nRF52832 DFU Service without bonds working and not with bonds
We are developing an application requiring the DFU Service on nRF52832.
The implementation of the DFU Service without bonds works very well, but when switching to required bonds, we have an issue when the DFU write request is send (0x01 value to the Secure Buttonless DFU characteristic).
The log report: <error> app: SOFTDEVICE: ASSERTION FAILED when writing to the characteristic.
A step by step debug led us to on_ctrlpt_write(&p_auth_req->request.write) call in ble_dfu.c before crashing.
To make the switch, we change the application and bootloader sdk_config.h files as following:
Application sdk_config.h:
// NRF_SDH_BLE_SERVICE_CHANGED - Include the Service Changed characteristic in the Attribute Table.
#ifndef NRF_SDH_BLE_SERVICE_CHANGED
#define NRF_SDH_BLE_SERVICE_CHANGED 1
// NRF_DFU_BLE_BUTTONLESS_SUPPORTS_BONDS - Buttonless DFU supports bonds.
#ifndef NRF_DFU_BLE_BUTTONLESS_SUPPORTS_BONDS
#define NRF_DFU_BLE_BUTTONLESS_SUPPORTS_BONDS 1
Bootloader sdk_config.h:
// NRF_DFU_BLE_REQUIRES_BONDS - Require bond with peer.
#ifndef NRF_DFU_BLE_REQUIRES_BONDS
#define NRF_DFU_BLE_REQUIRES_BONDS 1
I did not see any other post related to this issue, did we miss something in the config files when going from without bonds to required bonds ?
  • Edit : We found out that the log report a SoftDevice assertion failed only when debugging step by step, probably due to a timeout ?
    With no breakpoint, the app crash without any log error
  • Hi Bertrand,
    To test buttonless example with bond, you would need to generate a bootloader setting page and flash it in addition to the bootloader and the application.
    It's described here.
    Programming a bootloader settings page with information about a bootable application is required for using Secure DFU compiled with bond support. The reason for this is that the Secure DFU bootloader has no functionality to create bonds with a client device and it relies on the main application on the device to do so.
    I have some additional explanation here as well.
  • Hi Hung Bui, thank you for the fast answer.
    Actually I thought that it wouldn't work without bootloader settings, even without bonds (at least because of the CRC check at boot). So we already generate bootloader settings page, and we usually flash a merged .hex containing app + BL + freshly generated settings page.
    Is there a difference for generating bootloader settings page with or without bonds ?
    Regarding our issue, which happens as soon as we write the DFU Service characteristic:
    - Without bonds we get log information that the characteristic has been written (from the app_shutdown_handler, and from the blu_dfu_event handler, which are implemented following the DFU buttonless application template)
    - With bonds we don't get any of this log information. It seems that the app has crashed before
  • Please compile the application with debug mode and check where it crashes (check if it jumps to any assert handler) or if it crashes when switching to the bootloader.
    Please try to test with unmodified buttonless example and stock bootloader.
    Maybe you already have done it, you would need to make a bond with the device before jumping to the bootloader.
  • Thanks for the advice, the template application is running fine with both stock and modified bootloader
    Unfortunately the DEBUG flag did not provide more information
    I finally found out that I missed the SVCI initialization at the beginning of main.c file. Now this is working properly !
    Thanks for the help,
