I have a NRF52840 DK, with a pca63511 power profiler kit purchased just a few days ago from Mouser. I am trying to use the power profiler kit with version 2.3.1 of the power profiler app installed from nRF Connect v3.4.1 on MacOS 10.15.2. I'm connected to the DK via USB directly to my computer. Or more precisely through a USB-C to USB 3 adapter since I have a Macbook Pro 16in with no regular USB ports.
I cut the SB_40 (VDD) and SB_41 (VDD_hV) traces on the DK and was able to measure 400nA sleep current through the two VDD pins next to the trace using the another low current measuring device called the CurrentRanger. But I would like to use the power profiler kit.
Switch positions are as follows:
- DK: nRF power source = VDD
- DK: Power = ON
- DK: SW6 = Default
- Power Profiler: Power Select = DK
I have the blinky example flashed, but nothing happens when I connect the USB port because the power trace has been cut. When I attach the power profiler the LEDs start flashing in sequence as expected.
What is not working is that no LED lights up on the power profiler board. I can connect to the serial port in the power profiler app on my computer, but no readings are displayed. When I click "start" the buffer progress bar shows 113.8s and does not fill up as time passes. The avg,max,charge values are stuck at zero.
I can click Power ON or Power OFF but it doesn't seem to have any effect. The DK LEDs continue to flash regardless.
What am I doing wrong? Thanks!
