Thread Border Router networking fail
Hello Nordic Taam:
I follow the WEB steps below
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_tz_v4.1.0%2Fthread_ot_performance_measurement.html
Software Development Kit > nRF5 SDK for Thread and Zigbee v4.1.0 > Thread > Thread tools > Thread Border Router
nRF52840 DK Version:nRF5_SDK_for_Thread_and_Zigbee_v4.1.0_32ce5f8\examples\thread\ncp\ftd\uart\hex
Raspberry Pi 3 Version:RaspPi_OT_Border_Router_Demo_v4.1.0-1.alpha
Use nRF52840 DK UART connect Raspberry Pi 3 to get the following information
wpan0 => [
"NCP:State" => "associating"
"Daemon:Enabled" => true
"NCP:Version" => "OPENTHREAD/20191113-00534-gc6a258e3; NRF52840; Apr 5 2020 21:51:18"
"Daemon:Version" => "0.08.00d (; Apr 21 2020 19:11:43)"
"Config:NCP:DriverName" => "spinel"
"NCP:HardwareAddress" => [F4CE363EC3C45B0E]
pi@raspberrypi:~ $ sudo wpanctl status
wpan0 => [
"NCP:State" => "uninitialized"
"NCP:Version" => ""
If I have the wrong steps or have not completed, please give me some pointers, thank you.
Also, can you teach me how to set up the Thread Border Router successfully on Raspberry Pi 3?
Best Regards
Rick.
  • Can you check which message type you are receiving when this problem occurs, for instance by printing it in mqttsn_packet_receiver.c:949:
    NRF_LOG_ERROR("Message of unsupported type has been received: %d.\r\n", message_type);
  • Hi Jørgen,
    I get the message_type is 1.
    both are the same.
    Pls kindly help advise how to solve it?
    Best Regards,
    Rick.
  • Hi Jørgen:
    How are you today!
    Are you have any advice? and are you have the same issue?
    Best Regards,
    Rick.
  • Hi Rick,
    I tested this on my end, and I am seeing the same behavior. I believe that the unhandled event message happens because the second board is in a state where it does not expect to receive this event when the first board does a Gateway search. The examples are most likely not written with multiple publishers in mind.
    I'm not sure if the limitation is in the example code, or in the configuration of the Eclipse Paho MQTT-SN Gateway on the Raspberry Pi, but a workaround that seems to work is to disconnect after each node is done publishing (by pushing button 3), and reconnecting (by pressing button 3) on the second board before pressing button 4 to publish a message. You can also integrate this into a single button-press:
    case BSP_EVENT_KEY_3:
        uint32_t err_code;
        if (mqttsn_client_state_get(&m_client) == MQTTSN_CLIENT_DISCONNECTED)
            err_code = mqttsn_client_connect(&m_client, &m_gateway_addr, m_gateway_id, &m_connect_opt);
            if (err_code != NRF_SUCCESS)
                NRF_LOG_ERROR("CONNECT message could not be sent. Error: 0x%x\r\n", err_code);
        while(ready_to_publish == false)
            thread_process();
        publish();
        while(ready_to_publish == true)
            thread_process();
        err_code = mqttsn_client_disconnect(&m_client);
            NRF_LOG_ERROR("DISCONNECT message could not be sent. Error: 0x%x\r\n", err_code);
    You also needs to declare the flag in top of main.c:
    static uint8_t ready_to_publish = false;
    And set/clear the flags in the appropriate event cases:
    case MQTTSN_EVENT_REGISTERED:
        NRF_LOG_INFO("MQTT-SN event: Client registered topic.\r\n");
        regack_callback(p_event);
        ready_to_publish = true;
    case MQTTSN_EVENT_PUBLISHED:
        NRF_LOG_INFO("MQTT-SN event: Client has successfully published content.\r\n");
    You can now remove/comment out the entire BSP_EVENT_KEY_2 case, as this is no longer needed.
    Attaching full main.c as well:
     * Copyright (c) 2017 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup thread_mqttsn_publisher_example_main main.c
     * @ingroup thread_mqttsn_publisher_example
     * @brief Thread MQTT-SN Client Publisher Example Application main file.
     * @details This example demonstrates an MQTT-SN client publisher application that enables to toggle
     *          BSP_LED_2 on a board with related MQTT-SN client subscriber application via MQTT-SN messages.
