[Strategy] Multiple Tasks (SoftDevice + Scheduler + App Timer)
Hello guys. I'm beginner in Nordic Devices.
I'm working in project that sends Acceleration Data from KX220 sensor over LoRa network or if there is a BLE device connected, my nRF52 (SDK 14.2) should stream the data over BLE.
The acceleration data is currently collected by TIMER1 + SAADC + PPI, but I want collect the acelleration sampling 5KHz with LFXTAL due the low power consuption.
For LoRa network, I'm using this port:
https://github.com/gluedig/nrf52-lora
I built a Custom Board with my peripherals, LoRa Radio, Accelerometer KX220 and the nRF52832 is my main CPU. So, the nrf52-lora uses RTC2 to control the LoRaMAC timer. Soft Device uses the RTC0 and app_timer uses RTC1.
In the current scenario i want to keep my device sleeping for a long period, like 30 minutes for example. But I dont known exactly how can I count these 30 minutes sleeping, because RTC0, RTC1 and RTC2 have been used for other purpourse.
My first idea is using the app_timer lib to create a new task event but I'm note sure how could I do this.
I followed this tutorial:
https://devzone.nordicsemi.com/nordic/short-range-guides/b/software-development-kit/posts/application-timer-tutorial
I started to work with the ble_app_uart, this example uses the app_timer but this code doesnt follow the above steps for app_timer, I didn't understand very well how to use the app_timer with soft device. In the ble_app_uart we just see the following code:
// Initialize.
    err_code = app_timer_init();
In the ble_app_uart example there is not a app_timer callback like the tutorial, see the example bellow.
/**@brief Create timers.
static void create_timers()
    ret_code_t err_code;
    // Create timers
    err_code = app_timer_create(&m_repeated_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                repeated_timer_handler);
So I want to use app_timer to create tasks to wake up my device after sleep minutes and control a sampling process. Can i do this with app_timer ? Do I need to use the scheduler ? Which is the best strategy for this case ?
    Yes, app_timer supports timeout_ticks up to the maximum length of a uint32_t variable. 30 minutes should correspond to 1 800 000 ms, or 58 982 400 ticks with the default prescaler. You can change the prescaler for app_timer in sdk_config.h to support event longer intervals:
    // <o> APP_TIMER_CONFIG_RTC_FREQUENCY  - Configure RTC prescaler.
    // <0=> 32768 Hz
    // <1=> 16384 Hz
    // <3=> 8192 Hz
    // <7=> 4096 Hz
    // <15=> 2048 Hz
    // <31=> 1024 Hz
    #ifndef APP_TIMER_CONFIG_RTC_FREQUENCY
    #define APP_TIMER_CONFIG_RTC_FREQUENCY 0
    That should not be required. Scheduler is typically used to execute tasks from interrupt handlers in main context, to make sure everything is handled in the correct order.
    Jørgen
  • Hi Jorgen thanks for replying.
    I tried the APP_TIMER_DEF and I created a new timer for controlling my sleeping time.
    It works very well. But sometimes I receive in my Jlink Segger Rtt the error ("Fatal error") and the whole application stops.
    I believe this occurs because my PPI enable and disable could be wrong. Can you take a look in my summarized code please?
    And how about the sampling process ? What do you think is better ? Do I use the TIMER + PPI for sampling? Do I create a new app_timer task and use RTC+PPI for sampling ? (In my final project I wanna use sampling in 5KHz).
    Best Regards.
