SPI does not work on nRF52832
Hi
I put the MBN52832 (nRF52832) on my WSM-BL241-ADA-008DK to test the SPI (see the user guide here).
The sample "peripheral/spi" from SDK ver. 16.0 is used for the test. . However, the pin settings have been changed(sdk_config.h has not been changed).
The following is the source code.
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "Nordic"
static uint8_t       m_tx_buf[] = TEST_STRING;           /**< TX buffer. */
static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];    /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    if (m_rx_buf[0] != 0)
        NRF_LOG_INFO(" Received:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
//    spi_config.ss_pin   = SPI_SS_PIN;
//    spi_config.miso_pin = SPI_MISO_PIN;
//    spi_config.mosi_pin = SPI_MOSI_PIN;
//    spi_config.sck_pin  = SPI_SCK_PIN;
    spi_config.ss_pin   = 29;
    spi_config.miso_pin = 2;
    spi_config.mosi_pin = 3;
    spi_config.sck_pin  = 4;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
    NRF_LOG_INFO("SPI example started.");
    while (1)
        // Reset rx buffer and transfer done flag
        memset(m_rx_buf, 0, m_length);
        spi_xfer_done = false;
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
        while (!spi_xfer_done)
            __WFE();
        NRF_LOG_FLUSH();
        bsp_board_led_invert(BSP_BOARD_LED_0);
        nrf_delay_ms(200);
I ran it now and checked it on the oscilloscope, but it doesn't seem to respond to all the pins.
Is something missing in the settings?
Please help me out.
