NRF_LOG_INFO not displaying anything on RTT Viewer, nrf52840 custom board.
Hi All,
I am working on a custom board using the BMD-340 from RIGADO, and I am hoping to be able to see all the logs on the RTT viewer.
setup -> SDK 16.00, J-ling programmer using SWD interface, keil u vision 5, J-link RTT viewer V6.70.
I was expecting to see all the NRF_LOG_INFO , ERRORS, WARNINGS etc specially because I want to know the memory RAM requirements by new services an characteristics that I will be adding to the BLE stack. However up until now it does not work, even though my application is running and doing what it is expect to do, I started by using the ble_app_hrs as a template and have included my own service and features.
Relevant definitions in my sdk_config file :
1- #define NRF_LOG_BACKEND_RTT_ENABLED 1
2- #define NRF_LOG_ENABLED 1
3- #define NRF_LOG_DEFAULT_LEVEL 3
4-#define NRF_LOG_DEFERRED 1
While my application is running should I see all the logs on the RTT viewer ? or should I start a debug session ?
Am I missing any definitions in order to get this working ?
Any help on this would be highly appreciated ?
Thanks
  • 1- #define NRF_LOG_BACKEND_RTT_ENABLED 1
    check NRF_LOG_BACKEND_UART_ENABLED - that must be 0 (zero).
    You will see all enabled logs. Log level 3 disables NRF_LOG_DEBUG() messages.
    If you run jlinkgdbserver concurrently, use the "Existing session" feature in RTT viewer. I like to use it this way because flashing new stuff is much faster just using the debugger.
    Try setting this to zero. Will loose more messages that way, but does not rely on the main() loop running correctly.
  • it is indeed disabled.
    #define NRF_LOG_BACKEND_UART_ENABLED 0.
    And yet no Logs are printed to the J link RTT viewer.
    Tried this and I started getting the corresponding NRF_LOG_INFO.
     Having this cleared WORKED  #define NRF_LOG_DEFERRED 0.
    Thank you very much for your Help.
