Hard fault on the timer interrupt with Softdevice project included
I am using nRF SDK 16,0 and ble_app_template for pca10040 with Softdevice 132.
The example works fine, on my DK board but I need to utilize timers for my application.
Since TIMER0 is reserved for SoftDevice, I tried to initialize TIMER1,2,3 or 4 using the following implementation:
static nrf_drv_timer_t timer = \
    .p_reg = NRFX_CONCAT_2(NRF_TIMER, 1), \
    .instance_id = 1, \
    .cc_channel_count = NRF_TIMER_CC_CHANNEL_COUNT(1), \
static void ims_us_timer_init(void)
    ret_code_t err_code;
    err_code = nrf_drv_timer_init(&us_timer, &timer_cfg, timer_handler);
    nrf_drv_timer_compare(&us_timer, (nrf_timer_cc_channel_t)0,
    200 * 1000UL, true);
    nrf_drv_timer_enable(&us_timer);
However, if this code sticks to HardFault handler after enabling the timer. It doesn't crash only if, in nrf_drv_timer_compare function, the last parameter is set to false (disabled interrupt).
In any case, the callback (timer_handler) is not executed at all.
This code works well in the project that doesn't contain the SoftDevice.
Is there anything wrong I am doing or some constraints or collision between SoftDevice and Timers ?
