Can you please provide the SPI pins for nrf52840 chip.
or else should i connect any GPIO signal?
Any GPIO can be used, but you should avoid the pins marked with "Standard drive, low frequency I/O only" in the Pin assignments specifications.
Jørgen
Thank you..!
Should i use below signals as SPI signal .
P0.17 -- CS
P0.26 -- SCK
P0.20 -- DIO0/SI
P0.04 -- DIO1
P0.22 -- DIO2
P0.06 -- DIO3
Kindly suggest ASAP.
Yes, those are not marked as "Standard drive, low frequency I/O only". Are you planning to use QSPI?
Yes. As of now am not planning to use QSPI.. if i use is there any issues?
No issue, I was just asking since you only mention SPI is the original post, while the pin-connections indicate QSPI usage.
