nRF52840 DK - real TIFS inaccurate with Long Range
I am using the TIFS register of the NRF RADIO to define the interframe spacing timing.
(Done with the following line)
NRF_RADIO->SHORTS |= RADIO_SHORTS_DISABLED_TXEN_Msk; // or NRF_RADIO->SHORTS |= RADIO_SHORTS_DISABLED_RXEN_Msk;
NRF_RADIO->TIFS     = 150;
During a 1Mbit or 2Mbit connection, the real TIFS observed on the sniffer is quite accurate (~150.25us observed).
However, in LE Coded PHY with different Coded PHY, the real TIFS is inaccurate (TX: S=2, RX: S=8): TIFS observed 161.375us  and (TX: S=8, RX: S=2): TIFS observed 146.5us
I am using a nRF52840 DK (PCA10056 v1.0.0).
Do you have any idea of what may impact this timing and how could I avoid this behavior ?
Thank you.
  • We have seen similar behavior for asymmetric links previously. It’s still under investigation. For the asymmetric use-case, I suggest trying to update/modify the TIFS register with a different value, so that you observe 150 us.
  • Thanks a lot for the update.
    Indeed that's the work-around we are using for now, but it doesn't work when we don't know the remote device coding sheme (RX with S=2 or S=8 impacts the TIFS value).
    Please let me know, once you have more information about it, thank you.
  • You should be able to tell what TX mode the peer is using by monitoring the PDUSTAT CISTAT field for incoming packets. (Note: peer is allowed to dynamically switch between S8/S2 without notification, so T_IFS calculation would have to be checked upon every received packet. You set the TIFS register to a specific value when preparing the Tx packet.)
    Another option is to enable an interrupt on EVENTS_RATEBOOST. Write a TIFS value for S=2 to the TIFS register when starting the radio for BLE LR. If EVENTS_RATEBOOST (this happens during the reception of a frame in S=8!) is generated the software should update the TIFS register to the value for S=8.
    Update of the TIFS register takes immediate effect. It is recommended to update as early as possible.
