LwM2M Carrier Library Questions
  1. From my understanding, I should integrate the LwM2M Carrier Library connection as the first step in the boot process and once I have received the LWM2M_CARRIER_EVENT_READY event, I can move along with my application similar to how we are waiting for the cloud_ready_to_connect semaphore in the Asset Tracker example. If I am in an area with no LTE coverage, what will happen in this case? How long will I have to wait for the Carrier Library to give the semaphore if there is no coverage? When should I run the portion of my application that does not need LTE Connection, e.g. talking to other devices over UART.
  2. I need to use a different APN in my application. When should I initialize that? Should I put the modem in flight mode (AT+CFUN=4) after getting the LWM2M_CARRIER_EVENT_READY event and then reconfigure the APN and then turn the modem on again? If I do that, do I need to reconnect to the lwm2m operator network?
  3. If I am planning to use an MVNO SIM in my product (such as iBasis), do I need to include the LwM2M Carrier Library? Let's say I am deploying my product in the US and it is connecting to either Verizon or AT&T through the MVNO, will the carrier library be able to connect directly to the carrier.
Akash Patel
  • Hi Akash,
     Most of the abstractions in lwm2m can be found in the lwm2m_os.c file, which in this case will call upon the lte_lc library:
    https://github.com/nrfconnect/sdk-nrf/blob/v1.3.0/lib/bin/lwm2m_carrier/os/lwm2m_os.c#L626-L641
     So, it depends on how you have configured that to run (see CONFIG_LTE_NETWORK_TIMEOUT).
    Given that your own logic is running in an already running thread, it should run as expected.
     You can set the APN using this kconfig:
    https://github.com/nrfconnect/sdk-nrf/blob/master/lib/lte_link_control/Kconfig#L97
    Then lte_lc library will set it on boot up.
     Roaming SIMs will not access a carrier lwm2m server, so then its not needed.
    Håkon
  •  Roaming SIMs will not access a carrier lwm2m server, so then its not needed.
    What will happen if I have the lwm2m carrier library as part of my project and I use an MVNO sim? If it cannot connect to the carrier, then will it hang or timeout? If timeout, after how long?
    Nothing should happen, as it does not block anything in the application. the event _READY from LWM2M will never come, and the application shall run as normal.
    Håkon
