nRF91 How to use Google's primary and backup root CA on the modem?
I want to connect to Google Cloud IoT with a modified asset_tracker and want the TLS done by the modem like in asset_tracker.
Google has a primary and a backup root CA for IoT and they may switch between the primary and backup certificates at any time without notice
See here cloud.google.com/.../mqtt-bridge
Is it enough to install these certificates (in the right converted form) as type 0 with different sec_tags on the modem?
I hope :)
With kind regards,
Árpád
  • Currently, a huge portion of the support team (including many of the experts on nRF9160) is on summer vacation, and you may experience delayed answers. My apologies for that.
    I will try to provide you with an answer within this week.
    Simon
  • Hi Simon,
    this is not a big problem for me now: this one is much bigger :)
    Árpád
  • Hi Simon,
    update: The different root CAs should come to different sec_tags installed on the modem and that sec_tags must be referenced from the application software. That's clear me now.
    But I have a problem when I try to verify the peer in the TLS connection:
    struct mqtt_sec_config *tls_config =  &client->transport.tls.config;
    tls_config->peer_verify = MQTT_TRANSPORT_SECURE;
    results in EOPNOTSUPP 95 (Operation not supported on socket)
    When I use
    tls_config->peer_verify = TLS_PEER_VERIFY_NONE;
    I can connect.
    The peer verification works on Amazon with its sha256WithRSAEncryption signature. Google's signature for mqtt.2030.ltsapis.goog is an ecdsa-with-SHA256 signature.
    Is that not supported?
    Is this a bug in the modem software?
    I use the latest one (mfw_nrf9160_1.2.0.zip).
    With best regards,
    Árpád
  • I am currently looking into your questions. In the meanwhile, you should check out this blog, if you haven't seen it already.
    Simon
  • Hi Simon,
    thank you for your reply. From that blog code (nRF9160DKtoGoogleCloud.zip) is the
    workaround. See the function gcloud.c:gcloud_provision
    tls_config.peer_verify = 0;
    which is the same.
    The defined ROOT_CERT at the begin of the file is wrong. It's a self signed certificate, not the primary or the backup certificate of Google for mqtt.2030.ltsapis.goog:
    openssl x509 -in unknown_cert_from_How_to_connect_nRF9160_DK_to_Google_Cloud.pem -text
    Certificate:
        Data:
            Version: 3 (0x2)
            Serial Number:
                eb:e3:e0:f5:5f:02:0a:a3
            Signature Algorithm: ecdsa-with-SHA256
            Issuer: CN = nrf91-marte
            Validity
                Not Before: Apr  5 11:15:17 2019 GMT
                Not After : Mar  2 11:15:17 4757 GMT
            Subject: CN = nrf91-marte
            Subject Public Key Info:
                Public Key Algorithm: id-ecPublicKey
                    Public-Key: (256 bit)
                    pub:
                        04:0a:bc:a2:d9:16:1a:7a:1c:a5:d0:31:96:7a:49:
                        75:59:fa:10:16:f5:59:b4:27:65:72:c5:69:8c:ec:
                        31:e5:d6:18:52:08:3b:4d:a1:59:3b:da:49:43:c8:
                        d7:13:6c:d1:00:7c:73:72:14:f6:80:61:0d:79:11:
                        35:4d:8d:aa:2d
                    ASN1 OID: prime256v1
                    NIST CURVE: P-256
            X509v3 extensions:
                X509v3 Subject Key Identifier:
                    4B:02:13:B7:DF:90:80:77:6F:34:23:FA:95:42:68:8C:D3:B9:DD:F1
                X509v3 Authority Key Identifier:
                    keyid:4B:02:13:B7:DF:90:80:77:6F:34:23:FA:95:42:68:8C:D3:B9:DD:F1
                X509v3 Basic Constraints:
                    CA:TRUE
             30:45:02:20:5d:a4:40:ee:c2:aa:7e:f7:00:d9:b0:05:d8:06:
             03:5c:bf:28:63:a9:39:4e:08:ff:2c:05:2c:4b:bc:b6:b3:94:
             02:21:00:f3:ff:d4:5a:db:4c:46:49:9a:ca:58:21:c3:79:a0:
             b1:81:86:2a:4d:7b:ad:8f:b8:8f:ee:26:19:4c:2f:0e:7c
    -----BEGIN CERTIFICATE-----
    MIIBdTCCARugAwIBAgIJAOvj4PVfAgqjMAoGCCqGSM49BAMCMBYxFDASBgNVBAMM
    C25yZjkxLW1hcnRlMCAXDTE5MDQwNTExMTUxN1oYDzQ3NTcwMzAyMTExNTE3WjAW
    MRQwEgYDVQQDDAtucmY5MS1tYXJ0ZTBZMBMGByqGSM49AgEGCCqGSM49AwEHA0IA
    BAq8otkWGnocpdAxlnpJdVn6EBb1WbQnZXLFaYzsMeXWGFIIO02hWTvaSUPI1xNs
    0QB8c3IU9oBhDXkRNU2Nqi2jUDBOMB0GA1UdDgQWBBRLAhO335CAd280I/qVQmiM
    07nd8TAfBgNVHSMEGDAWgBRLAhO335CAd280I/qVQmiM07nd8TAMBgNVHRMEBTAD
    AQH/MAoGCCqGSM49BAMCA0gAMEUCIF2kQO7Cqn73ANmwBdgGA1y/KGOpOU4I/ywF
    LEu8trOUAiEA8//UWttMRkmaylghw3mgsYGGKk17rY+4j+4mGUwvDnw=
    -----END CERTIFICATE-----
    Look at the Issuer.
