high speed settings for nrf52832
I have project with nrf52832.
every second, i want send 11k byte data from nrf52832 to android app, but it is loss data. (i used phone ble 4.2  loss about 1-2% packet)
(every 16ms, i will send buffer 176 byte to andoid app)
I have read some documents to optimize it but it still fails
Any advice for me?
    Could you post the code you use to transmit the data? Data loss usually means that there is a problem with the way it's implemented in the app code. Also, keep in mind that not all phones will support >11kB/s so the application needs to take that into account.
    I've made an example to test notification throughput that you may be interested in trying to see if you can get >11kB/s with your phone. You can find it here: https://devzone.nordicsemi.com/f/nordic-q-a/61560/stopping-the-nrf52832-uart-sample (note the correction in the accepted answer)
  • #include <stdint.h>
    #include <string.h>
    #include "nrf_gpio.h"
    #include "module_ble.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_nus.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "bsp_btn_ble.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "module_ads1298_config.h"
    #include "app_timer.h"
    extern uint32_t ui32_start_test_signal;
    extern uint32_t ui32_send_data_to_ble;
    extern uint32_t ui32_status_ble;
    extern uint8_t ui8_gain_signal;
    int32_t ui32_handshake_count = 50000;
    uint32_t ui32_counter_x = 0;
    uint32_t ui32_counter_y = 0;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    //pin power latch
    void init_pin_led_ble()
      nrf_gpio_cfg_output(PIN_LED_BLE);
    void turn_on_led_ble()
      nrf_gpio_pin_write(PIN_LED_BLE,0);
    void turn_off_led_ble()
      nrf_gpio_pin_write(PIN_LED_BLE,1);
    void toggle_led_ble()
      nrf_gpio_pin_toggle(PIN_LED_BLE);
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
     void timers_init(void)
     *          the device. It also sets the permissions and appearance.
     void gap_params_init(void)
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    void process_command_from_app(char type_control)
      switch(type_control)
      case CMD_START_TEST_SIGNAL:
        ui8_gain_signal = CHNSET_GAIN_6 | CHNSET_MUXN_TEST_SIGNAL;
        ui32_start_test_signal = true;
        ui32_handshake_count = 10000;
       case CMD_START_ECG_SIGNAL:
        ui8_gain_signal = CHNSET_GAIN_2;;
        case 'x':     // Incorrect Packet Received by PC/Mobile
          ui32_handshake_count++;
          ui32_counter_x++;
        case 'y':     // Correct Packet Received by PC/Mobile
          ui32_counter_y++;
      case CMD_STOP_SIGNAL:
        ui32_send_data_to_ble = false;
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            //uint32_t err_code;
            process_command_from_app(p_evt->params.rx_data.p_data[0]);
           // for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
    //            do
    //                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
    //                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
    //                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
    //                    APP_ERROR_CHECK(err_code);
    //            } while (err_code == NRF_ERROR_BUSY);
    //        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
    //            while (app_uart_put('\n') == NRF_ERROR_BUSY);
     void services_init(void)
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
     void conn_params_init(void)
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                //sleep_mode_enter();
              NRF_LOG_INFO("BLE_ADV_EVT_IDLE...");
                err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                ui32_status_ble = true;
                turn_off_led_ble();
                NRF_LOG_INFO("Disconnected");
                ui32_status_ble = false;
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_1MBPS,
                    .tx_phys = BLE_GAP_PHY_1MBPS,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
     void ble_stack_init(void)
         nrf_sdh_enable_request();
        //APP_ERROR_CHECK(err_code);
        uint32_t ram_start = 0;
        nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
        // Enable BLE stack.
        nrf_sdh_ble_enable(&ram_start);
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        ret_code_t err_code;
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
        err_code = nrf_ble_gatt_data_length_set(&m_gatt, BLE_CONN_HANDLE_INVALID, NRF_SDH_BLE_GAP_DATA_LENGTH);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     void advertising_init(void)
        int8_t tx_power_level = 4;
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        //init.advdata.p_tx_power_level = &tx_power_level;
        //sd_ble_gap_tx_power_set(tx_power_level);
        //sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, 4);
        //init.config.ble_adv_secondary_phy = BLE_GAP_PHY_AUTO;
        //sd_ble_gap_tx_power_set(0);
        //sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle,4);
     void advertising_start(void)
    void send_data_ble(uint8_t* data, uint16_t* len)
      ble_nus_data_send(&m_nus,data,len, m_conn_handle);
    #include "nrf.h"
    #define PIN_LED_BLE                     16
    #define CMD_START_TEST_SIGNAL                     'A'
    #define CMD_START_ECG_SIGNAL                      'T'
    #define CMD_STOP_SIGNAL                           'S'
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "ECG_TEST"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(8, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(12, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    void init_pin_led_ble();
    void turn_on_led_ble();
    void turn_off_led_ble();
    void toggle_led_ble();
    void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name);
    void timers_init(void);
    void gap_params_init(void);
    static void nrf_qwr_error_handler(uint32_t nrf_error);
    void process_command_from_app(char type_control);
    static void nus_data_handler(ble_nus_evt_t * p_evt);
    void services_init(void);
    static void on_conn_params_evt(ble_conn_params_evt_t * p_evt);
    static void conn_params_error_handler(uint32_t nrf_error);
    void conn_params_init(void);
    static void sleep_mode_enter(void);
    static void on_adv_evt(ble_adv_evt_t ble_adv_evt);
    static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context);
    void ble_stack_init(void);
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt);
    void gatt_init(void);
    void bsp_event_handler(bsp_event_t event);
     void advertising_init(void);
     void advertising_start(void);
     void send_data_ble(uint8_t* data, uint16_t* len);
    sourcode here
    every 16ms, i send 176 byte.
    i tesed with samsung a50s and samsung note 8 have support ble 5.0
    it is still loss packet
  • It looks like you are ignoring the return value from ble_nus_data_send() so you won't know if the notification packet got added to the Softdevice's output queue or not. The data will only be sent if the function returns NRF_SUCCESS.
    API documentation for reference:sd_ble_gatts_hvx
    i must resend data when function ble_nus_data_send not return NRF_SUCCESS?
  • Yes, correct. You need to resend the data if it didn't return NRF_SUCCESS