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "app_scheduler.h"
    #include "app_timer.h"
    #include "bsp_thread.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "mqttsn_client.h"
    #include "thread_utils.h"
    #include <openthread/thread.h>
    #define SEARCH_GATEWAY_TIMEOUT 5                                            /**< MQTT-SN Gateway discovery procedure timeout in [s]. */
    #define SCHED_QUEUE_SIZE       32                                           /**< Maximum number of events in the scheduler queue. */
    #define SCHED_EVENT_DATA_SIZE  APP_TIMER_SCHED_EVENT_DATA_SIZE              /**< Maximum app_scheduler event size. */
    static mqttsn_client_t      m_client;                                       /**< An MQTT-SN client instance. */
    static mqttsn_remote_t      m_gateway_addr;                                 /**< A gateway address. */
    static uint8_t              m_gateway_id;                                   /**< A gateway ID. */
    static mqttsn_connect_opt_t m_connect_opt;                                  /**< Connect options for the MQTT-SN client. */
    static uint8_t              m_led_state        = 0;                         /**< Previously sent BSP_LED_2 command. */
    static uint16_t             m_msg_id           = 0;                         /**< Message ID thrown with MQTTSN_EVENT_TIMEOUT. */
    static char                 m_client_id[]      = "nRF52840_publisher";      /**< The MQTT-SN Client's ID. */
    static char                 m_topic_name[]     = "nRF52840_resources/led3"; /**< Name of the topic corresponding to subscriber's BSP_LED_2. */
    static mqttsn_topic_t       m_topic            =                            /**< Topic corresponding to subscriber's BSP_LED_2. */
        .p_topic_name = (unsigned char *)m_topic_name,
        .topic_id     = 0,
     * @section MQTT-SN
    /**@brief Turns the MQTT-SN network indication LED on.
     * @details This LED is on when an MQTT-SN client is in connected or awake state.
    static void light_on(void)
        LEDS_ON(BSP_LED_3_MASK);
    /**@brief Turns the MQTT-SN network indication LED off.
     * @details This LED is on when an MQTT-SN client is in disconnected or asleep state.
    static void light_off(void)
        LEDS_OFF(BSP_LED_3_MASK);
    /**@brief Initializes MQTT-SN client's connection options.
    static void connect_opt_init(void)
        m_connect_opt.alive_duration = MQTTSN_DEFAULT_ALIVE_DURATION,
        m_connect_opt.clean_session  = MQTTSN_DEFAULT_CLEAN_SESSION_FLAG,
        m_connect_opt.will_flag      = MQTTSN_DEFAULT_WILL_FLAG,
        m_connect_opt.client_id_len  = strlen(m_client_id),
        memcpy(m_connect_opt.p_client_id, (unsigned char *)m_client_id, m_connect_opt.client_id_len);
    /**@brief Processes GWINFO message from a gateway.
     * @details This function updates MQTT-SN Gateway information.
     * @param[in]    p_event  Pointer to MQTT-SN event.
    static void gateway_info_callback(mqttsn_event_t * p_event)
        m_gateway_addr = *(p_event->event_data.connected.p_gateway_addr);
        m_gateway_id   = p_event->event_data.connected.gateway_id;
    /**@brief Processes CONNACK message from a gateway.
     * @details This function launches the topic registration procedure if necessary.
    static void connected_callback(void)
        light_on();
        uint32_t err_code = mqttsn_client_topic_register(&m_client,
                                                         m_topic.p_topic_name,
                                                         strlen(m_topic_name),
                                                         &m_msg_id);
            NRF_LOG_ERROR("REGISTER message could not be sent. Error code: 0x%x\r\n", err_code);
    /**@brief Processes DISCONNECT message from a gateway. */
    static void disconnected_callback(void)
        light_off();
    /**@brief Processes REGACK message from a gateway.
