Problem with connection to my service.
#include <string.h>
#include "ble_srv_common.h"
#include "nrf_gpio.h"
#include "boards.h"
#include "nrf_log.h"
#include "sdk_common.h"
#include "ble_aph_service.h"
/**@brief Function for handling the Connect event.
 * @param[in]   p_cus       Custom Service structure.
 * @param[in]   p_ble_evt   Event received from the BLE stack.
static void
on_connect (ble_cus_t * p_cus, ble_evt_t const *p_ble_evt)
    p_cus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    ble_cus_evt_t evt;
    evt.evt_type = BLE_CUS_EVT_CONNECTED;
    p_cus->evt_handler (p_cus, &evt);
/**@brief Function for handling the Disconnect event.
static void
on_disconnect (ble_cus_t * p_cus, ble_evt_t const *p_ble_evt)
    UNUSED_PARAMETER (p_ble_evt);
    p_cus->conn_handle = BLE_CONN_HANDLE_INVALID;
    ble_cus_evt_t evt;
    evt.evt_type = BLE_CUS_EVT_DISCONNECTED;
/**@brief Function for handling the Write event.
static void
on_write (ble_cus_t * p_cus, ble_evt_t const *p_ble_evt)
    ble_gatts_evt_write_t const *p_evt_write =
        &p_ble_evt->evt.gatts_evt.params.write;
    // Custom Value Characteristic Written to.
    if (p_evt_write->handle == p_cus->rx_handles.value_handle) {
//        nrf_gpio_pin_toggle(LED_4);
           if(*p_evt_write->data == 0x01)
           //            nrf_gpio_pin_clear(20);
           else if(*p_evt_write->data == 0x02)
           //            nrf_gpio_pin_set(20);
           //Do nothing
    // Check if the Custom value CCCD is written to and that the value is the appropriate length, i.e 5 bytes.
    if ((p_evt_write->handle ==
            p_cus->tx_handles.cccd_handle)
            &&(p_evt_write->
               len == 5)
        // CCCD written, call application event handler
        if (p_cus->evt_handler != NULL) {
            ble_cus_evt_t evt;
            if (ble_srv_is_notification_enabled
                    (p_evt_write->data)) {
                evt.evt_type = BLE_CUS_EVT_NOTIFICATION_ENABLED;
            } else {
                evt.evt_type =
                    BLE_CUS_EVT_NOTIFICATION_DISABLED;
            // Call the application event handler.
void
ble_cus_on_ble_evt (ble_evt_t const *p_ble_evt, void *p_context)
    ble_cus_t * p_cus = (ble_cus_t *) p_context;
    NRF_LOG_INFO ("BLE event received. Event type = %d\r\n",
                  p_ble_evt->header.evt_id);
    if (p_cus == NULL || p_ble_evt == NULL) {
        return;
    switch (p_ble_evt->header.evt_id) {
    case BLE_GAP_EVT_CONNECTED:
        on_connect (p_cus, p_ble_evt);
        on_disconnect (p_cus, p_ble_evt);
    case BLE_GATTS_EVT_WRITE:
        on_write (p_cus, p_ble_evt);
    /* Handling this event is not necessary
            case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
                NRF_LOG_INFO("EXCHANGE_MTU_REQUEST event received.\r\n");
        // No implementation needed.
/**@brief Function for adding the TX characteristic.
 * @param[in]   p_cus        custom Service structure.
 * @param[in]   p_cus_init   Information needed to initialize the service.
