After upgrading from 1.3.0-rc1 to 1.3.0 I get the error ModuleNotFoundError: No module named 'yaml'
I'm trying to upgrade nRF Connect SDK from 1.3.0-rc1 to 1.3.0 because I need one of the bugfixes to keep developing.
I'm on macOS catalina and I've used the Toolchain Manager.
Now I get this annoying and apparently well known error message when opening projects:
I can go back out and "Open IDE" for version 1.3.0-rc1 in Toolchain Manager and then it works.
I have fixed my python executable as described in Bjørn's comment at the bottom of this thread.
https://devzone.nordicsemi.com/f/nordic-q-a/62172/thingy91-is-useless-without-working-samples-and-sdk/255301#255301
Jan Erik Foss
BikeFinder
  • I understand. I find it odd that anyone would seriously want to use the command line to build a project when there is a perfectly good ide.
    The problem you have with OS X is that it ships with python and you cannot override it easily. Since Seeger has a specific setting to provide the python interpreter it seems odd that this would then be ignored later. Why provide the setting?
    I would set up a definition for the python executable in the shell environment and document that as a requirement for command line compilation. Anyone using command line stuff will be very happy to add that to their shell environment.
    Another option is simply don’t set the python path in the make file if it is already set. You could even spit out a debug line to say you found an existing value and did not override it.
  • I ran into another issue that was not resolved by editing the python.cmake. I was unable to change the project configuration because it was also using the wrong version of Python. I did a little more digging.
    The fundamental problem here is that if you execute Segger Embedded Studio from spotlight or finder it does NOT use the path environment variable defined for whatever shell you use in Terminal. OS X Catalina on the Mac now uses zsh so when using terminal you get the path as defined in ~/.zprofile. OS X comes with an installation of Python in the /usr/bin folder but this is actually Python3.8 whereas following the instructions in the Nordic getting started guide results in a home brew installation of Python3.9. Python3.9 is found first on the path when executing from a zsh shell but when executing from a finder or spotlight launched GUI app the first location on the path is /usr/bin and this results in Python3.8 being found by the find_package command in cmake.
    There appear to be two ways to solve this problem.
    1. If you do not want ot mess with the path settings for all GUI applications you can simply launch Segger Embedded Studio from a terminal shell. e.g.  Open Terminal and enter (including the double quotes) "/Applications/arm_segger_embedded_studio_v520b_macos_x64_nordic/SEGGER Embedded Studio for ARM 5.20b.app/Contents/MacOS/emStudio"
    2. You can set the GUI path by executing this command from a terminal session.
    sudo launchctl config user path /usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin.
    This will place the home brew managed executables ahead of the built in path and cause GUI launched applications to pick up the correct version of Python. You will need to reboot to get this to take effect.
  • Sorry but I did both and I keep having this issue. I'm switching to windows now but would be grate if this could be fixed. :)
  • If you open a terminal window and type python3 --version what version does it report? For a successful install of the Nordic tools this appears to need to be Python 3.9.0 or higher.
