I think I have properly configured my application to authorize reads on characteristic, yet I do not see an event generated. I get write events, but I don't get read events. Can anyone see what I'm doing wrong, or not doing at all? Here are some code snippets from my application.
I create custom services as follows:
ret_code_t ble_vpe_init(ble_vpe_t * p_vpe, ble_vpe_init_t * p_vpe_init) { ret_code_t err_code; ble_uuid_t ble_uuid; ble_uuid128_t vpe_base_uuid = VECTOR_PUMP_BASE_UUID; VERIFY_PARAM_NOT_NULL(p_vpe); VERIFY_PARAM_NOT_NULL(p_vpe_init); /**@snippet [Adding proprietary Service to the SoftDevice] */ // Add a custom base UUID. err_code = sd_ble_uuid_vs_add(&vpe_base_uuid, &p_vpe->uuid_type); VERIFY_SUCCESS(err_code); ble_uuid.type = p_vpe->uuid_type; ble_uuid.uuid = BLE_UUID_VECTOR_PUMP; // Add service err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_vpe->service_handle); VERIFY_SUCCESS(err_code); // Add the characteristics err_code = vpe_command_char_add(p_vpe); return err_code; }
I add the custom characteristic to the service as follows:
static ret_code_t vpe_command_char_add(ble_vpe_t *p_vpe) { ret_code_t err_code; uint8_t init_value = 0; ble_uuid_t char_uuid; ble_uuid128_t base_uuid = COMMAND_BASE_UUID; ble_add_char_user_desc_t user_desc; ble_gatts_attr_md_t attr_md; ble_gatts_char_md_t char_md; ble_gatts_attr_t attr_char_value; // Add a custom base UUID. err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type); VERIFY_SUCCESS(err_code); memset(&char_md, 0, sizeof(char_md)); char_md.char_props.read = 1; char_md.char_props.write = 1; ble_gatts_attr_md_t cccd_md; memset(&cccd_md, 0, sizeof(cccd_md)); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm); cccd_md.vloc = BLE_GATTS_VLOC_STACK; char_md.p_cccd_md = &cccd_md; char_md.char_props.notify = 1; memset(&attr_md, 0, sizeof(attr_md)); attr_md.rd_auth = 1; attr_md.wr_auth = 0; attr_md.vlen = 0; attr_md.vloc = BLE_GATTS_VLOC_STACK; BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm); memset(&attr_char_value, 0, sizeof(attr_char_value)); char_uuid.uuid = BLE_UUID_VECTOR_PUMP; attr_char_value.p_uuid = &char_uuid; attr_char_value.p_attr_md = &attr_md; attr_char_value.init_len = BLE_COMMAND_CHAR_LEN; attr_char_value.init_offs = 0; attr_char_value.max_len = BLE_COMMAND_CHAR_LEN; attr_char_value.p_value = &init_value; err_code = sd_ble_gatts_characteristic_add(p_vpe->service_handle, &char_md, &attr_char_value, &p_vpe->command_char_handle); VERIFY_SUCCESS(err_code); return err_code; }
I get write events, but I don't get any read events. My event handler is as follows:
void ble_vpe_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context) { if ((p_context == NULL) || (p_ble_evt == NULL)) { return; } ble_vpe_t * p_vpe = (ble_vpe_t *)p_context; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_CONNECTED: on_connect(p_vpe, p_ble_evt); break; case BLE_GATTS_EVT_WRITE: on_write(p_vpe, p_ble_evt); break; case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST: if((p_ble_evt->evt.gatts_evt.params.authorize_request.type) == BLE_GATTS_AUTHORIZE_TYPE_READ){ NRF_LOG_INFO(0,"BLE Read request. \n"); on_read(p_vpe, p_ble_evt); } //If there is a write request else if((p_ble_evt->evt.gatts_evt.params.authorize_request.type) == BLE_GATTS_AUTHORIZE_TYPE_WRITE){ NRF_LOG_INFO(0,"BLE Write request. \n"); on_write(p_vpe, p_ble_evt); } break; default: // No implementation needed. break; } }