 * @return      NRF_SUCCESS on success, otherwise an error code.
static ret_code_t  addTXChar (ble_cus_t * p_cus,
                              const ble_cus_init_t * p_cus_init)
    ret_code_t  err_code;
    ble_gatts_char_md_t char_md;
    ble_gatts_attr_t attr_char_value;
    ble_uuid_t ble_uuid;
    ble_gatts_attr_md_t attr_md;
    memset (&char_md, 0, sizeof (char_md));
    char_md.char_props.read = 0;
    char_md.char_props.write = 1;
    char_md.char_props.notify = 0;
    char_md.char_props.write_wo_resp = 1;
    char_md.p_char_user_desc = NULL;
    char_md.p_char_pf = NULL;
    char_md.p_user_desc_md = NULL;
    char_md.p_cccd_md = NULL;
    char_md.p_sccd_md = NULL;
    memset (&attr_md, 0, sizeof (attr_md));
    attr_md.read_perm = p_cus_init->custom_value_char_attr_md.read_perm;
    attr_md.write_perm = p_cus_init->custom_value_char_attr_md.write_perm;
    attr_md.vloc = BLE_GATTS_VLOC_STACK;
    attr_md.rd_auth = 1;
    attr_md.wr_auth = 1;
    attr_md.vlen = 0;
    ble_uuid.type = p_cus->uuid_type;
    ble_uuid.uuid = APH_TX_UUID;	//will add the 16-bit UUID
    memset (&attr_char_value, 0, sizeof (attr_char_value));
    attr_char_value.p_uuid = &ble_uuid;
    attr_char_value.p_attr_md = &attr_md;
    attr_char_value.init_len = (sizeof (uint8_t)*5);
    attr_char_value.init_offs = 0;
    attr_char_value.max_len = (sizeof (uint8_t)*5);
    uint8_t v1[5]            = {0x1B,0x01,0x00,0x00,0x00};
    attr_char_value.p_value     = v1;
    err_code =
        sd_ble_gatts_characteristic_add (p_cus->service_handle, &char_md,
                                         &attr_char_value,
                                         &p_cus->tx_handles);
    if (err_code != NRF_SUCCESS) {
        return err_code;
    return NRF_SUCCESS;
/**@brief Function for adding the RX Characteristic.
static ret_code_t  addRXChar (ble_cus_t * p_cus,
    char_md.char_props.read = 1;
    char_md.char_props.write = 0;
    char_md.char_props.notify = 1;
    char_md.char_props.write_wo_resp = 0;
    attr_md.vlen = 0;
    ble_uuid.uuid = APH_RX_UUID;	//will add the 16-bit UUID
    uint8_t v2[5]            = {0x00,0x00,0x00,0x00,0x00};
    attr_char_value.p_value     = v2;
    err_code =
                                         &attr_char_value,
        return err_code;
    return NRF_SUCCESS;
//ble_cus_init
ret_code_t ble_cus_init (ble_cus_t * p_cus,
    if (p_cus == NULL || p_cus_init == NULL) {
        return NRF_ERROR_NULL;
// Initialize service structure
    p_cus->evt_handler = p_cus_init->evt_handler;
// Add Custom Service UUID
    ble_uuid128_t base_uuid = {APH_SERVICE_BASE_REV};
    err_code = sd_ble_uuid_vs_add (&base_uuid, &p_cus->uuid_type);
    APP_ERROR_CHECK (err_code);
    ble_uuid.uuid = APH_SERVICE_UUID;
    err_code =
        sd_ble_gatts_service_add (BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid,
                                  &p_cus->service_handle);
        return err_code;
    // Add Custom Value characteristic tx
//    ble_uuid128_t base_tx ={APH_TX_BASE};
    ble_uuid128_t base_tx = {APH_SERVICE_BASE_REV};
    err_code = sd_ble_uuid_vs_add (&base_tx, &p_cus->uuid_type);	//changing the base for the first characteristic
        return err_code;
    err_code = addTXChar(p_cus, p_cus_init);
        return err_code;
    // Add Custom Value characteristic rx
//    ble_uuid128_t base_rx = {APH_RX_BASE};
    ble_uuid128_t base_rx = {APH_SERVICE_BASE_REV};
    err_code = sd_ble_uuid_vs_add (&base_rx, &p_cus->uuid_type);	//changing the base for the first characteristic
        return err_code;
    err_code = addRXChar(p_cus, p_cus_init);
    return err_code;
//update values to application on device
ret_code_t updateTX (ble_cus_t * p_cus, uint8_t  custom_value[5])
    NRF_LOG_INFO ("In ble_cus_custom_value_update. \r\n");
    if (p_cus == NULL) {
    ret_code_t err_code = NRF_SUCCESS;
    ble_gatts_value_t gatts_value;
    // Initialize value struct.
