I am working with a proximity beacon example. In that runs scanning and advertisement code, And in testing, most of the cases, I am not able to get the Advertisement packet even in 1.5sec from the other beacon. I have verified the connection parameter for advertisement and scanning both. Can anyone please help?
I am using Nrfsdk 14.01 and Nrf52810chipset.
I have attached the beacon_example file here.
/** * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA * * All rights reserved. * * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, this * list of conditions and the following disclaimer. * * 2. Redistributions in binary form, except as embedded into a Nordic * Semiconductor ASA integrated circuit in a product or a software update for * such product, must reproduce the above copyright notice, this list of * conditions and the following disclaimer in the documentation and/or other * materials provided with the distribution. * * 3. Neither the name of Nordic Semiconductor ASA nor the names of its * contributors may be used to endorse or promote products derived from this * software without specific prior written permission. * * 4. This software, with or without modification, must only be used with a * Nordic Semiconductor ASA integrated circuit. * * 5. Any software provided in binary form under this license must not be reverse * engineered, decompiled, modified and/or disassembled. * * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES * OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE * DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /** @file * * @defgroup ble_sdk_app_beacon_main main.c * @{ * @ingroup ble_sdk_app_beacon * @brief Beacon Transmitter Sample Application main file. * * This file contains the source code for an Beacon transmitter sample application. */ #include <stdbool.h> #include <stdint.h> #include <string.h> #include "nordic_common.h" #include "bsp.h" #include "nrf_soc.h" #include "nrf_sdh.h" #include "nrf_sdh_ble.h" #include "ble_advdata.h" #include "app_timer.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" #include "nrf_delay.h" #include "math.h" #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */ #define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(100, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */ #define APP_BEACON_INFO_LENGTH 0x17 /**< Total length of information advertised by the Beacon. */ #define APP_ADV_DATA_LENGTH 0x15 /**< Length of manufacturer specific data in the advertisement. */ #define APP_DEVICE_TYPE 0x02 /**< 0x02 refers to Beacon. */ #define APP_MEASURED_RSSI 0xC3 /**< The Beacon's measured RSSI at 1 meter distance in dBm. */ #define APP_COMPANY_IDENTIFIER 0x0059 /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */ #define APP_MAJOR_VALUE 0x01, 0x02 /**< Major value used to identify Beacons. */ #define APP_MINOR_VALUE 0x03, 0x04 /**< Minor value used to identify Beacons. */ #define APP_BEACON_UUID 0x01, 0x12, 0x23, 0x34, \ 0x45, 0x56, 0x67, 0x78, \ 0x89, 0x9a, 0xab, 0xbc, \ 0xcd, 0xde, 0xef, 0xf0 /**< Proprietary UUID for Beacon. */ #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */ #if defined(USE_UICR_FOR_MAJ_MIN_VALUES) #define MAJ_VAL_OFFSET_IN_BEACON_INFO 18 /**< Position of the MSB of the Major Value in m_beacon_info array. */ #define UICR_ADDRESS 0x10001080 /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */ #endif #define SCAN_DURATION_WITELIST 0x0000 /**< Duration of the scanning in units of 10 milliseconds. */ #define NRF_BLE_SCAN_SCAN_INTERVAL 0x00A0 #define NRF_BLE_SCAN_SCAN_DURATION 0 #define NRF_BLE_SCAN_SCAN_WINDOW 0x0050 #define BLE_GAP_ADV_SET_HANDLE_NOT_SET (0xFF) #define APP_BLE_OBSERVER_PRIO 0 NRF_BLE_SCAN_DEF(m_scan); /**< Scanning Module instance. */ static ble_gap_scan_params_t m_scan_param = /**< Scan parameters requested for scanning and connection. */ { .active = 1, .interval = NRF_BLE_SCAN_SCAN_INTERVAL, .window = NRF_BLE_SCAN_SCAN_WINDOW, .timeout = SCAN_DURATION_WITELIST, #if (NRF_SD_BLE_API_VERSION <= 2) .selective = 0, .p_whitelist = NULL, #endif #if (NRF_SD_BLE_API_VERSION >= 3) .use_whitelist = 0, #endif }; #if 0 static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] = /**< Information advertised by the Beacon. */ { APP_DEVICE_TYPE, // Manufacturer specific information. Specifies the device type in this // implementation. APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the // manufacturer specific data in this implementation. APP_BEACON_UUID, // 128 bit UUID value. APP_MAJOR_VALUE, // Major arbitrary value that can be used to distinguish between Beacons. APP_MINOR_VALUE, // Minor arbitrary value that can be used to distinguish between Beacons. APP_MEASURED_RSSI // Manufacturer specific information. The Beacon's measured TX power in // this implementation. }; #endif /**@brief Callback function for asserts in the SoftDevice. * * @details This function will be called in case of an assert in the SoftDevice. * * @warning This handler is an example only and does not fit a final product. You need to analyze * how your product is supposed to react in case of Assert. * @warning On assert from the SoftDevice, the system can only recover on reset. * * @param[in] line_num Line number of the failing ASSERT call. * @param[in] file_name File name of the failing ASSERT call. */ void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name) { app_error_handler(DEAD_BEEF, line_num, p_file_name); } /**@brief Function for initializing the Advertising