nRF52832 Custom board not advertising after flashing Custom Bootloader (Buttonless)
I followed this page, downloaded SDK 15.1.0 and I was able to compile and build Custom bootloader (after adding custom board, also changed in makefile as well) for Custom board of nRF52832 in the provided secure bootloader option using arm gcc.
But, after successfully flashing softdevice and bootloader on the board using nRF gostudio, nRF52832 stops advertising, but i can see the led on. But, I can't see my device in nRF connect. I also tried flashing softdevice, bootloader and application in the respective order, all were successfully flashed but no advertisement as well and I can see led on only after holding buttonpress.
My plan is to implement buttonless feature for the bootloader and hence have disabled NRF_BL_DFU_ENTER_METHOD_BUTTON and enabled NRF_BL_DFU_ENTER_METHOD_BUTTONLESS in sdk_config.h and have set "enter_buttonless_dfu" in nrf_dfu_settings_init() of nrf_dfu_settings.c.  Also, I want to know even though I have disabled NRF_BL_DFU_ENTER_METHOD_BUTTON, why do I have to define NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN (I get error if I don't define) ?
Could anyone guide further regarding the issue and let me know, if I am doing something wrong?
Nagarjun CS
  • Nagarjun said:
    But, after i corrected I get no debug messages after flash.
     Did you build the project without any errors and was is flashed successfully? What do you observe on the board, is it advertising?
  • Okay, starting from building from building bootloader, i built the secure_bootloader project with no errors (after adding custom_board.h and enabling buttonless features in sdk_config) and flashed the soft device and bootloader succesfully. Now, the device advertises successfully in DFU mode, there is no problem there.
    But, after I flash my application (built with no errors)even though flashing is succesfull the device shutsdown without advertising. I checked if memory adjustements have to be so,i attahced debugger, but I see no debug results.
     Seems that maybe you are overwriting the application due to the flash memory settings.
    • Could you change the FLASH settings to what is used in a SDK example, for example the dfu secure example?
    • You have obviously changed the Link count in the config file. What other changes have you done? A specific reason for why you changed this?
    • Have you tried a unmodified SDK DFU example?
  • Thanks alot issue has been resolved, it was mainly because, when i downloaded SDK 15.x.x i did not pay much heed to migration document, that was the problem regarding advertisement issue. I am using older SDK everything seems fine now.
    To answer your questions:
    1. I was using same flash setting than I got debug suggestion to change it.
    2. I just added disabled DFU enter through button press and enabled buttonless method and as well adjusted clock source as suggested above.
    3. I did it succesfully flashed but no advertisement.
    Nagarjun CS
