I am new to BLE with my nRF51. I've got this example and I try to stop a RSSI scan when the device get all advertising data from the local device.
But when I try to add a loop for scanning the program just stop working nothing happens no scan at all. Maybe I put a loop the wrong places.
Then I try to compare MAC addr. with first one that the device read when MAC addr. matches program should stop scanning. Right now program
just stop/resume with Button 1 press.
I wonder is there any function or command to get only a single report of advertising data (Not the infinite loop)
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
* The information contained herein is property of Nordic Semiconductor ASA.
* Terms and conditions of usage are described in detail in NORDIC
* SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
* Licensees are granted free, non-transferable use of the information. NO
* WARRANTY of ANY KIND is provided. This heading must NOT be removed from
* the file.
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "boards.h"
#include "app_button.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "app_util.h"
#include "ble_gap.h"
#include "app_error.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
//#include "ble_db_discovery.h"
#include "fstorage.h"
#define IS_SRVC_CHANGED_CHARACT_PRESENT 0 /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
#if (NRF_SD_BLE_API_VERSION == 3)
#define NRF_BLE_MAX_MTU_SIZE GATT_MTU_SIZE_DEFAULT /**< MTU size used in the softdevice enabling and to reply to a BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST event. */
#define APP_FEATURE_NOT_SUPPORTED BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2 /**< Reply when unsupported features are requested. */
#define CENTRAL_LINK_COUNT 0 /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT 1 /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#define DEVICE_NAME "Nordic_GET_RSSI" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS 180 /**< The advertising timeout (in units of seconds). */
#define APP_TIMER_PRESCALER 0 /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE 4 /**< Size of timer operation queues. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
static ble_nus_t m_nus; /**< Structure to identify the Nordic UART Service. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}}; /**< Universally unique service identifier. */
uint8_t cr = 'F';
#if defined(BOARD_PCA10031)
#define SCAN_LED_PIN_NO LED_RGB_BLUE /**< Is on when device is scanning. */
#define CONNECTED_LED_PIN_NO LED_RGB_GREEN /**< Is on when device has connected. */
#define ASSERT_LED_PIN_NO LED_RGB_RED /**< Is on when application has asserted. */
#else
#define SCAN_LED_PIN_NO BSP_BOARD_LED_1 /**< Is on when device is scanning. */
#define CONNECTED_LED_PIN_NO BSP_BOARD_LED_2 /**< Is on when device has connected. */
#define ASSERT_LED_PIN_NO BSP_BOARD_LED_3 /**< Is on when application has asserted. */
// Start for Bluetooth Scan
//static bool m_whitelist_scan = true; /**< Scan mode used by application. */
//static dm_application_instance_t m_dm_app_id; /**< Application identifier. */
typedef enum
BLE_NO_SCAN, /**< No advertising running. */
BLE_WHITELIST_SCAN, /**< Advertising with whitelist. */
BLE_FAST_SCAN, /**< Fast advertising running. */
} ble_advertising_mode_t;
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_TIMEOUT 0x0000 /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Determines maximum connection interval in milliseconds. */
#define SLAVE_LATENCY 0 /**< Determines slave latency in terms of connection events. */
#define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 milliseconds. */
//#define NRF_LOG_MODULE_NAME "APP"
/** @brief Scan parameters requested for scanning and connection. */
static const ble_gap_scan_params_t m_scan_params =
.active = 0,
.interval = SCAN_INTERVAL,
.window = SCAN_WINDOW,
.timeout = SCAN_TIMEOUT,
#if (NRF_SD_BLE_API_VERSION == 2)
.selective = 0,
.p_whitelist = NULL,
.use_whitelist = 0,
.adv_dir_report = 0,
// Stop for Bluetooth Scan
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_nus Nordic UART Service structure.
* @param[in] p_data Data to be send to UART module.
* @param[in] length Length of the data.
/**@snippet [Handling the data received over BLE] */
static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
for (uint32_t i = 0; i < length; i++)
while (app_uart_put(p_data[i]) != NRF_SUCCESS);
while (app_uart_put('\r') != NRF_SUCCESS);
while (app_uart_put('\n') != NRF_SUCCESS);
uint32_t err_code;
ble_nus_init_t nus_init;
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
/**@brief Function for the application's SoftDevice event handler.
