undefined reference twi error
I hope you can help me. I get an error while compiling. I merge "twi sensor" example from sdk to the "ble app uart" example from sdk. So I customize the sdk_config to enable twi. In addition to that, I add all missing nRF_Drivers to make it work. While compiling, I get the following output:
1> "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/as" --traditional-format -I../../../config -I../../../../../../components -I../../../../../../components/ble/ble_advertising -I../../../../../../components/ble/ble_dtm -I../../../../../../components/ble/ble_link_ctx_manager -I../../../../../../components/ble/ble_racp -I../../../../../../components/ble/ble_services/ble_ancs_c -I../../../../../../components/ble/ble_services/ble_ans_c -I../../../../../../components/ble/ble_services/ble_bas -I../../../../../../components/ble/ble_services/ble_bas_c -I../../../../../../components/ble/ble_services/ble_cscs -I../../../../../../components/ble/ble_services/ble_cts_c -I../../../../../../components/ble/ble_services/ble_dfu -I../../../../../../components/ble/ble_services/ble_dis -I../../../../../../components/ble/ble_services/ble_gls -I../../../../../../components/ble/ble_services/ble_hids -I../../../../../../components/ble/ble_services/ble_hrs -I../../../../../../components/ble/ble_services/ble_hrs_c -I../../../../../../components/ble/ble_services/ble_hts -I../../../../../../components/ble/ble_services/ble_ias -I../../../../../../components/ble/ble_services/ble_ias_c -I../../../../../../components/ble/ble_services/ble_lbs -I../../../../../../components/ble/ble_services/ble_lbs_c -I../../../../../../components/ble/ble_services/ble_lls -I../../../../../../components/ble/ble_services/ble_nus -I../../../../../../components/ble/ble_services/ble_nus_c -I../../../../../../components/ble/ble_services/ble_rscs -I../../../../../../components/ble/ble_services/ble_rscs_c -I../../../../../../components/ble/ble_services/ble_tps -I../../../../../../components/ble/common -I../../../../../../components/ble/nrf_ble_gatt -I../../../../../../components/ble/nrf_ble_qwr -I../../../../../../components/ble/peer_manager -I../../../../../../components/boards -I../../../../../../components/libraries/atomic -I../../../../../../components/libraries/atomic_fifo -I../../../../../../components/libraries/atomic_flags -I../../../../../../components/libraries/balloc -I../../../../../../components/libraries/bootloader/ble_dfu -I../../../../../../components/libraries/bsp -I../../../../../../components/libraries/button -I../../../../../../components/libraries/cli -I../../../../../../components/libraries/crc16 -I../../../../../../components/libraries/crc32 -I../../../../../../components/libraries/crypto -I../../../../../../components/libraries/csense -I../../../../../../components/libraries/csense_drv -I../../../../../../components/libraries/delay -I../../../../../../components/libraries/ecc -I../../../../../../components/libraries/experimental_section_vars -I../../../../../../components/libraries/experimental_task_manager -I../../../../../../components/libraries/fds -I../../../../../../components/libraries/fifo -I../../../../../../components/libraries/fstorage -I../../../../../../components/libraries/gfx -I../../../../../../components/libraries/gpiote -I../../../../../../components/libraries/hardfault -I../../../../../../components/libraries/hci -I../../../../../../components/libraries/led_softblink -I../../../../../../components/libraries/log -I../../../../../../components/libraries/log/src -I../../../../../../components/libraries/low_power_pwm -I../../../../../../components/libraries/mem_manager -I../../../../../../components/libraries/memobj -I../../../../../../components/libraries/mpu -I../../../../../../components/libraries/mutex -I../../../../../../components/libraries/pwm -I../../../../../../components/libraries/pwr_mgmt -I../../../../../../components/libraries/queue -I../../../../../../components/libraries/ringbuf -I../../../../../../components/libraries/scheduler -I../../../../../../components/libraries/sdcard -I../../../../../../components/libraries/slip -I../../../../../../components/libraries/sortlist -I../../../../../../components/libraries/spi_mngr -I../../../../../../components/libraries/stack_guard -I../../../../../../components/libraries/strerror -I../../../../../../components/libraries/svc -I../../../../../../components/libraries/timer -I../../../../../../components/libraries/twi_mngr -I../../../../../../components/libraries/twi_sensor -I../../../../../../components/libraries/uart -I../../../../../../components/libraries/usbd -I../../../../../../components/libraries/usbd/class/audio -I../../../../../../components/libraries/usbd/class/cdc -I../../../../../../components/libraries/usbd/class/cdc/acm -I../../../../../../components/libraries/usbd/class/hid -I../../../../../../components/libraries/usbd/class/hid/generic -I../../../../../../components/libraries/usbd/class/hid/kbd -I../../../../../../components/libraries/usbd/class/hid/mouse -I../../../../../../components/libraries/usbd/class/msc -I../../../../../../components/libraries/util -I../../../../../../components/nfc/ndef/conn_hand_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser -I../../../../../../components/nfc/ndef/connection_handover/ac_rec -I../../../../../../components/nfc/ndef/connection_handover/ble_oob_advdata -I../../../../../../components/nfc/ndef/connection_handover/ble_pair_lib -I../../../../../../components/nfc/ndef/connection_handover/ble_pair_msg -I../../../../../../components/nfc/ndef/connection_handover/common -I../../../../../../components/nfc/ndef/connection_handover/ep_oob_rec -I../../../../../../components/nfc/ndef/connection_handover/hs_rec -I../../../../../../components/nfc/ndef/connection_handover/le_oob_rec -I../../../../../../components/nfc/ndef/generic/message -I../../../../../../components/nfc/ndef/generic/record -I../../../../../../components/nfc/ndef/launchapp -I../../../../../../components/nfc/ndef/parser/message -I../../../../../../components/nfc/ndef/parser/record -I../../../../../../components/nfc/ndef/text -I../../../../../../components/nfc/ndef/uri -I../../../../../../components/nfc/platform -I../../../../../../components/nfc/t2t_lib -I../../../../../../components/nfc/t2t_parser -I../../../../../../components/nfc/t4t_lib -I../../../../../../components/nfc/t4t_parser/apdu -I../../../../../../components/nfc/t4t_parser/cc_file -I../../../../../../components/nfc/t4t_parser/hl_detection_procedure -I../../../../../../components/nfc/t4t_parser/tlv -I../../../../../../components/softdevice/common -I../../../../../../components/softdevice/s140/headers -I../../../../../../components/softdevice/s140/headers/nrf52 -I../../../../../../components/toolchain/cmsis/include -I../../../../../../external/fprintf -I../../../../../../external/segger_rtt -I../../../../../../external/utf_converter -I../../../../../../integration/nrfx -I../../../../../../integration/nrfx/legacy -I../../../../../../modules/nrfx -I../../../../../../modules/nrfx/drivers/include -I../../../../../../modules/nrfx/hal -I../../../../../../modules/nrfx/mdk -I../config -mcpu=cortex-m4 -mlittle-endian -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mthumb "C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/main.asm" -o "Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o"
1> rm "C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/main.asm"
1> Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o (28.06.2020 20:58:16) is newer than Output/Debug/Exe/ble_app_uart_pca10100_s140.elf (28.06.2020 20:57:32).
1> Linking ble_app_uart_pca10100_s140.elf
1> "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld" -X --omagic -eReset_Handler --defsym=__vfprintf=__vfprintf_long --defsym=__vfscanf=__vfscanf_long -EL --gc-sections "-TC:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/ble_app_uart_pca10100_s140.ld" -Map Output/Debug/Exe/ble_app_uart_pca10100_s140.map -u_vectors -o Output/Debug/Exe/ble_app_uart_pca10100_s140.elf --emit-relocs --start-group "@C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/ble_app_uart_pca10100_s140.ind" --end-group
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/nrf_drv_twi.o: in function `nrf_drv_twi_init':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\integration\nrfx\legacy/nrf_drv_twi.c:186: undefined reference to `nrfx_twi_init'
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o: in function `nrf_drv_twi_enable':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\examples\ble_peripheral\ble_app_uart\pca10100\s140\ses/../../../../../../integration/nrfx/legacy/nrf_drv_twi.h:513: undefined reference to `nrfx_twim_enable'
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o: in function `nrf_drv_twi_tx':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\examples\ble_peripheral\ble_app_uart\pca10100\s140\ses/../../../../../../integration/nrfx/legacy/nrf_drv_twi.h:544: undefined reference to `nrfx_twim_tx'
Build failed
But I don´t know what I´m making wrong.
