nRF52840 DK - real TIFS inaccurate with Long Range
I am using the TIFS register of the NRF RADIO to define the interframe spacing timing.
(Done with the following line)
NRF_RADIO->SHORTS |= RADIO_SHORTS_DISABLED_TXEN_Msk; // or NRF_RADIO->SHORTS |= RADIO_SHORTS_DISABLED_RXEN_Msk;
NRF_RADIO->TIFS     = 150;
During a 1Mbit or 2Mbit connection, the real TIFS observed on the sniffer is quite accurate (~150.25us observed).
However, in LE Coded PHY with different Coded PHY, the real TIFS is inaccurate (TX: S=2, RX: S=8): TIFS observed 161.375us  and (TX: S=8, RX: S=2): TIFS observed 146.5us
I am using a nRF52840 DK (PCA10056 v1.0.0).
Do you have any idea of what may impact this timing and how could I avoid this behavior ?
Thank you.
    Can you check that the HFCLK with crystal oscillator(HFXO) is running ?
  • Thank you for your answer !
    I used the following lines to start the HFXO.
        while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
    Then when the connection is established with LE Coded PHY, I checked the NRF_CLOCK->HFCLKRUN (=0x00000001) and NRF_CLOCK->HFCLKSTAT (=0x00010001)  registers and they indicates that the HFCLK is running with the HFXO 64 MHz crystal oscillator.
    Is there something more that I should check ?
    Thank you.
  • Good point, I didn't write this part in the code snippet but the shortcuts configuration is done before the TIFS configuration :
        NRF_RADIO->SHORTS           = RADIO_SHORTS_READY_START_Msk |
                                      RADIO_SHORTS_END_DISABLE_Msk;
        //or NRF_RADIO->SHORTS |= RADIO_SHORTS_DISABLED_RXEN_Msk; depending on the next operation chosen
    Without those shortcuts the TIFS doesn't work with the 1Mbps or 2Mbps neither.
    In my case, the timing are always good, except with different LE Coded Coding Sheme.
     Ok. I have asked the team internally if they have seen this issue before. I will get back to you with a reply when I know more.
  • We have seen similar behavior for asymmetric links previously. It’s still under investigation. For the asymmetric use-case, I suggest trying to update/modify the TIFS register with a different value, so that you observe 150 us.
  • Thanks a lot for the update.
    Indeed that's the work-around we are using for now, but it doesn't work when we don't know the remote device coding sheme (RX with S=2 or S=8 impacts the TIFS value).
    Please let me know, once you have more information about it, thank you.
  • You should be able to tell what TX mode the peer is using by monitoring the PDUSTAT CISTAT field for incoming packets. (Note: peer is allowed to dynamically switch between S8/S2 without notification, so T_IFS calculation would have to be checked upon every received packet. You set the TIFS register to a specific value when preparing the Tx packet.)
    Another option is to enable an interrupt on EVENTS_RATEBOOST. Write a TIFS value for S=2 to the TIFS register when starting the radio for BLE LR. If EVENTS_RATEBOOST (this happens during the reception of a frame in S=8!) is generated the software should update the TIFS register to the value for S=8.
    Update of the TIFS register takes immediate effect. It is recommended to update as early as possible.