functionality. * * @details Encodes the required advertising data and passes it to the stack. * Also builds a structure to be passed to the stack when starting advertising. */ static void advertising_init(void) { uint32_t err_code; ble_advdata_t advdata; uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED; int8_t tx_power_level = -20; ble_advdata_manuf_data_t manuf_specific_data; /*#if defined(USE_UICR_FOR_MAJ_MIN_VALUES) // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the // UICR instead of using the default values. The major and minor values obtained from the UICR // are encoded into advertising data in big endian order (MSB First). // To set the UICR used by this example to a desired value, write to the address 0x10001080 // using the nrfjprog tool. The command to be used is as follows. // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value> // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the // the following command should be used. // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102 uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16; uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF); uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO; m_beacon_info[index++] = MSB_16(major_value); m_beacon_info[index++] = LSB_16(major_value); m_beacon_info[index++] = MSB_16(minor_value); m_beacon_info[index++] = LSB_16(minor_value); #endif manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info; manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH; */ // Build and set advertising data. memset(&advdata, 0, sizeof(advdata)); advdata.name_type = BLE_ADVDATA_NO_NAME; advdata.flags = flags; //advdata.p_manuf_specific_data = &manuf_specific_data; err_code = ble_advdata_set(&advdata, NULL); APP_ERROR_CHECK(err_code); err_code = sd_ble_gap_tx_power_set(tx_power_level); // Initialize advertising parameters (used when starting advertising). memset(&m_adv_params, 0, sizeof(m_adv_params)); m_adv_params.type = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND; m_adv_params.p_peer_addr = NULL; // Undirected advertisement. m_adv_params.fp = BLE_GAP_ADV_FP_ANY; m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL; m_adv_params.timeout = 0; // Never time out. m_adv_params.channel_mask.ch_37_off = 0x00; m_adv_params.channel_mask.ch_38_off = 0xFF; m_adv_params.channel_mask.ch_39_off = 0xFF; //Advertising only on channel 37, Disables Channel 38 & 39 } /**@brief Function for starting timer. */ static void timer_start(void) { ret_code_t err_code; // Start application timers. APP_ERROR_CHECK(err_code); } /**@brief Function for starting advertising. */ static void advertising_start(void) { ret_code_t err_code; err_code = sd_ble_gap_adv_start(&m_adv_params, APP_BLE_CONN_CFG_TAG); APP_ERROR_CHECK(err_code); err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING); APP_ERROR_CHECK(err_code); } /**@brief Function for handling BLE events. * * @param[in] p_ble_evt Bluetooth stack event. * @param[in] p_context Unused. */ static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context) { ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt; switch (p_ble_evt->header.evt_id) { // Upon connection, initiate secure bonding. case BLE_GAP_EVT_CONNECTED: NRF_LOG_INFO("Connected."); break; case BLE_GAP_EVT_DISCONNECTED: NRF_LOG_INFO("Disconnected."); //LEDS_ON(BSP_LED_0_MASK); break; case BLE_GAP_EVT_SEC_PARAMS_REQUEST: break; // BLE_GAP_EVT_SEC_PARAMS_REQUEST case BLE_GAP_EVT_ADV_REPORT:{ break; default: // No implementation needed. break; } } /**@brief Function for initializing the BLE stack. * * @details Initializes the SoftDevice and the BLE event interrupt. */ static void ble_stack_init(void) { ret_code_t err_code; err_code = nrf_sdh_enable_request(); APP_ERROR_CHECK(err_code); // Configure the BLE stack using the default settings. // Fetch the start address of the application RAM. uint32_t ram_start = 0; err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start); APP_ERROR_CHECK(err_code); // Enable BLE stack. err_code = nrf_sdh_ble_enable(&ram_start); APP_ERROR_CHECK(err_code); // Register a handler for BLE events. NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL); } /**@brief Function for initializing logging. */ static void log_init(void) { ret_code_t err_code = NRF_LOG_INIT(NULL); APP_ERROR_CHECK(err_code); NRF_LOG_DEFAULT_BACKENDS_INIT(); } /**@brief Function for initializing LEDs. */ static void leds_init(void) { bsp_board_leds_init(); //ret_code_t err_code = bsp_init(BSP_INIT_LED, NULL); //APP_ERROR_CHECK(err_code); } /**@brief Function for initializing timers. */ static void timers_init(void) { ret_code_t err_code = app_timer_init(); APP_ERROR_CHECK(err_code); /*Create a timer instance*/ APP_ERROR_CHECK(err_code); } /**@brief Function for doing power management. */ static void power_manage(void) { ret_code_t err_code = sd_app_evt_wait(); APP_ERROR_CHECK(err_code); } /**@brief Function to start scanning. */ static void scan_start(void) { ret_code_t err_code; (void) sd_ble_gap_scan_stop(); err_code = sd_ble_gap_scan_start(&m_scan_param); APP_ERROR_CHECK(err_code); } /** * @brief Function for application main entry. */ int main(void) { // Initialize. log_init(); timers_init(); leds_init(); ble_stack_init(); advertising_init(); advertising_start(); timer_start(); scan_start(); // Start execution. NRF_LOG_INFO("Beacon example started."); // Enter main loop. for (;; ) { if (NRF_LOG_PROCESS() == false) { power_manage(); } } } /** * @} */
