NRF_CRYPTO_CELL port to 52833
I am trying to port the examples/ble_central/ble_app_hrs_c project from the 52840/pca10056/s140 to a 52833/pca10100/s140  project.
Having trouble in the port from the nrf52840.h to the nrf52833.h - it seems there is a lot missing.
Before I started changing things I thought it productive to at least ask the questions.
Questions:
           is there an updated nrf53833.h with all the crypto information added.
           has someone already updated the ble_app_hrs_c project to work on the 52833
Thanks
  • Got it building ble_app_hrs_c_gcc_nrf52.ld
    nrf52833.h
    Makefile will not upload as it continues to get an error - but started with an 840 makefile and worked thru the 840 stuff to the 833 .s/.c files and that way the crypto libs were present
    did a nrfjprog --recover
    in the armgcc directory did the make flash_softdevice
    But when I debug the program always hangs at
    file cc310_backend_rng.c line 159
       err_code = CRYS_RndInit(&p_ctx->crys_rnd_state, p_work_buffer);
    with no error or timeout.
    If you have any information on what I should try or a solution to my problem I would appreciate it.
    Thank you,
    This is expected. The CrytpoCell peripheral is not present on the nRF52833, so there is no point in trying to use it.
    You have to use a SW crypto backend, but you do not need to make any significant changes, as the nrf_crypto library provides a unified API. The only thing you should need to do is to disable the CC310 backed in sdk_config.h by setting NRF_CRYPTO_BACKEND_CC310_ENABLED to 0, and enable the Oberon backend by setting NRF_CRYPTO_BACKEND_OBERON_ENABLED to 1, and also the NRF_CRYPTO_BACKEND_NRF_HW_RNG_ENABLED to 1. You can compare with the sdk_config.h of the pca10040 project to see how this should be done, and they should be identical with regard to crypto configuration.