    memset (&gatts_value, 0, sizeof (gatts_value));
    gatts_value.len     = (sizeof(uint8_t)*5);
    gatts_value.offset  = 0;
    gatts_value.p_value = custom_value;
    // Update database.
    err_code = sd_ble_gatts_value_set (p_cus->conn_handle,
                                       p_cus->tx_handles.value_handle,
                                       &gatts_value);
        return err_code;
    // Send value if connected and notifying.
NRF_LOG_INFO("h2 %d h3 %d\n",custom_value[2],custom_value[3]);
    if ((p_cus->conn_handle != BLE_CONN_HANDLE_INVALID)) {
	NRF_LOG_INFO("t1");
        ble_gatts_hvx_params_t hvx_params;
        memset (&hvx_params, 0, sizeof (hvx_params));
        hvx_params.handle =
            p_cus->tx_handles.value_handle;
        hvx_params.type = BLE_GATT_HVX_NOTIFICATION;
        hvx_params.offset = gatts_value.offset;
        hvx_params.p_len = &gatts_value.len;
        hvx_params.p_data = gatts_value.p_value;
        err_code =
            sd_ble_gatts_hvx (p_cus->conn_handle, &hvx_params);
        NRF_LOG_INFO ("sd_ble_gatts_hvx result: %x. \r\n", err_code);
    } else {
		NRF_LOG_INFO("t2");
        err_code = NRF_ERROR_INVALID_STATE;
    return err_code;
ble_aph_service.h
*The start of the SALSProbe in NRF style
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "boards.h"
#include "app_timer.h"
#include "ble_lbs.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log_ctrl.h"
/*message*/
#define PACKET_START 0X1B
#define PACKET_END 0X00
#define MSG_TYPE_VALUE 0X01
#define PACKET_LENGTH  5
* packet to send.
 * first bit is to start \B1
 *second bit is what is in the packet
 * 3rd and 4th bit is the payload
 *fifth bit is the end to say we got the whole thing.
#define TEST_SIGNAL
#ifdef TEST_SIGNAL
uint16_t value = 0;
bool up = true;
uint16_t testValue (uint16_t v)
    NRF_LOG_INFO ("test value %d", v);
    if (up == true) {
        if (v > 1022)
        up = false;
        return (++v);
    } else {
        if (v < 2)
            up = true;
        return (--v);
#define DEVICE_NAME "SALS P1"
#define MANUFACTURER_NAME               "APH"
#define SENSOR_INTERVAL  	   APP_TIMER_TICKS(50)	//1000ms
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL                32                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
#define APP_ADV_DURATION                0
//BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
#define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(650, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY                       0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
BLE_CUS_DEF (m_cus);
NRF_BLE_GATT_DEF (m_gatt);							/**< GATT module instance. */
APP_TIMER_DEF (m_sensor_timer_id);				       /**< Sensor timer. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;			/**< Handle of the current connection. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;		/**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];			/**< Buffer for storing an encoded advertising set. */
static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];/**< Buffer for storing an encoded scan data. */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data = {
    .adv_data =
        .p_data = m_enc_advdata,
        .len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = m_enc_scan_response_data,
/**@brief Function for assert macro callback.
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
void
assert_nrf_callback (uint16_t line_num, const uint8_t * p_file_name)
    app_error_handler (DEAD_BEEF, line_num, p_file_name);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
static void
gap_params_init (void)
    ble_gap_conn_params_t gap_conn_params;
    BLE_GAP_CONN_SEC_MODE_SET_OPEN (&sec_mode);
    err_code = sd_ble_gap_device_name_set (&sec_mode,
                                           strlen (DEVICE_NAME));
    memset (&gap_conn_params, 0, sizeof (gap_conn_params));
    gap_conn_params.slave_latency = SLAVE_LATENCY;
    gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
    err_code = sd_ble_gap_ppcp_set (&gap_conn_params);
/**@brief Function for initializing the GATT module.
