I'm attempting to using pa_lna_setup(), specifically the softdevice function sd_ble_opt_set to enable/disable the radio and an external amplifier. My application is a custom beacon that advertises on an occasional basis (multiple seconds). It toggles between broadcasting 1M PHY and coded PHY. It also inserts the battery voltage into the advertising data. Presently, the advertising cycle is triggered on a timer interrupt that has the ADC get VDD, inserts the voltage into the advertising data, and then kicks off one advertising event. It works as expected without trying to use the pa_lna functionality. When attempting to use pa_lna, my timer no longer works and there is no data being advertised, though for some reason the bsp_indication_set(BSP_INDICATE_ADVERTISING) LED is still flashing.
