Periodic advertisement when APP_ADV_DURATION expires
I am using ble_app_uart example for peripheral device and it will be powered by a 3.7 V battery. I need to use battery as long as possible. So I decided to make peripheral device advertise periodically.
Since I need to use app_timer, System ON sleep mode works for me. I know that device doesn't advertise when APP_ADV_DURATION expires (assume it is not 0).  I tried to restart advertise after APP_ADV_DURATION which triggers BLE_ADV_EVT_IDLE event. Also I disabled sleep_mode_enter() function in BLE_ADV_EVT_IDLE since it will put device in System OFF sleep mode.
My timeout handler is like this:
static void single_shot_timer_handler(void * p_context)
 uint32_t err_code;
 err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
And I wanted to start timer in BLE_ADV_EVT_IDLE event like this:
switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("adv fast");
        case BLE_ADV_EVT_IDLE:
            NRF_LOG_INFO("idle");
            err_code = app_timer_start(m_single_shot_timer_id, APP_TIMER_TICKS(20000), NULL);
            //sleep_mode_enter();
I just wanted to advertise for 10 seconds and make it sleep for 20 seconds. I expected timer to start 20 seconds after BLE_ADV_EVT_IDLE. However, device advertises all the time. I mean when APP_ADV_DURATION expires, it doesn't stop advertising.
By the way APP_ADV_DURATION macro is 1000. And I use SDK 16
Could you please help me about it ? I will be very appreciated if you give me a suggestion.
Best Regards
