undefined reference twi error
I hope you can help me. I get an error while compiling. I merge "twi sensor" example from sdk to the "ble app uart" example from sdk. So I customize the sdk_config to enable twi. In addition to that, I add all missing nRF_Drivers to make it work. While compiling, I get the following output:
1> "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/as" --traditional-format -I../../../config -I../../../../../../components -I../../../../../../components/ble/ble_advertising -I../../../../../../components/ble/ble_dtm -I../../../../../../components/ble/ble_link_ctx_manager -I../../../../../../components/ble/ble_racp -I../../../../../../components/ble/ble_services/ble_ancs_c -I../../../../../../components/ble/ble_services/ble_ans_c -I../../../../../../components/ble/ble_services/ble_bas -I../../../../../../components/ble/ble_services/ble_bas_c -I../../../../../../components/ble/ble_services/ble_cscs -I../../../../../../components/ble/ble_services/ble_cts_c -I../../../../../../components/ble/ble_services/ble_dfu -I../../../../../../components/ble/ble_services/ble_dis -I../../../../../../components/ble/ble_services/ble_gls -I../../../../../../components/ble/ble_services/ble_hids -I../../../../../../components/ble/ble_services/ble_hrs -I../../../../../../components/ble/ble_services/ble_hrs_c -I../../../../../../components/ble/ble_services/ble_hts -I../../../../../../components/ble/ble_services/ble_ias -I../../../../../../components/ble/ble_services/ble_ias_c -I../../../../../../components/ble/ble_services/ble_lbs -I../../../../../../components/ble/ble_services/ble_lbs_c -I../../../../../../components/ble/ble_services/ble_lls -I../../../../../../components/ble/ble_services/ble_nus -I../../../../../../components/ble/ble_services/ble_nus_c -I../../../../../../components/ble/ble_services/ble_rscs -I../../../../../../components/ble/ble_services/ble_rscs_c -I../../../../../../components/ble/ble_services/ble_tps -I../../../../../../components/ble/common -I../../../../../../components/ble/nrf_ble_gatt -I../../../../../../components/ble/nrf_ble_qwr -I../../../../../../components/ble/peer_manager -I../../../../../../components/boards -I../../../../../../components/libraries/atomic -I../../../../../../components/libraries/atomic_fifo -I../../../../../../components/libraries/atomic_flags -I../../../../../../components/libraries/balloc -I../../../../../../components/libraries/bootloader/ble_dfu -I../../../../../../components/libraries/bsp -I../../../../../../components/libraries/button -I../../../../../../components/libraries/cli -I../../../../../../components/libraries/crc16 -I../../../../../../components/libraries/crc32 -I../../../../../../components/libraries/crypto -I../../../../../../components/libraries/csense -I../../../../../../components/libraries/csense_drv -I../../../../../../components/libraries/delay -I../../../../../../components/libraries/ecc -I../../../../../../components/libraries/experimental_section_vars -I../../../../../../components/libraries/experimental_task_manager -I../../../../../../components/libraries/fds -I../../../../../../components/libraries/fifo -I../../../../../../components/libraries/fstorage -I../../../../../../components/libraries/gfx -I../../../../../../components/libraries/gpiote -I../../../../../../components/libraries/hardfault -I../../../../../../components/libraries/hci -I../../../../../../components/libraries/led_softblink -I../../../../../../components/libraries/log -I../../../../../../components/libraries/log/src -I../../../../../../components/libraries/low_power_pwm -I../../../../../../components/libraries/mem_manager -I../../../../../../components/libraries/memobj -I../../../../../../components/libraries/mpu -I../../../../../../components/libraries/mutex -I../../../../../../components/libraries/pwm -I../../../../../../components/libraries/pwr_mgmt -I../../../../../../components/libraries/queue -I../../../../../../components/libraries/ringbuf -I../../../../../../components/libraries/scheduler -I../../../../../../components/libraries/sdcard -I../../../../../../components/libraries/slip -I../../../../../../components/libraries/sortlist -I../../../../../../components/libraries/spi_mngr -I../../../../../../components/libraries/stack_guard -I../../../../../../components/libraries/strerror -I../../../../../../components/libraries/svc -I../../../../../../components/libraries/timer -I../../../../../../components/libraries/twi_mngr -I../../../../../../components/libraries/twi_sensor -I../../../../../../components/libraries/uart -I../../../../../../components/libraries/usbd -I../../../../../../components/libraries/usbd/class/audio -I../../../../../../components/libraries/usbd/class/cdc -I../../../../../../components/libraries/usbd/class/cdc/acm -I../../../../../../components/libraries/usbd/class/hid -I../../../../../../components/libraries/usbd/class/hid/generic -I../../../../../../components/libraries/usbd/class/hid/kbd -I../../../../../../components/libraries/usbd/class/hid/mouse -I../../../../../../components/libraries/usbd/class/msc -I../../../../../../components/libraries/util -I../../../../../../components/nfc/ndef/conn_hand_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser -I../../../../../../components/nfc/ndef/connection_handover/ac_rec -I../../../../../../components/nfc/ndef/connection_handover/ble_oob_advdata -I../../../../../../components/nfc/ndef/connection_handover/ble_pair_lib -I../../../../../../components/nfc/ndef/connection_handover/ble_pair_msg -I../../../../../../components/nfc/ndef/connection_handover/common -I../../../../../../components/nfc/ndef/connection_handover/ep_oob_rec -I../../../../../../components/nfc/ndef/connection_handover/hs_rec -I../../../../../../components/nfc/ndef/connection_handover/le_oob_rec -I../../../../../../components/nfc/ndef/generic/message -I../../../../../../components/nfc/ndef/generic/record -I../../../../../../components/nfc/ndef/launchapp -I../../../../../../components/nfc/ndef/parser/message -I../../../../../../components/nfc/ndef/parser/record -I../../../../../../components/nfc/ndef/text -I../../../../../../components/nfc/ndef/uri -I../../../../../../components/nfc/platform -I../../../../../../components/nfc/t2t_lib -I../../../../../../components/nfc/t2t_parser -I../../../../../../components/nfc/t4t_lib -I../../../../../../components/nfc/t4t_parser/apdu -I../../../../../../components/nfc/t4t_parser/cc_file -I../../../../../../components/nfc/t4t_parser/hl_detection_procedure -I../../../../../../components/nfc/t4t_parser/tlv -I../../../../../../components/softdevice/common -I../../../../../../components/softdevice/s140/headers -I../../../../../../components/softdevice/s140/headers/nrf52 -I../../../../../../components/toolchain/cmsis/include -I../../../../../../external/fprintf -I../../../../../../external/segger_rtt -I../../../../../../external/utf_converter -I../../../../../../integration/nrfx -I../../../../../../integration/nrfx/legacy -I../../../../../../modules/nrfx -I../../../../../../modules/nrfx/drivers/include -I../../../../../../modules/nrfx/hal -I../../../../../../modules/nrfx/mdk -I../config -mcpu=cortex-m4 -mlittle-endian -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mthumb "C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/main.asm" -o "Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o"
1> rm "C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/main.asm"
1> Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o (28.06.2020 20:58:16) is newer than Output/Debug/Exe/ble_app_uart_pca10100_s140.elf (28.06.2020 20:57:32).
1> Linking ble_app_uart_pca10100_s140.elf
1> "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld" -X --omagic -eReset_Handler --defsym=__vfprintf=__vfprintf_long --defsym=__vfscanf=__vfscanf_long -EL --gc-sections "-TC:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/ble_app_uart_pca10100_s140.ld" -Map Output/Debug/Exe/ble_app_uart_pca10100_s140.map -u_vectors -o Output/Debug/Exe/ble_app_uart_pca10100_s140.elf --emit-relocs --start-group "@C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/ble_app_uart_pca10100_s140.ind" --end-group
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/nrf_drv_twi.o: in function `nrf_drv_twi_init':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\integration\nrfx\legacy/nrf_drv_twi.c:186: undefined reference to `nrfx_twi_init'
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o: in function `nrf_drv_twi_enable':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\examples\ble_peripheral\ble_app_uart\pca10100\s140\ses/../../../../../../integration/nrfx/legacy/nrf_drv_twi.h:513: undefined reference to `nrfx_twim_enable'
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o: in function `nrf_drv_twi_tx':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\examples\ble_peripheral\ble_app_uart\pca10100\s140\ses/../../../../../../integration/nrfx/legacy/nrf_drv_twi.h:544: undefined reference to `nrfx_twim_tx'
Build failed
But I don´t know what I´m making wrong.
