Errata 136
I have some questions regarding errata 136.
I understand that the workaround is to ignore reset reason bits which are not RESETPIN.
However, I don't understand how ~POWER_RESETREAS_RESETPIN_Msk can help us, as the operation makes pin reset bit 0 and the other bits become 1. Isn't that the opposite from what we want?
In addition, I had some troubles with implementing watchdog, as POWER_RESETREAS_DOG_Msk was always true, until I removed errata 126 fix. Is it possible?
Thanks!
    The RESETREAS register is cleared by writing '1' to the bit, as shown in the PS:
    https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52832.ps.v1.1/power.html?cp=4_2_0_17_8_2#register.RESETREAS
    This will ensure that the RESETPIN_Msk is still held when the application checks the specific bit after the errata workaround has executed.
    Are you clearing the RESETREAS by writing '1' to the source bit?
    Kind regards,.
    Håkon
  • So the operation  if (NRF_POWER->RESETREAS & POWER_RESETREAS_RESETPIN_Msk) checks if the bit is cleared? And if so, it makes that bit 0 and the others cleared (1)?
    I'm using sd_power_reset_reason_get to get the bitmap, and then operating & POWER_RESETREAS_DOG_Msk on the reslt, in order to identify watchdog reset. If watchdog was identified, I'm using sd_power_reset_reason_clr(POWER_RESETREAS_DOG_Msk) to clear the bit.
    It checks if the condition has been met.
    A read of the register will not alter the contents. Only a write to it will do that.
    The errata 136 states that if the reset pin is used, other sources might also be set at the same time. The sequence will ensure that these other resetreas sources are cleared and only the resetpin is set in the register.
    If you see that RESETREAS_DOG_Msk is set in this register, it is likely because the reset reason is due to a watchdog timeout. Try clearing the whole register, as it is accumulative register, meaning it keeps the values. During a debug session, it is quite common to see several reset sources, especially if you are pressing the button from time-to-time, and doing debug-reset from an IDE.
    Håkon
  • So the operation & with the reset pin mask will actually tell us if the bit is cleared? That's the idea?
    And if so - we know that it has been used?
    No, it will clear all other sources if pin reset is set in RESETREAS register. As the errata explains, other bits can be set when RESETREAS_RESETPIN is set.
