I'm using a NRF52832 with SoftDevice s132 v7.0. I also have freertos. I have an app which advertises and scans. The app is set up to trigger a break point on assertions as well - by using app_error_weak.c
I noticed that if I put a breakpoint in the scan event handler, once i single step i go into the assert handler. However, without the breakpoint the program doesn't assert. I know this because the scan event handler is passing messages to an rtos task. I can breakpoint in the rtos task and verify that I received a message. However, in the rtos task, once I step the debugger I go into a assert there too. What could be causing this?
note:
I stepped through app_error_weak.c's app_error_fault_handler and found that the id was NRF_FAULT_ID_SD_ASSERT, so it appears that the softdevice is throwing an assert when the program halts on a breakpoint.
