Issue with "cJSON_Parse failed :" in lte_ble_gateway application
Hi Team,
We are working on the nRF9160 DK. We are integrating the central_uart code into the lte_ble_gateway, As we integrated for the purpose to use NUS(nordic uart service). As the project is compiled successfully, But at run time i observed the below issue in the LTE link monitor
Please find the issue in the highlighted region
Please let me know that do i missed any configs or please point me to the solution why this issue arises
venkatesh
  • Pretty sure there is a missing "}" in the JSON. Please copy and paste AS TEXT and not as image.
    Please find the text as requested
    cJSON_Parse failed: {"desired":{"pairing":{"state":"paired","topics":{"d2c":"prod/05f78b98-f918-44bb-b4ce-f55604c81c6d/m/d/nrf-352656100373185/d2c","c2d":"prod/05f78b98-f918-44bb-b4ce-f55604c81c6d/m/d/nrf-352656100373185/c2d"}},"nrfcloud_mqtt_topic_prefix":"prod/05f78b98-f918-44bb-b4ce-f55604c81c6d/"},"config":{"GPS":{"enable":false}}}\x0D\x0A 2020-07-02T10:08:28.471Z DEBUG modem << E: nrf_cloud_decode_requested_state Failed -2\x0D\x0A 2020-07-02T10:08:28.475Z DEBUG modem << E: Handler failed! state: 5, type: 3\x0D\x0A 2020-07-02T10:08:28.530Z DEBUG modem << E: nct_input: failed -2\x0D\x0A
    venkatesh
  • Thanks, I miscounted { } above. Unfortunately that also means I have absolutely zero idea why the JSON parse step failed. :-(
  • Could you debug your application and look at the function
    • cJSON_Parse() (<..>\ncs\v1.3.0\nrf\subsys\net\lib\nrf_cloud\src\nrf_cloud_codec.c)
      • →cJSON_ParseWithOpts() (<..>\ncs\v1.3.0\nrf\ext\cjson\cJSON.c):
    CJSON_PUBLIC(cJSON *) cJSON_ParseWithOpts(const char *value, const char **return_parse_end, cJSON_bool require_null_terminated)
        parse_buffer buffer = { 0, 0, 0, 0, { 0, 0, 0 } };
        cJSON *item = NULL;
        /* reset error position */
        global_error.json = NULL;
        global_error.position = 0;
        if (value == NULL)
            goto fail;
        buffer.content = (const unsigned char*)value;
        buffer.length = strlen((const char*)value) + sizeof("");
        buffer.offset = 0;
        buffer.hooks = global_hooks;
        item = cJSON_New_Item(&global_hooks);
        if (item == NULL) /* memory fail */
            goto fail;
        if (!parse_value(item, buffer_skip_whitespace(skip_utf8_bom(&buffer))))
            /* parse failure. ep is set. */
            goto fail;
        /* if we require null-terminated JSON without appended garbage, skip and then check for a null terminator */
        if (require_null_terminated)
            buffer_skip_whitespace(&buffer);
            if ((buffer.offset >= buffer.length) || buffer_at_offset(&buffer)[0] != '\0')
                goto fail;
        if (return_parse_end)
            *return_parse_end = (const char*)buffer_at_offset(&buffer);
        return item;
    fail:
        if (item != NULL)
            cJSON_Delete(item);
        if (value != NULL)
            error local_error;
            local_error.json = (const unsigned char*)value;
            local_error.position = 0;
            if (buffer.offset < buffer.length)
                local_error.position = buffer.offset;
            else if (buffer.length > 0)
                local_error.position = buffer.length - 1;
            if (return_parse_end != NULL)
                *return_parse_end = (const char*)local_error.json + local_error.position;
            global_error = local_error;
        return NULL;
    Put breakpoints on all "goto fail" to see where the error comes from.
    Simon