Could you help me with that?
Thanks in advance
  • Hello Simon,
    simon1516 said:
    thanks for your support!
    No problem at all, I am happy to help!
    simon1516 said:
    No, it was just for testing the procedure while watching the timer expiration. In normal mode, we would like to process a TWIM with BLE transfer each 10ms, maybe 20ms. In your opinion, does it make sense to set the chip into sleep modus for this small time? If we expect, a data transfer needs about 2ms...then the chip could sleep for 8ms until the next transfer - a long time?
    I would say 8 ms is quite a long time, especially if it is every 10 ms. That means you potentially have the CPU sleeping ( drawing significantly less power ) for 80% of the time ( unless you are doing something else in your application as well ). It is definitely better than having the CPU perform NOP cycles for the duration, with regards to power consumption.
    You can see the different power consumption scenarios here.
    If you want to take it up another notch, you could look into using Radio Notifications to perform your TWIM transfers right before the next connection event. But, this is not required at this time. Lets first finish the work with the timer!
    simon1516 said:
    What could be a good way to handle this? After each transfer, I can call "sleep_mode_enter()". And then the system is off? Is it possible, to wake up with timer expiration as interrupt? Is there an easy example for this?
     Yes, the power manage module makes this quite easy. As you probably have seen in most of the SDK examples the only thing happening in the main while() loop is a function called "idle_state_handler". If you look into this idle state handler, you will see that it is merely a call to the nrf_pwr_mgmt_run function ( if there are no logs to process ). This function places the CPU in the "Wait for event" state. Once an event is generated, the CPU will handle it accordingly.
    So, it is both very easy to set up ( just use the provided power management module ), and easy to use - I highly recommend giving it a try! It will significantly increase the battery life of your device.
    simon1516 said:
    Okay, but ignoration should be okay for me or not? But someting aborts in my application.
    That the second timer_start is being ignored is fine, yes.
    For example, if your main loop keeps fetching data somewhere, and trying to process the data by sending it over TWIM. If your TWIM only happens at the end of the timer, and that timer is too long, then data will "build up" rapidly, since it is not being processed in time.
    When you say that something aborts in your application, are you then talking about the NRF_BUSY_ERROR returned from nrfx_twim_xfer?
    simon1516 said:
    Correct. It´s the function "nrfx_twim_xfer" again. The complete error message is:
    <error> app: ERROR 17 [NRF_ERROR_BUSY] at C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\examples\ble_peripheral\ble_app_uart_with_twim v0.2\main.c:826
    PC at: 0x0003137B
    As we can see from the nrfx_twim_xfer documentation, NRF_ERROR_BUSY will be returned when the driver is not yet ready for a new transfer, such as if it is still working on the previous transfer and you attempt to start a new one.
    Taking a quick look through your project I have the following questions:
    - what is the b_Battery_Pin define for?
    - all your "regX" variables should have proper names. I.e READ_XXX, or CTRL_XXX. You could also have a separate header file that defines all the possible commands for the sensor, which makes them easy to invoke. This increases readability and reduces that chance of mistyping a command / reading the wrong register.
    - your "my_timer_id" timer is set to be in REPEATED mode, I do not know if this is intentional? As I understood it you would just like to start the timer in between each transfer, to ensure that enough time passes for the device to be ready for the next transfer, was it not so? With the current REPEATED timer, triggering read_sensor_data you still rely on nrf_delay_ms in between your transfers.
    simon1516 said:
    Karl, thanks for you help!
    It is no problem at all, Simon!
    Karl
  • Hi Karl,
    Thanks for this. So it make sense, setting CPU in sleep mode. I will try it :-)
    _____________________________________________________________
    My timers are working now, I get it! :-) In my case I call two times "nrfx_twim_xfer" in one read procedure. Because of that, I have declared two timers now. I had to split my read function in two parts (because a timer can just call one function after expiration).
    First timer: Repeatet, because I would like to send data in an special time intervall.
    Second timer: NOT repeatet; If First timer expired, second timer start´s - because of TWIM needs this time for processing well.
    In my case, first timer 1000ms,second timer 10ms. I try to reduce this the next days, we´ll see how much works.