    static void regack_callback(mqttsn_event_t * p_event)
        m_topic.topic_id = p_event->event_data.registered.packet.topic.topic_id;
        NRF_LOG_INFO("MQTT-SN event: Topic has been registered with ID: %d.\r\n",
                     p_event->event_data.registered.packet.topic.topic_id);
    /**@brief Processes retransmission limit reached event. */
    static void timeout_callback(mqttsn_event_t * p_event)
        NRF_LOG_INFO("MQTT-SN event: Timed-out message: %d. Message ID: %d.\r\n",
                      p_event->event_data.error.msg_type,
                      p_event->event_data.error.msg_id);
    /**@brief Processes results of gateway discovery procedure. */
    static void searchgw_timeout_callback(mqttsn_event_t * p_event)
        NRF_LOG_INFO("MQTT-SN event: Gateway discovery result: 0x%x.\r\n", p_event->event_data.discovery);
    /**@brief Function for handling MQTT-SN events. */
    void mqttsn_evt_handler(mqttsn_client_t * p_client, mqttsn_event_t * p_event)
        switch(p_event->event_id)
            case MQTTSN_EVENT_GATEWAY_FOUND:
                NRF_LOG_INFO("MQTT-SN event: Client has found an active gateway.\r\n");
                gateway_info_callback(p_event);
            case MQTTSN_EVENT_CONNECTED:
                NRF_LOG_INFO("MQTT-SN event: Client connected.\r\n");
                connected_callback();
            case MQTTSN_EVENT_DISCONNECT_PERMIT:
                NRF_LOG_INFO("MQTT-SN event: Client disconnected.\r\n");
                disconnected_callback();
            case MQTTSN_EVENT_TIMEOUT:
                NRF_LOG_INFO("MQTT-SN event: Retransmission retries limit has been reached.\r\n");
                timeout_callback(p_event);
            case MQTTSN_EVENT_SEARCHGW_TIMEOUT:
                NRF_LOG_INFO("MQTT-SN event: Gateway discovery procedure has finished.\r\n");
                searchgw_timeout_callback(p_event);
                NRF_LOG_INFO("MQTT-SN unhandled event: %d\r\n", p_event->event_id);
     * @section State
    static void state_changed_callback(uint32_t flags, void * p_context)
        NRF_LOG_INFO("State changed! Flags: 0x%08x Current role: %d\r\n",
                     flags, otThreadGetDeviceRole(p_context));
     * @section Buttons
    static void led_state_pub(uint8_t led_state)
        uint32_t err_code = mqttsn_client_publish(&m_client, m_topic.topic_id, &led_state, 1, &m_msg_id);
            NRF_LOG_ERROR("PUBLISH message could not be sent. Error code: 0x%x\r\n", err_code)
    static void publish(void)
        m_led_state = m_led_state == 1 ? 0 : 1;
        led_state_pub(m_led_state);
    static void bsp_event_handler(bsp_event_t event)
        if (otThreadGetDeviceRole(thread_ot_instance_get()) < OT_DEVICE_ROLE_CHILD )
            (void)event;
            return;
        switch (event)
            case BSP_EVENT_KEY_1:
                uint32_t err_code = mqttsn_client_search_gateway(&m_client, SEARCH_GATEWAY_TIMEOUT);
                    NRF_LOG_ERROR("SEARCH GATEWAY message could not be sent. Error: 0x%x\r\n", err_code);
            case BSP_EVENT_KEY_2:
    //            uint32_t err_code;
    //            if (mqttsn_client_state_get(&m_client) == MQTTSN_CLIENT_CONNECTED)
    //                err_code = mqttsn_client_disconnect(&m_client);
    //                if (err_code != NRF_SUCCESS)
    //                    NRF_LOG_ERROR("DISCONNECT message could not be sent. Error: 0x%x\r\n", err_code);
    //            else
    //                err_code = mqttsn_client_connect(&m_client, &m_gateway_addr, m_gateway_id, &m_connect_opt);
    //                    NRF_LOG_ERROR("CONNECT message could not be sent. Error: 0x%x\r\n", err_code);
                uint32_t err_code;
                    thread_process();
                publish();
                    thread_process();
     * @section Initialization
    /**@brief Function for initializing the Application Timer Module.
    static void timer_init(void)
        uint32_t err_code = app_timer_init();
    /**@brief Function for initializing the LEDs.
    static void leds_init(void)
        LEDS_CONFIGURE(LEDS_MASK);
        LEDS_OFF(LEDS_MASK);
    static void log_init(void)
    /**@brief Function for initializing the Thread Board Support Package.
    static void thread_bsp_init(void)
        uint32_t err_code;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
        err_code = bsp_thread_init(thread_ot_instance_get());
    /**@brief Function for initializing the Thread Stack.
    static void thread_instance_init(void)
        thread_configuration_t thread_configuration =
            .radio_mode        = THREAD_RADIO_MODE_RX_ON_WHEN_IDLE,
            .autocommissioning = true,
        thread_init(&thread_configuration);
        thread_cli_init();
        thread_state_changed_callback_set(state_changed_callback);
    /**@brief Function for initializing the MQTTSN client.
    static void mqttsn_init(void)
        uint32_t err_code = mqttsn_client_init(&m_client,
                                               MQTTSN_DEFAULT_CLIENT_PORT,
                                               mqttsn_evt_handler,
        connect_opt_init();
    /**@brief Function for initializing scheduler module.
    static void scheduler_init(void)
        APP_SCHED_INIT(SCHED_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
     * @section Main
    int main(int argc, char *argv[])
        log_init();
        scheduler_init();
        timer_init();
        leds_init();
        thread_instance_init();
        thread_bsp_init();
        mqttsn_init();
        while (true)
            thread_process();
            app_sched_execute();
                thread_sleep();
    Jørgen
  • Hi Jørgen,
    Thank you for your reply.
    if work is to disconnect after each node is done publishing, it can subscribe MQTT?
    because I follow the WEB steps below Playing with Thread and MQTT-SN on Nordic nRF52840, I need support to publish and subscribe at the same time in the device.
    Best Regards,
    Rick.
