Master Control panel 3.8.0.7 fails to search devices
Hi, After i flashed the firmware MEFW nRF58122 0.11.0, MCP "start discovery" button is disabled. I flashed the lower version MEFW nRF58122 0.9.0. Same issue.
There is exception after "Failed to import BleDfu" with Python exception in the log file.
I saw a similar questions asked earlier, but unanswered.
Here is the log file content.
2;03:21:59.0809 [MainThread] Master Control Panel 3.8.0.7
3;03:21:59.1029 [MainThread] Log verbosity level: High
4;03:21:59.2019 [MainThread] nrfjprog.dll 5.2.0.45203
5;03:21:59.2029 [MainThread] JLinkARM.dll 4.92
6;03:21:59.2089 [MainThread] 480112595 - COM3
7;03:21:59.2179 [MainThread] nrfjprog.dll 5.2.0.45203
8;03:21:59.2339 [MainThread] HciJLinkDriver opened (COM3, 1000000-8-None-1-RequestToSend)
9;03:21:59.2389 [480112595][MainThread] JLinkARM.dll 4.92
10;03:21:59.2459 [480112595][MainThread] 480112595 - COM3
11;03:22:00.5760 [480112595][MainThread] HCI command: BTLE_CMD_READ_BD_ADDR
12;03:22:00.5900 [480112595][MainThread] Serial port write: 01-09-10-00
13;03:22:00.5910 [480112595][MainThread] Waiting for event packet. Timeout is 500ms
14;03:22:00.5940 [480112595][ReadPacketQueueThread] Serial port read: 04-0E-0A-01-09-10-00-56-FF-99-00-CD-29
15;03:22:00.6070 [480112595][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_COMPLETE, OpCode: BTLE_CMD_READ_BD_ADDR, Status: BTLE_STATUS_CODE_SUCCESS, BdAddress: 0x29CD0099FF56
16;03:22:00.6070 [480112595][MainThread] Finished waiting for event packet. PacketReceived:True
17;03:22:00.6090 [480112595][MainThread] HCI command: NRF_CMD_SET_BD_ADDR, Address: 0x2C-48-76-93-A4-F2
18;03:22:00.6090 [480112595][MainThread] Serial port write: 01-03-FC-06-2C-48-76-93-A4-F2
19;03:22:00.6090 [480112595][MainThread] Waiting for event packet. Timeout is 500ms
20;03:22:00.7100 [480112595][ReadPacketQueueThread] Serial port read: 04-0E-04-01-03-FC-00
21;03:22:00.7100 [480112595][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_COMPLETE, OpCode: NRF_CMD_SET_BD_ADDR, Status: BTLE_STATUS_CODE_SUCCESS
22;03:22:00.7100 [480112595][MainThread] Finished waiting for event packet. PacketReceived:True
23;03:22:00.7120 [480112595][MainThread] HCI command: NRF_CMD_GET_VERSION_INFO
24;03:22:00.7120 [480112595][MainThread] Serial port write: 01-06-FC-00
25;03:22:00.7120 [480112595][MainThread] Waiting for event packet. Timeout is 500ms
26;03:22:00.9180 [480112595][ReadPacketQueueThread] Serial port read: 04-0E-2C-01-06-FC-00-6D-65-66-77-5F-6E-72-66-35-31-38-32-32-5F-30-2E-31-31-2E-30-2E-31-38-33-37-38-00-00-00-00-00-00-00-00-00-00-00-00-00-00
27;03:22:00.9180 [480112595][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_COMPLETE, OpCode: NRF_CMD_GET_VERSION_INFO, Status: BTLE_STATUS_CODE_SUCCESS, VersionInfo: mefw_nrf51822_0.11.0.18378
28;03:22:00.9180 [480112595][MainThread] Finished waiting for event packet. PacketReceived:True
29;03:22:01.7951 [480112595][ScriptThread] Failed to import BleDfu
30;03:22:01.8571 [480112595][ScriptThread] Python exception: No module named Nordicsemi
Stacktrace:   at Microsoft.Scripting.Runtime.LightExceptions.CheckAndThrow(Object value)
   at Microsoft.Scripting.Interpreter.FuncCallInstruction`2.Run(InterpretedFrame frame)
   at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame)
   at Microsoft.Scripting.Interpreter.LightLambda.Run1[T0,TRet](T0 arg0)
   at IronPython.Compiler.RuntimeScriptCode.InvokeTarget(Scope scope)
   at IronPython.Compiler.RuntimeScriptCode.Run(Scope scope)
   at IronPython.Runtime.PythonContext.InitializeModule(String fileName, ModuleContext moduleContext, ScriptCode scriptCode, ModuleOptions options)
   at IronPython.Runtime.PythonContext.CompileModule(String fileName, String moduleName, SourceUnit sourceCode, ModuleOptions options, ScriptCode& scriptCode)
   at IronPython.Runtime.Importer.LoadModuleFromSource(CodeContext context, String name, String path)
   at IronPython.Runtime.Importer.LoadFromDisk(CodeContext context, String name, String fullName, String str)
   at IronPython.Runtime.Importer.ImportFromPathHook(CodeContext context, String name, String fullName, List path, Func`5 defaultLoader)
   at IronPython.Runtime.Importer.ImportFromPath(CodeContext context, String name, String fullName, List path)
   at IronPython.Runtime.Importer.ImportModule(CodeContext context, Object globals, String modName, Boolean bottom, Int32 level)
   at IronPython.Modules.Builtin.__import__(CodeContext context, String name, Object globals, Object locals, Object fromlist, Int32 level)
   at Microsoft.Scripting.Interpreter.FuncCallInstruction`7.Run(InterpretedFrame frame)
   at Microsoft.Scripting.Interpreter.LightLambda.Run7[T0,T1,T2,T3,T4,T5,T6,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5, T6 arg6)
   at IronPython.Runtime.Importer.ImportLightThrow(CodeContext context, String fullName, PythonTuple from, Int32 level)
   at IronPython.Runtime.Operations.PythonOps.ImportWithNames(CodeContext context, String fullName, String[] names, Int32 level)
   at Microsoft.Scripting.Interpreter.FuncCallInstruction`5.Run(InterpretedFrame frame)
   at IronPython.Runtime.Importer.ImportNestedModule(CodeContext context, PythonModule module, String[] parts, Int32 current, List path)
   at IronPython.Runtime.Importer.ImportModuleFrom(CodeContext context, Object from, String[] parts, Int32 current)
   at Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1)
   at IronPython.Compiler.PythonScriptCode.RunWorker(CodeContext ctx)
   at IronPython.Compiler.PythonScriptCode.Run(Scope scope)
   at Microsoft.Scripting.SourceUnit.Execute(Scope scope, ErrorSink errorSink)
   at Microsoft.Scripting.Hosting.ScriptSource.Execute(ScriptScope scope)
   at Microsoft.Scripting.Hosting.ScriptEngine.ExecuteFile(String path, ScriptScope scope)
   at UlpbtIronPython.TesterScript.ScriptRun()
