TWI doesn't get past event check loop
I'm working on TWI with nrf52832 dev board, using examples from SDK 16. Here's the code:
#define I2C_INSTANCE_ID 0
#define I2C_ADDRESS 0x55
#define TWI0_SCL_PIN 23
#devine TWI0_SDA_PIN 22
static const nrfx_twi_t m_twi0 = NRFX_TWI_INSTANCE(I2C_INSTANCE_ID);
void twi0_handler(nrfx_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRFX_TWI_EVT_DONE:
            m_xfer_done = true;
void twi0_init(void)
    ret_code_t err_code;
    const nrfx_twi_config_t twi0_config = {
       .scl                = TWI0_SCL_PIN,                    //Pin 23
       .sda                = TWI0_SDA_PIN,                    //Pin 22
       .frequency          = TWI_DEFAULT_CONFIG_FREQUENCY,    //100 kHz
       .interrupt_priority = TWI_DEFAULT_CONFIG_IRQ_PRIORITY, //6
       .hold_bus_uninit    = false
    err_code = nrfx_twi_init(&m_twi0, &twi0_config, twi0_handler, NULL);
    nrfx_twi_enable(&m_twi0);
void twi0_data_transfer(void)
    APP_ERROR_CHECK(nrfx_twi_tx(&m_twi0, I2C_ADDRESS, m_twi_tx_buf0, m_twi_length0, false));
    while (!m_xfer_done);  //Wait until the tranfser is done
I see no activity on the logic analyser and the application gets stuck in the TX while loop.
I get similar results when running the "TWI scanner" example. The example gets stuck at the "while (!nrf_twim_event_check(p_twim, evt_to_wait))", and no activity appears on the logic analyser. The RTT output only gets to "<info> app: TWI scanner started.", but nothing else happens.
What am I doing wrong here?
