Thread network commissionning (with Bluetooth)
Hello
I would like to commission my Thread network but my Thread network is isolated (I have no wifi) but I have bluetooth which works in parallel to the Thread network (app based on the "ble_thread_dyn_mtd_coap_cli_pca10056_s140" example ).
Would it be possible to use bluetooth to commission the Thread network (add a new device to the Thread network)? If yes, what do you advise me to be able to do that?
Thank you
    As far as I know there are no standardized methods of providing the provision keys for openthread. Are you able to close the network, only allowing certain devices that contain the correct keys to join?
    What I am really asking is whether this is the question, or whether the question is if we have any suggestions on how to transfer the keys over BLE.
    Edvin
  • Hi Edvin,
    I just wanted to know if there was a good way to commission a new device to join an existing Thread network using Bluetooth.
    For example, I was thinking of doing one of the following:
    - connect in Bluetooth to the new device (to add to the Thread network) and send it all the credentials of the Thread network
    - or, connect in Bluetooth to a device in the Thread network and send it a command to activate the "commissioner" by providing it with the uid64 of the device to be added and its pskd. Then, I will connect in Bluetooth to the new device to activate the "joiner" to start the commissioning.
    So the question is: is this a good way to do it?
    I started by testing the second solution but I can't start the "Commissioner".
    My application is based on the example "ble_thread_dyn_mtd_coap_cli_pca10056_s140" but when I run the function "otCommissionerStart (...)" it returns "OT_ERROR_ALREADY" (Commissioner is already started).
    So I ignore this error and I run "otCommissionerAddJoiner (...)" but it returns "OT_ERROR_INVALID_STATE" (The commissioner is not active).
    Do you have any idea on how to fix this problem?
    Thank you
    A new reply from our Thread team:
    The commissioner API exposes on-mesh commissioner API.
    Note that the on-mesh commissioner feature is optional in Thread, and does not need to be used. The normal/regular commissioning
    is done using external commissioner through e.g. mobile phone: https://openthread.io/guides/border-router/external-commissioning
    I do see two problems here.
    The first one is incorrect API usage, and the second is the bug in OpenThread described here: https://github.com/openthread/openthread/pull/4788
    which is already fixed on master.
    First of all, otCommissionerStart can be called only when device has already attached
    to the network. Calling this API before will return error code as in your case.
    For example, you can act on state change handler for example:
    switch (otThreadGetDeviceRole(p_context))
     case OT_DEVICE_ROLE_CHILD:
     case OT_DEVICE_ROLE_ROUTER:
     case OT_DEVICE_ROLE_LEADER:
         otError error = otCommissionerStart(thread_ot_instance_get(), commissioner_state_callback, commissioner_joiner_callback, NULL);
         ASSERT(error == OT_ERROR_NONE);
    Only when state of the commissioner changes to `OT_COMMISSIONER_STATE_ACTIVE` you can call
    When it comes to the side-effect of using the OpenThread libraries as is in SDK 4.1.0, as explained
    in the GitHub's Pull Request. Basically if Commissioner changes the state without user intervention
    e.g. from Active to Disabled (due to some network issue e.g. Keep Alives are lost) without calling
    the OpenThread API it may not be possible to turn on/off the commissioner again.
    This should not be a blocker with the current OpenThread libraries.
    The `OT_ERROR_ALREADY` error is a little bit misleading since it is returned from Border Agent module, not the Commissioner one:
    https://github.com/openthread/openthread/blob/c6a258e3a5bd90aa26d8245c435c0ae5797027f4/src/core/api/commissioner_api.cpp#L54
    Anyway, I would suggest to rebuild OpenThread libraries with the following commit which includes the fix: 2f618bd4a72501a2f31e23d50a4f388b9a8c6b9b
    Try this.
    BR,
    Edvin
    Thank you very much for your help and all this information.
    I use the on-mesh commissioner because I don't have a boarder router connected to the internet, as your example shows: I only have a smartphone that can connect to the device via Bluetooth.
    Now I am no longer getting errors from these functions but still have problem in certain scenarios.
    For example, if I do the simple procedure like this, it works (with the "thread_cli_ftd_uart_pca10056" exemple):
    But if the 2 devices were on a different network before launching the commissioning, the commissioning fails:
      or
    Do you have any idea why commissioning fails when the 2 devices are not on the same network?
    Thank you
  • I am not sure I follow. Are they supposed to be commissioning when they are not on the same network?
  • In fact, I want to commission one of the devices (which is on another network) to join an existing network.
  • So how did you tell the node that it should accept a new network?
    I guess one approach could be something like this:
    https://github.com/openthread/openthread/blob/master/src/cli/README_DATASET.md#form-network
    But please let me know how you did it. Is there some way for me to reproduce this using only DKs?
