Dear All,
I am trying to add a custom service on the ble_template_app that I have managed to run successfully on the nRF52820.
I have successfully created the custom service I need and I have been able to compile and run my code on an nRF52840.
Unfortunately, I have been unable to do the same for the nRF52820. The code will not even compile, geiving me this error:
C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.52c/gcc/arm-none-eabi/bin/ld: error: .rodata is too large to fit in FLASH memory segment 1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.52c/gcc/arm-none-eabi/bin/ld: error: .data is too large to fit in FLASH memory segment
I am assuming that there is an issue with the FLASH memory size, but I am not sure how to fix it.
In my project I have this line:
linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x40000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x8000;FLASH_START=0x27000;FLASH_SIZE=0x19000;RAM_START=0x20002ae8;RAM_SIZE=0x5518"
I took this line from the example for the UART application that can be found here.
I am also curious to understand how exactly I need to modify the flash and ram size in case I want to add more services, like the
