DFU error: OPERATION NOT PERMITTED
Hello, I'm using softdevice 6.0, SDK 15.0, secure bootloader buttonless S132. On the phone with Android I'm using: nRF Toolbox 2.9.0 with DFU Library version 1.10.3.
I start the firmware update with firmware A and stop before it finishes by closing the app DFU. If I retry the update with the same firmware A, the app DFU resumes from the percentage from where it was interrupted, but the app DFU returns the error "OPERATION NOT PERMITTED and disconnects (I also attach the log). At this point I make an update with a frimware B. The update restarts from the beginning and, if I do not interrupt the app, it is successful.
What is the solution to this criticism in Android?
Best regards
nRF Connect, 2020-06-22
SE-007-E000027 (FE:10:CD:01:21:29)
D	10:13:42.482	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
V	10:13:42.969	Connecting to FE:10:CD:01:21:29...
D	10:13:42.969	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE)
D	10:13:43.104	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	10:13:43.104	Connected to FE:10:CD:01:21:29
V	10:13:43.106	Requesting new MTU...
D	10:13:43.106	gatt.requestMtu(517)
I	10:13:43.765	MTU changed to: 247
V	10:13:43.792	Discovering services...
D	10:13:43.793	gatt.discoverServices()
D	10:13:43.868	[Callback] Services discovered with status: 0
I	10:13:43.868	Services discovered
V	10:13:43.913	Generic Access (0x1800)
- Device Name [R W] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
- Central Address Resolution [R] (0x2AA6)
Generic Attribute (0x1801)
Unknown Service (7f04f3f0-b665-11e3-a5e2-0800200c9a66)
- Unknown Characteristic [W WNR] (92b403f0-b665-11e3-a5e2-0800200c9a66)
- Unknown Characteristic [N R] (7d32c0f0-bef5-11e3-b1b6-0800200c9a66)
   Client Characteristic Configuration (0x2902)
- Unknown Characteristic [N R] (2d417c80-b667-11e3-a5e2-0800200c9a66)
- Unknown Characteristic [N R] (f9f84152-b667-11e3-a5e2-0800200c9a66)
Secure DFU Service (0xFE59)
- Buttonless DFU [I W] (8ec90003-f315-4f60-9fb8-838830daea50)
Battery Service (0x180F)
- Battery Level [N R] (0x2A19)
Device Information (0x180A)
- Manufacturer Name String [R] (0x2A29)
- Model Number String [R] (0x2A24)
- Serial Number String [R] (0x2A25)
- Hardware Revision String [R] (0x2A27)
- Firmware Revision String [R] (0x2A26)
- Software Revision String [R] (0x2A28)
D	10:13:43.913	gatt.setCharacteristicNotification(7d32c0f0-bef5-11e3-b1b6-0800200c9a66, true)
D	10:13:43.915	gatt.setCharacteristicNotification(2d417c80-b667-11e3-a5e2-0800200c9a66, true)
D	10:13:43.918	gatt.setCharacteristicNotification(f9f84152-b667-11e3-a5e2-0800200c9a66, true)
D	10:13:43.922	gatt.setCharacteristicNotification(00002a19-0000-1000-8000-00805f9b34fb, true)
D	10:14:05.248	[Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
E	10:14:05.259	Error 8 (0x8): GATT CONN TIMEOUT
I	10:14:05.260	Disconnected
D	10:14:05.375	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
D	10:19:28.806	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
D	10:19:28.806	gatt.close()
D	10:19:28.844	wait(200)
V	10:19:29.047	Connecting to FE:10:CD:01:21:29...
D	10:19:29.047	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE)
D	10:19:29.185	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	10:19:29.185	Connected to FE:10:CD:01:21:29
V	10:19:29.187	Requesting new MTU...
D	10:19:29.187	gatt.requestMtu(517)
I	10:19:29.515	MTU changed to: 247
V	10:19:29.542	Discovering services...
D	10:19:29.542	gatt.discoverServices()
D	10:19:29.700	[Callback] Services discovered with status: 0
I	10:19:29.700	Services discovered
V	10:19:29.746	Generic Access (0x1800)
D	10:19:29.746	gatt.setCharacteristicNotification(7d32c0f0-bef5-11e3-b1b6-0800200c9a66, true)
D	10:19:29.749	gatt.setCharacteristicNotification(2d417c80-b667-11e3-a5e2-0800200c9a66, true)
D	10:19:29.751	gatt.setCharacteristicNotification(f9f84152-b667-11e3-a5e2-0800200c9a66, true)
D	10:19:29.756	gatt.setCharacteristicNotification(00002a19-0000-1000-8000-00805f9b34fb, true)
D	10:19:51.867	[Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
E	10:19:51.868	Error 8 (0x8): GATT CONN TIMEOUT
I	10:19:51.868	Disconnected
D	10:19:51.922	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