static void
gatt_init (void)
    ret_code_t err_code = nrf_ble_gatt_init (&m_gatt, NULL);
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
static void
advertising_init (void)
    ble_advdata_t advdata;
    ble_advdata_t srdata;
    static ble_uuid_t adv_uuids[] = {
        {APH_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN}
    // Build and set advertising data.
    memset (&advdata, 0, sizeof (advdata));
    advdata.name_type = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = true;
    advdata.flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED         ;
    memset (&srdata, 0, sizeof (srdata));
    srdata.uuids_complete.uuid_cnt =
        sizeof (adv_uuids) / sizeof (adv_uuids[0]);
    srdata.uuids_complete.p_uuids = adv_uuids;
    err_code =
        ble_advdata_encode (&advdata, m_adv_data.adv_data.p_data,
		                            &m_adv_data.adv_data.len);
    err_code =
        ble_advdata_encode (&srdata, m_adv_data.scan_rsp_data.p_data,
                            &m_adv_data.scan_rsp_data.len);
    ble_gap_adv_params_t adv_params;
    // Set advertising parameters.
    memset (&adv_params, 0, sizeof (adv_params));
    adv_params.primary_phy = BLE_GAP_PHY_1MBPS;
    adv_params.duration = APP_ADV_DURATION;
    adv_params.properties.type =
        BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    adv_params.p_peer_addr = NULL;
    adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
    adv_params.interval = APP_ADV_INTERVAL;
    err_code =
        sd_ble_gap_adv_set_configure (&m_adv_handle, &m_adv_data,
                                      &adv_params);
static uint8_t msg_packet[PACKET_LENGTH] = { 0, 0, 0, 0, 0 };
//send code
void
sendMsgBlue (uint16_t value)
    NRF_LOG_INFO ("value %d ", value);
    msg_packet[0] = PACKET_START;
    msg_packet[1] = MSG_TYPE_VALUE;
    msg_packet[2] = value & 0xff;	//LOW BIT
    msg_packet[3] = (value >> 8);	//HIGH BIT
    msg_packet[4] = PACKET_END;
    err_code = updateTX (&m_cus, msg_packet);
//sensor timout handler
static void
sensor_timeout_handler (void *p_context)
    NRF_LOG_INFO ("sensor timout handler");
    static bool sensor = false;
    UNUSED_PARAMETER (p_context);
    sensor = !sensor;
    value = testValue (value);
    sendMsgBlue (value);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void
timers_init (void)
    // Initialize timer module.
    ret_code_t err_code = app_timer_init ();
    //sensor check timer
    err_code =
        app_timer_create (&m_sensor_timer_id,
                          APP_TIMER_MODE_REPEATED,
                          sensor_timeout_handler);
/**@brief Function for handling the Custom Service Service events.
 * @details This function will be called for all Custom Service events which are passed to
 *          the application.
 * @param[in]   p_cus_service  Custom Service structure.
 * @param[in]   p_evt          Event received from the Custom Service.
static void
on_cus_evt (ble_cus_t * p_cus_service,
            ble_cus_evt_t * p_evt)
NRF_LOG_INFO("in on_cus_evt %d",p_evt->evt_type);
    switch (p_evt->evt_type) {
    case BLE_CUS_EVT_NOTIFICATION_ENABLED:
        err_code =
            app_timer_start (m_sensor_timer_id, SENSOR_INTERVAL, NULL);
    case BLE_CUS_EVT_NOTIFICATION_DISABLED:
        err_code = app_timer_stop (m_sensor_timer_id);
    case BLE_CUS_EVT_CONNECTED:
        err_code = app_timer_start (m_sensor_timer_id, SENSOR_INTERVAL, NULL);
    case BLE_CUS_EVT_DISCONNECTED:
static void
services_init (void)
    NRF_LOG_INFO ("SErvices init");
    //create cus structure
    ble_cus_init_t cus_init;
    // Initialize CUS Service init structure to zero.
    memset (&cus_init, 0, sizeof (cus_init));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN (&cus_init.
