Greetings!
I want to use GPIO P1.07 & P1.05, which are specific Standard Drive,Low Frequency pins.
I used these same gpio pins in SPI peripheral example and it running well but when I was going to integrate this code in BLE_peipheral_blinky example, the error fault occurs. I can not configure this two pins as input or output. The code is running well when I changed these IO pins and set as GPIO P0.30 & P0.31.
Why I can't configure these specific pins in BLE_peripheral_blinky example? Is there any setting require to do in sdk_config file? I just don't get where is the exactly problem?
I used BMD340 module and BMD340 evaluation board. Can you please help me out?
Thanks in advance.
Pooja Uchagaonkar