     * main.c
     *  Created on: 21 de jun de 2020
     *      Author: Augusto Peterle
    #include "kx220_driver.h"
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "custom_board.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "ble_serial_api.h"
    #include "app_timer.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #define SLEEP_INTERVAL					APP_TIMER_TICKS(10000)
    #define SAMPLING						APP_TIMER_TICKS(5000)
    #define SAADC_SAMPLES_IN_BUFFER         4											 /**<Amount of samples in Buffer */
    #define SAADC_SAMPLE_RATE		        2000                                         /**< SAADC sample rate in ms. */
    volatile uint8_t state = 1;
    static const nrf_drv_timer_t   			m_timer = NRF_DRV_TIMER_INSTANCE(3);
    static nrf_saadc_value_t     			m_buffer_pool[1][SAADC_SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t       			m_ppi_channel;
    static uint32_t              			m_adc_evt_counter;
    uint8_t statusSampling = 0;
    //Sleep timer
    APP_TIMER_DEF(m_sleep_timer);
    //Ohter timer not applicable yet
    APP_TIMER_DEF(m_timer_write);
    void timer_handler(nrf_timer_event_t event_type, void* p_context)
        //Timer Configure Init
        nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
        timer_config.frequency = NRF_TIMER_FREQ_31250Hz;
        err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_handler);
        /* setup m_timer for compare event */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer,SAADC_SAMPLE_RATE);
        nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
        uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
        // PPI Interconnect Timer Event NRF_TIMER_CC_CHANNEL0 to saadc_sample_event_addr
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
    void saadc_sampling_event_disable(void)
        ret_code_t err_code = nrf_drv_ppi_channel_disable(m_ppi_channel);
            uint16_t adc_value;
            uint8_t value[SAADC_SAMPLES_IN_BUFFER*2];
            uint8_t bytes_to_send;
            // set buffers
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
            NRF_LOG_INFO("ADC event number: %d\r\n",(int)m_adc_evt_counter);
            NRF_LOG_PROCESS();
            for (int i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
                //printf("%d\r\n", p_event->data.done.p_buffer[i]);
                NRF_LOG_INFO("%d\r\n", p_event->data.done.p_buffer[i]);
    			NRF_LOG_PROCESS();
                adc_value = p_event->data.done.p_buffer[i];
                value[i*2] = adc_value;
                value[(i*2)+1] = adc_value >> 8;
            // Send data over BLE via NUS service. Makes sure not to send more than 20 bytes.
    			if((SAADC_SAMPLES_IN_BUFFER*2) <= 20)
    				bytes_to_send = (SAADC_SAMPLES_IN_BUFFER*2);
    				bytes_to_send = 20;
    			//I can evaluate adc read here
            m_adc_evt_counter++;
    void saadc_init(void)
        nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
        saadc_config.resolution = NRF_SAADC_RESOLUTION_14BIT;
        nrf_saadc_channel_config_t channel_0_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
        channel_0_config.gain = NRF_SAADC_GAIN1_4;
        channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_1_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
        channel_1_config.gain = NRF_SAADC_GAIN1_4;
        channel_1_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_2_config =
    		NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
        channel_2_config.gain = NRF_SAADC_GAIN1_4;
        channel_2_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_3_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7);
        channel_3_config.gain = NRF_SAADC_GAIN1_4;
        channel_3_config.reference = NRF_SAADC_REFERENCE_VDD4;
        err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
        err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
        err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
        err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
    /* Logger Segger RTT */
    static void log_init(void)
    static void battery_level_meas_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        nRF_BLE_write();
        if( statusSampling == 1){
        	//Enable Timer interconnect to SAAD Interrupt
        	statusSampling = 0;
        } else {
        	//Disable Timer interconnect to SAAD Interrupt
        	nrf_drv_timer_disable(&m_timer);
        	saadc_sampling_event_disable();
        	statusSampling = 1;
    static void timers_init(void)
        // Create battery timer.
        err_code = app_timer_create(&m_sleep_timer,
                                    battery_level_meas_timeout_handler);
    static void timers_start(void)
        err_code = app_timer_start(m_sleep_timer, SLEEP_INTERVAL, NULL);
    int main(){
    	//Setup Accelerometer Functions
    	log_init();											//Segger Log functions
    	setupKX220();										//Start Pins in KX220
    	saadc_sampling_event_init();						//Sampling Init
    	saadc_init();										//SAADC Config Init
    	nrf_delay_ms(50);
    	//UART for NUS services
    	uart_init();
    	//App timer init
    	timers_init();
    	//Setup BLE Functions
    	nRF_hardware_init();
    	nRF_BLE_init();
    	nRF_BLE_start_advertising();
    	//NRF_LOG Flag Start
    	NRF_LOG_INFO("Start");
    	NRF_LOG_PROCESS();
    	timers_start();
    	while(true){
    		power_manage();
  • If you build the application in debug configuration mode (or with DEBUG flag set in preprocessor symbols), the exact function call/line number/error code should be output on the log. This will help with determining what is failing in your application.
    App_timer is a software timer implementation. It is not possible to use PPI with app_timer to trigger HW events. If you want to use RTC with PPI, you need to use another RTC instance and set this up manually (see for instance this example).