                                    cccd_write_perm);
                                    custom_value_char_attr_md.read_perm);
                                    custom_value_char_attr_md.write_perm);
    err_code = ble_cus_init (&m_cus, &cus_init);
    cus_init.evt_handler = on_cus_evt;
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module that
 *          are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply
 *       setting the disconnect_on_fail config parameter, but instead we use the event
 *       handler mechanism to demonstrate its use.
static void
on_conn_params_evt (ble_conn_params_evt_t * p_evt)
    if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
        err_code =
            sd_ble_gap_disconnect (m_conn_handle,
                                   BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
/**@brief Function for handling a Connection Parameters error.
static void
conn_params_error_handler (uint32_t nrf_error)
    APP_ERROR_HANDLER (nrf_error);
static void
conn_params_init (void)
    memset (&cp_init, 0, sizeof (cp_init));
    cp_init.p_conn_params = NULL;
    cp_init.first_conn_params_update_delay =
        FIRST_CONN_PARAMS_UPDATE_DELAY;
    cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
    cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
    cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
    cp_init.disconnect_on_fail = false;
    cp_init.evt_handler = on_conn_params_evt;
    cp_init.error_handler = conn_params_error_handler;
    err_code = ble_conn_params_init (&cp_init);
static void
advertising_start (void)
    err_code = sd_ble_gap_adv_start (m_adv_handle, APP_BLE_CONN_CFG_TAG);
static void
ble_evt_handler (ble_evt_t const *p_ble_evt, void *p_context)
NRF_LOG_INFO("ble_event\n");
        NRF_LOG_INFO ("Connected");
        err_code =
        NRF_LOG_INFO ("Disconnected");
        advertising_start ();
        // Pairing not supported
        err_code =
            sd_ble_gap_sec_params_reply (m_conn_handle,
                                         BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                         NULL,
                                         NULL);
    case BLE_GAP_EVT_PHY_UPDATE_REQUEST: {
        NRF_LOG_DEBUG ("PHY update request.");
        ble_gap_phys_t const phys = {
            .rx_phys = BLE_GAP_PHY_AUTO,
            .tx_phys =
            BLE_GAP_PHY_AUTO,
        err_code =
            sd_ble_gap_phy_update (p_ble_evt->evt.gap_evt.
                                   conn_handle, &phys);
        err_code =
            sd_ble_gatts_sys_attr_set (m_conn_handle, NULL, 0, 0);
    case BLE_GATTC_EVT_TIMEOUT:
        NRF_LOG_DEBUG ("GATT Client Timeout.");
        err_code =
            sd_ble_gap_disconnect (p_ble_evt->evt.gattc_evt.conn_handle,
    case BLE_GATTS_EVT_TIMEOUT:
        NRF_LOG_DEBUG ("GATT Server Timeout.");
        err_code =
            sd_ble_gap_disconnect (p_ble_evt->evt.gatts_evt.conn_handle,
static void
ble_stack_init (void)
    err_code = nrf_sdh_enable_request ();
    uint32_t ram_start = 0;
    err_code = nrf_sdh_ble_default_cfg_set (APP_BLE_CONN_CFG_TAG, &ram_start);
    // Enable BLE stack.
    err_code = nrf_sdh_ble_enable (&ram_start);
    NRF_SDH_BLE_OBSERVER (m_ble_observer, APP_BLE_OBSERVER_PRIO,
                          ble_evt_handler, NULL);
// initialize the log module.
static void
log_init (void)
    ret_code_t err_code = NRF_LOG_INIT (NULL);
    NRF_LOG_DEFAULT_BACKENDS_INIT ();
static void
power_management_init (void)
    err_code = nrf_pwr_mgmt_init ();
static void
idle_state_handle (void)
	if (NRF_LOG_PROCESS () == false) {
        nrf_pwr_mgmt_run ();
/**@brief Function for application main entry.
int
main (void)
    // Initialize.
    log_init ();
    NRF_LOG_INFO ("log init  init");
    timers_init ();
    power_management_init ();
    ble_stack_init ();
    gap_params_init ();
    gatt_init ();
    services_init ();
    advertising_init ();
    conn_params_init ();
    // Start execution.