Could you help me with that?
Thanks in advance
  • Hi Karl,
    I´m sorry for late reply.
    You may not provide NULL as the event_handler argument here, this is the reason why it ASSERTS. Are you familiar with using ASSERT?
    No, not really. I don´t know for what this is for.
    _______________________________________________
    If you are unsure what you should provide as arguments to a function, or how to use a function, please see the functions API Refernce.
    Okay, I get it. I did it the same way like provided by the SAADC example. So now, every time the timer expires, my "sensor_data_read" function should be called. This is, what I would like to have.
    Unfortunaly, it doesn´t work completely. I tried to start my timer in the main loop. While compiling I get a warning. Could you tell me, what is the reason for this?
    I commented out my "read_sensor_data" function because it is called automatically by expiration of the time (i hope so :-) ).
    I think there is something wrong with the definition of my timer_id. As described in the nordic InfoCenter, I declared this variable as a static. Do I have to pay attention to something other?
    Thanks in Advance,
    Simon
  • Hello Simon,
    Do not worry about this at all, it is no problem.
    Using ASSERTs in your code is a very helpful tool when debugging, to make sure certain conditions are always fulfilled before executing code.
    Here is a brief explanation. In this case, the ASSERT tells us that you did not provide the function with the required parameters, and it therefore can not continue.
    Please tell me what the warning said - there is no way for me to see this from your included picture. What are you trying to do in your static const my_timer_id = 3; line?
    If you are attempting to declare a timer instance, you will need to use the _TIMER_INSTANCE macro. You can see this being done in line 72 of the SAADC example.
    Cool, lets get this timer configuration out of the way, so we may see if it works!
    Yes, as I mentioned above you will need to use the INSTANCE macro. If you are uncertain about how something like this should be done, the fastest way to find out is to check a similar example and see how it is implemented there! :)
    You will also need to make sure that the timer is enabled in your sdk_config file ( but since you did not receive a compiler error I think it already is ).
    Also here you may check the sdk_config file of the example, to see that it matches up on the particular functionality you are interested in using.
    Karl
  • Hi Karl,
    I am a Little bit confused.
    Okay, but in this example it seems that there is a library "nrf_drv_timer.h" is used. But I already use "app_timer.h". So I don´t think that I need both, or not? If I include additional the "nrf_drv_timer.h" I get errors with my NRFX_Timer driver. I think in this example an other Driver is used, can this be?
    I think for this I have to enable a few things in sdk_config, but I also use app_timer in my project for other Things.
    So do I have to include the new library (as shown in example) or can I just work with my app_timer library?
    Thanks in Advance.
    Kind regards
    Simon
  • Hello Simon,
    I am sorry for any confusion I might have caused here, my mistake. I thought you were using the TIMER driver directly. If you are using the app_timer library, you will not need ot use the _TIMER_INSTANCE macro, but you will need to use the APP_TIMER_DEF macro instead.
    If you are using the app_timer library, then you do not need to use the TIMER peripheral drivers directly - the app_timer library handles this for you.
    I am sorry about my confusion here, I thought you intended to use the TIMER driver, not the app_timer library. You may just use the app_timer library as you already are, no need to worry about the TIMER driver.
    Karl
  • Hi Karl,
    so now I just use my app_timer.h library but someting went wrong in my implementation.
    For creating my timers I do the following:
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
        APP_TIMER_DEF(my_timer_id);
        err_code=app_timer_create(&my_timer_id,APP_TIMER_MODE_REPEATED, read_sensor_data);
    But when I try to start the timer in my main function, then I get an error because "my_timer_id" is not declared in here:
    Could you explain me how to declare this const?
    If I say "#define my_timer_id 3" for example I get an error because of integer value is not possible here.
    Is there an example of using this app_timer? I didn´t find much using this app_timer :-/
    Thanks in advance
    Kind regards
    Simon