* @param[in] p_ble_evt SoftDevice event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
uint32_t err_code;
//int8_t rssi_value;
//ble_gap_addr_t peer_address;
uint8_t cntData;
uint8_t devNameBuff[25], AdvData[31];
const ble_gap_evt_t * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_ADV_REPORT:
//if (is_uuid_present(&m_tb_uuid, p_adv_report))
if (p_ble_evt->evt.gap_evt.params.adv_report.scan_rsp == 0)
//printf("BLE_GAP_EVT_ADV_REPORT\r\n");
//peer_address = p_ble_evt->evt.gap_evt.params.scan_req_report.peer_addr;
//rssi_value = p_ble_evt->evt.gap_evt.params.scan_req_report.rssi;
const ble_gap_evt_adv_report_t * p_adv_report = &p_gap_evt->params.adv_report;
for(cntData=0 ; cntData<31;cntData++)
AdvData[cntData] = p_adv_report->data[cntData];
uint16_t plen;
printf("device name: ");
for(cntData=0 ; cntData<25;cntData++)
printf("%02x ",devNameBuff[cntData]);
printf("\n");
//printf("Found target %02x%02x%02x%02x%02x%02x\n\tRSSI Power: %i dBm\n\t dlen: %02x\n \tscan_rsp: %i\n",
// p_adv_report->peer_addr.addr[0],p_adv_report->peer_addr.addr[1],
// p_adv_report->peer_addr.addr[2],p_adv_report->peer_addr.addr[3],
// p_adv_report->peer_addr.addr[4],p_adv_report->peer_addr.addr[5],
// p_adv_report->rssi,
// p_adv_report->dlen,
// p_adv_report->scan_rsp
printf("RSSI Power: %i dBm\n\t dlen: %02x\n \tscan_rsp: %i\n",
p_adv_report->rssi,
p_adv_report->dlen,
err_code = sd_ble_gap_device_name_get(devNameBuff,&plen);
printf("\n");
// for(cntData=0 ; cntData<31;cntData++)
// printf("AdvData[%i]: %02x\n",cntData,AdvData[cntData]);
// err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
// &m_scan_params,
// &m_connection_param);
//err_code = 0;
// if (err_code == NRF_SUCCESS)
// // scan is automatically stopped by the connect
// printf("Connecting to target %02x%02x%02x%02x%02x%02x\r\n",
// p_adv_report->peer_addr.addr[1],
// p_adv_report->peer_addr.addr[3],
// p_adv_report->peer_addr.addr[5]
//sd_ble_gap_rssi_start(p_gap_evt->conn_handle,3,0); // Get RSSI
} break; // BLE_GAP_EVT_RSSI_CHANGED
case BLE_GAP_EVT_RSSI_CHANGED:
//NRF_LOG_INFO("Rssi is %d with conn_handle: %d\n",p_gap_evt->params.rssi_changed.rssi,p_gap_evt->conn_handle);
case BLE_GAP_EVT_SCAN_REQ_REPORT:
printf("BLE_GAP_EVT_SCAN_REQ_REPORT\r\n");
case BLE_GAP_EVT_CONNECTED:
break; // BLE_GAP_EVT_CONNECTED
break; // BLE_GAP_EVT_DISCONNECTED
// Pairing not supported
break; // BLE_GAP_EVT_SEC_PARAMS_REQUEST
break; // BLE_GATTS_EVT_SYS_ATTR_MISSING
case BLE_GATTC_EVT_TIMEOUT:
break; // BLE_GATTC_EVT_TIMEOUT
case BLE_GATTS_EVT_TIMEOUT:
break; // BLE_GATTS_EVT_TIMEOUT
case BLE_EVT_USER_MEM_REQUEST:
err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
break; // BLE_EVT_USER_MEM_REQUEST
case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
ble_gatts_evt_rw_authorize_request_t req;
ble_gatts_rw_authorize_reply_params_t auth_reply;
req = p_ble_evt->evt.gatts_evt.params.authorize_request;
if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ) ||
(req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
(req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
&auth_reply);
} break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
err_code = sd_ble_gatts_exchange_mtu_reply(p_ble_evt->evt.gatts_evt.conn_handle,
NRF_BLE_MAX_MTU_SIZE);
break; // BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST
// No implementation needed.
/**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice
* event handler.
* @details This function is called from the SoftDevice event interrupt handler after a
* SoftDevice event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
ble_conn_params_on_ble_evt(p_ble_evt);
ble_nus_on_ble_evt(&m_nus, p_ble_evt);
ble_advertising_on_ble_evt(p_ble_evt);
bsp_btn_ble_on_ble_evt(p_ble_evt);
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
uint32_t err_code;
nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
// Initialize SoftDevice.
SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
ble_enable_params_t ble_enable_params;
err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
PERIPHERAL_LINK_COUNT,
&ble_enable_params);
//Check the ram settings against the used number of links
CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
// Enable BLE stack.
ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
err_code = softdevice_enable(&ble_enable_params);
// Subscribe for BLE events.
err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
printf("Entered sleep mode ");
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
err_code = ble_advertising_restart_without_whitelist();
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' i.e '\r\n' (hex 0x0D) or if the string has reached a length of
* @ref NUS_MAX_DATA_LENGTH.
/**@snippet [Handling the data received over UART] */
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
printf("Data Received\r\n");
for (uint8_t i = 0; i < index; i++)
app_uart_put(data_array[i]);
err_code = ble_nus_string_send(&m_nus, data_array, index);
printf("Data Error\r\n");
index = 0;
printf("APP_UART_COMMUNICATION_ERROR\r\n");
case APP_UART_FIFO_ERROR:
printf("APP_UART_FIFO_ERROR\r\n");
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
APP_UART_FLOW_CONTROL_DISABLED,
false,
UART_BAUDRATE_BAUDRATE_Baud115200
APP_UART_FIFO_INIT( &comm_params,
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
uint32_t err_code;
ble_advdata_t advdata;
ble_advdata_t scanrsp;
ble_adv_modes_config_t options;
// Build advertising data struct to pass into @ref ble_advertising_init.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_FULL_NAME;
advdata.include_appearance = false;
advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
memset(&scanrsp, 0, sizeof(scanrsp));
scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
scanrsp.uuids_complete.p_uuids = m_adv_uuids;
memset(&options, 0, sizeof(options));
options.ble_adv_fast_enabled = true;
options.ble_adv_fast_interval = APP_ADV_INTERVAL;
options.ble_adv_fast_timeout = APP_ADV_TIMEOUT_IN_SECONDS;
err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
bsp_event_handler);
/**@brief Function for placing the application in low power state while waiting for events.
static void power_manage(void)
uint32_t err_code = sd_app_evt_wait();
/**@brief Function for initiating scanning.
static void scan_start(void)
ret_code_t err_code;
printf("Scanning ...\r\n");
// Turn on the LED to signal scanning.
bsp_board_led_on(SCAN_LED_PIN_NO);
(void) sd_ble_gap_scan_stop();
err_code = sd_ble_gap_scan_start(&m_scan_params);
// It is okay to ignore this error since we are stopping the scan anyway.
NRF_LOG_INFO("Scan Error !!!\r\n");
NRF_LOG_INFO("Scanning\r\n");
bsp_board_led_off(SCAN_LED_PIN_NO);
//nrf_gpio_pin_set(SCAN_LED_PIN_NO);
printf("Scanning done\r\n");
/**@brief Function for initiating advertising and scanning.
static void adv_scan_start(void)
uint32_t count;
//check if there are no flash operations in progress
err_code = fs_queued_op_count_get(&count);
if (count == 0)
// Start scanning for peripherals and initiate connection to devices which
// advertise Heart Rate or Running speed and cadence UUIDs.
scan_start();
// Start advertising.
err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
NRF_LOG_INFO("Advertising\r\n");
} else
printf("No Scanning\r\n");
/**@brief Application main function.
uint32_t err_code;
bool erase_bonds;
/* Configure board. */
bsp_board_leds_init();
// Initialize.
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
uart_init();
ble_stack_init();
gap_params_init();
services_init();
advertising_init();
conn_params_init();
printf("\r\n");
printf("Button 1 for Wakeup\r\n");
printf("UART Start!\r\n");
bsp_board_led_on(ASSERT_LED_PIN_NO);
//bsp_board_led_invert(i);
// with devices that advertise NUS UUID.
//scan_start();
//scan_all_periph();
//adv_scan_start();
scan_start();
while (true)
while(app_uart_get(&cr) != NRF_SUCCESS);
while(app_uart_put(cr) != NRF_SUCCESS);
if (cr == 'q' || cr == 'Q')
printf(" \n\rExit!\n\r");
while (cr != 'q' || cr != 'Q')
//power_manage();
//scan_start();
// Enter main loop.
//for (;;)
// power_manage();