    NRF_LOG_INFO ("SALSProbe started");
    // Enter main loop.
    for (;;) {
        idle_state_handle ();
As you will see with my simple files I have followed about 3 different tutorials to get to  the point I am at.  I am trying to replace the included SALSProbe.ino program with The following source files.  I can send a zip that will compile under nrf-sdk 16.01  If someone has time to help.  The problem is I have to make it work like the INO file because the software for the IOS device is already wrote to interface with it.
I thought I had everything right.  I do not have the code to do the Saadc because I didn't want the extra problems while testing the connection.  I have wrote a test function to imulate the type of data being sent in a 5 byte packet.  The function in main.c  testValue creates the value that would normally come from an SAADC value.  it should go up and down between 0 and 1024.  It is just there to test sending values to the IOS device.   I have watched it work without ble so I know that part is working.
I am using a RayTac mdbt42q nrf 52832 board. which works a lot like all the nordic  test boards.
I wrote an earlier message before I learned as much as I have so I am starting over.  Everything seems to be working except when I do updateTX which is the code to write from the Ble to the IOS device it errors saying I don't have a valid connection.
The device shows up in the list of devices on my app.  When I press to connect it acts like it is connecting then it fails and I think it is timing out because the board does not seem to be getting a connect message.  I have watched with logs and see nothing.
I have tried this starting with the template code and with the blinky code.  This started as the blinky code because it was more simplified at the start.  It has two characteristics with 5 bytes each.
When I start with the blinky code the connection seems to work until I take out the queue code and the button code.  I don't need either of those. It actually works until I switch to my service so the problem may be in my service but everything seems to init right.  The values look right, and there are no memory errors.
Again I am fully willing to send a fully compilable version if someone has time to take a look at it with nrf connect.  I will mention that I am blind and while the new release of nrf connect works better for me I  am not able to get any information out of it that helps.  It also errors in connecting but it shows my service and characteristics I think.
I am hoping someone can just look at my service initalization and just see the problem.  Of course that is wishful thinking.  Any help is greatlly appriciated.  I am also willing to connect by skype and work that way if needed.
  • back and used gdb to log the connect case in the blink app without my changes.  I am able to catch the connect case with the regular blink app.  With my app though the code never reaches the ble_evt handler in the connect case.
    So somewhere between the advertising which shows up fine.  and ble_evt handler getting called it is not working.  I have not changed that much from the blinky app other than removing the queue code, the buttons code, and adding my own service.   I just can't find what is causing the ble_evt handler from being called by the ble stack.
  • I can feel the pain, but don't have any other suggestion than to try and fail a bit. If you are connectable advertising it should go straight to ble_evt_handler() -> BLE_GAP_EVT_CONNECTED. I assume you have checked that there is no assert causing the app_error_fault_handler() to be called.
  • Yes no asserts are thrown.  The app just sits there quiet and happily doing nothing.
    One intersting note.  I moved services_init above the stack_init and then it asserts.   I think that is because the gap is not initilized at that point and when it tries to create my service everything fails.  I think services_init has to be after the stack, gatt, and gap, init.  Of course when it is there there is no errors.
    The ble_observer macro doesn't ahve a return value so I can't tell if something might be going wrong there.
    Coding should not be like this.  There should be some kind of error.  Is there some way I can print out my service and characteristic table to see if they are all corectly done with 128 bit values?
    I looked on the nrf connect app and the service has a 128 bit characteristic but I can't seem to find the 16 bit or the 128 bit characteristic value even though it shows both. characteristic.  Maybe I am just not finding the button to click on the IOS app
    I would like it if I could just print out the table when it gets registerd.
    This is starting to feel like some memory problem even if there is no complaining going on from the chip.
    Ken
