SUCCESS;
    void nrf_drv_csense_channels_enable(uint8_t channels_mask)
        m_csense.busy = true;
        m_csense.module_state = NRFX_DRV_STATE_POWERED_ON;
        m_csense.adc_channels_input_mask |= channels_mask;
    void nrf_drv_csense_channels_disable(uint8_t channels_mask)
        ASSERT(m_csense.module_state == NRFX_DRV_STATE_POWERED_ON);
        m_csense.adc_channels_input_mask &= ~channels_mask;
        if (m_csense.adc_channels_input_mask == 0)
    uint16_t nrf_drv_csense_channel_read(uint8_t csense_channel)
        return m_csense.analog_values[csense_channel];
    ret_code_t nrf_drv_csense_sample(void)
        if (m_csense.adc_channels_input_mask != 0)
                nrf_saadc_enable();
                if (nrf_drv_csense_is_busy() == true)
                    return NRF_ERROR_BUSY;
                m_csense.channels_to_read = m_csense.adc_channels_input_mask;
    #if USE_COMP
            if (!m_csense.timers_powered_on)
                nrf_drv_timer_enable(&m_timer0);
                nrf_drv_timer_enable(&m_timer1);
                m_csense.timers_powered_on = true;
                nrf_drv_timer_resume(&m_timer0);
                nrf_drv_timer_resume(&m_timer1);
            nrf_drv_comp_pin_select((nrf_comp_input_t)m_csense.cur_chann_idx);
            // we need the COMP events to be enabled when starting
            nrf_drv_comp_start(NRFX_COMP_EVT_EN_CROSS_MASK |
                               NRFX_COMP_EVT_EN_UP_MASK |
                               NRFX_COMP_EVT_EN_DOWN_MASK,
                               0);
            // toggle GPIO high to kick circuit into operation
            // Note, that since we have GPIO tasks enabled for this pin, setting the
            // raw output register is ignored, we need to use the task
            if(nrfx_comp_sample()) // currently high, so set low
                nrfx_gpiote_clr_task_trigger(NRF_CSENSE_OUTPUT_PIN);
            else // currently low, so set high
                nrfx_gpiote_set_task_trigger(NRF_CSENSE_OUTPUT_PIN);
    #else
            nrf_drv_comp_start(0, 0);
    #else
    #ifdef ADC_PRESENT
            adc_channel.config.config.ain = (nrf_adc_config_input_t)(1<<m_csense.cur_chann_idx);
            nrf_gpio_pin_clear(m_csense.output_pin);
            err_code = nrfx_adc_sample_convert(&adc_channel, NULL);
            saadc_channel.pin_p = (nrf_saadc_input_t)(m_csense.cur_chann_idx + 1);
            nrf_saadc_channel_input_set(0, saadc_channel.pin_p, NRF_SAADC_INPUT_DISABLED);
            err_code = nrf_drv_saadc_sample();
                return err_code;
    #endif //USE_COMP
        return NRF_SUCCESS;
    bool nrf_drv_csense_is_busy(void)
        return m_csense.busy;
    #endif //NRF_MODULE_ENABLED(NRF_DRV_CSENSE)
