How can I get Thingy91 to work with the LwM2M sample?
Hi, I have been trying to get Thingy91 to work with the LwM2M sample found here. It works fine with the nrf9160 devkit and it seems to work for ~1min or so with the thingy91 also since I can see it in the Leshan server for a short while. Why it disconnects I do not know. So if you could share some tips what I need to make sure in my build environment that this would work on thingy (secure boot is set properly already). And then I was looking at the sensor code and it seems that there is no easy way to configure the Thingy91 sensors, but the LwM2M sample code is sending a hardcoded value or using the die sensor which is not present in nrf9160, if there was some instructions on how to enable at least the temp sensor that would be awesome.