    - b_Battery_Pin was just for testing - setting a Pin high from the nrf52833 to high. Our custom board includes a battery management chip - this Pin high shall activate/enable the IC on the board.
    - Yes, this is a good point. I have to do that. But making code better to read, doesn´t make fun :-) Please give me a few days for that.
    - You´re right. But in each transfer I start a timer. But I need a second timer, to start the transfer. Because of that, I implemented two timers for this.
    I try to implement the idle_state_handler the next days for better battery life. I haven´t done it yet, but I will give you a feedback here soon.
    Thank you and kind regards
    Simon
  • Hello Simon,
    Great, I am happy to hear that you found the reference helpful! :)
    Its working, great!
    I am not sure I have completely understood the usage of the TWIM transfers here then.
    After initialization of the sensor, what else than reading the sensor data do you do?
    Regarding that last part, have you looked at the possibility to use the _TXRX DESC type? It sets up two transfers, one write and one read. Alternatively, if you are always doing the same read/write operation periodically, you could use the NRFX_TWIM_FLAG_REPEATED_XFER flag for the nrfx_twim_xfer. This way, you can queue a lot of these transfers to happen periodically.
    That sounds great, thank you for clarifying this.
    He-he yes, I totally get what you are saying here!
    I am happy to hear that you might be taking this suggestion to heart :)
    I am not sure that I see the need for a second timer here, as I have understood your setup.
    But, if it is working as intended and you are happy with the results then do not worry at all about my understanding of it.
    You already have the idle_state_handler implemented in your project - it came with the example you started out from. Just search for idle_state_handler in your main.c and you will see!
    All you need to do is call it, for example in the main loop.
    Looking forward to hearing your thoughts on using the nrfx_twim_xfer flags I mentioned above!
    Karl
  • Hi Karl,
    Nothing. I just want to collect the sensor data and transmitt them by BLE. Nothing else.
    Is it okay notice this for later? I´m happy that the main things are working now. I´m sure that both things are making sense :-)
    I just added the call "idle_state_handle()" in my main loop. I´m excited to see the impact to the current consumptation. I wasn´t able to measure this yet.
    Unfortunaly I have another problem with my connection: If I rebuild/repower the Dev. board I can see the application in nRF connect as BLE device - as it should be. But if I wait a short time, sometimes 20s, sometings 30s, the device can´t be found furthermore. The same if I connect to the device and then disconnect - I can´t found the device furthermore.
    I think this is because of the TWIM transfer - so many transfers (every 10 or 20ms) to read from the sensor, print over uart and send ober BLE...is the application able to advertise, allthough the CPU has to do such many tasks? I seems not. So my question here: Is there a variable I can use to indicate if the TWIM shall work or not?
    If variable (BLE device connected)
    then TWIM transfer
    endif
    Then the CPU can take it´s time for advertising because there are no other tasks to do.
    Thanks for helping me with all my problems!
    Kind regards
    Simon
  • Hello Simon,
    Absolutely, you can jot this down for later, as a possible optimization of your application. It is great to hear that you are happy with how things are working currently!
    In short, you might optimize this application by using the REPEATED_XFER flag with the nrfx_twim_xfer. This will make it so that a given transfer happens every so often.
    You may then set it up so that your peripheral does not transmit the value if there has not been a significant change ( I do not know exactly what you are measuring and / or how fast it will fluctuate ) but you may do this by setting slave latency in your connection parameters. This can also save you a lot of power.
    Great, I look forward to hearing the results!
    Hm, this sounds like the device is not advertising anymore.
    What is your advertising parameters? Have you set a timeout for the advertisement?
    Yes, you do not need to worry that the CPU will not be able to fulfill the SoftDevice requirements. As mentioned earlier, the SoftDevice takes priority over any application layer task, which means that when the SoftDevice needs the CPU for time-critical tasks it will take it, no matter what the application is doing.
    So, it is actually the other way around which you will need to think about - how will your application behave if interrupted during a certain operation - this is important to take into account when developing the application.
    You can create a variable to stop reading / trying to send the TWI transfers when you are in a connection or not - this is probably wise, since there is no use in collecting the sensor data if you can not send it to anyone ( if you are not buffering it ).
    So, you can add such a variable to the ble_evt_handler in the CONNECTED and DISCONNECTED events, for instance.
    Karl