    In my code I use the primary certificate of Google for mqtt.2030.ltsapis.goog uploaded to the modem together with my public certificate and private key to a definite sec_tag.
    The usage is exact of nrf_cloud_transport.c:nct_provision but with my sec_tag and google's hostname:
    static int nct_provision(void)
    	static sec_tag_t sec_tag_list[] = { CONFIG_NRF_CLOUD_SEC_TAG };
    	nct.tls_config.peer_verify = 2;
    	nct.tls_config.cipher_count = 0;
    	nct.tls_config.cipher_list = NULL;
    	nct.tls_config.sec_tag_count = ARRAY_SIZE(sec_tag_list);
    	nct.tls_config.sec_tag_list = sec_tag_list;
    	nct.tls_config.hostname = NRF_CLOUD_HOSTNAME;
    That should be enough to work, I think, but doesn't.
    The only difference what I see is the signature algorithm: nRF Cloud (Amazon IoT) uses sha256WithRSAEncryption, Google's signature for mqtt.2030.ltsapis.goog is an ecdsa-with-SHA256 signature.
    Look at the Signature Algorithm property of the following two root CA certificates:
    openssl x509 -in nrf_cloud_ca_certificate.pem -text
    Certificate:
        Data:
            Version: 3 (0x2)
            Serial Number:
                06:6c:9f:cf:99:bf:8c:0a:39:e2:f0:78:8a:43:e6:96:36:5b:ca
            Signature Algorithm: sha256WithRSAEncryption
            Issuer: C = US, O = Amazon, CN = Amazon Root CA 1
            Validity
                Not Before: May 26 00:00:00 2015 GMT
                Not After : Jan 17 00:00:00 2038 GMT
            Subject: C = US, O = Amazon, CN = Amazon Root CA 1
                Public Key Algorithm: rsaEncryption
                    RSA Public-Key: (2048 bit)
                    Modulus:
                        00:b2:78:80:71:ca:78:d5:e3:71:af:47:80:50:74:
                        7d:6e:d8:d7:88:76:f4:99:68:f7:58:21:60:f9:74:
                        84:01:2f:ac:02:2d:86:d3:a0:43:7a:4e:b2:a4:d0:
                        36:ba:01:be:8d:db:48:c8:07:17:36:4c:f4:ee:88:
                        23:c7:3e:eb:37:f5:b5:19:f8:49:68:b0:de:d7:b9:
                        76:38:1d:61:9e:a4:fe:82:36:a5:e5:4a:56:e4:45:
                        e1:f9:fd:b4:16:fa:74:da:9c:9b:35:39:2f:fa:b0:
                        20:50:06:6c:7a:d0:80:b2:a6:f9:af:ec:47:19:8f:
                        50:38:07:dc:a2:87:39:58:f8:ba:d5:a9:f9:48:67:
                        30:96:ee:94:78:5e:6f:89:a3:51:c0:30:86:66:a1:
                        45:66:ba:54:eb:a3:c3:91:f9:48:dc:ff:d1:e8:30:
                        2d:7d:2d:74:70:35:d7:88:24:f7:9e:c4:59:6e:bb:
                        73:87:17:f2:32:46:28:b8:43:fa:b7:1d:aa:ca:b4:
                        f2:9f:24:0e:2d:4b:f7:71:5c:5e:69:ff:ea:95:02:
                        cb:38:8a:ae:50:38:6f:db:fb:2d:62:1b:c5:c7:1e:
                        54:e1:77:e0:67:c8:0f:9c:87:23:d6:3f:40:20:7f:
                        20:80:c4:80:4c:3e:3b:24:26:8e:04:ae:6c:9a:c8:
                        aa:0d
                    Exponent: 65537 (0x10001)
            X509v3 extensions:
                X509v3 Basic Constraints: critical
                    CA:TRUE
                X509v3 Key Usage: critical
                    Digital Signature, Certificate Sign, CRL Sign
                    84:18:CC:85:34:EC:BC:0C:94:94:2E:08:59:9C:C7:B2:10:4E:0A:08
             98:f2:37:5a:41:90:a1:1a:c5:76:51:28:20:36:23:0e:ae:e6:
             28:bb:aa:f8:94:ae:48:a4:30:7f:1b:fc:24:8d:4b:b4:c8:a1:
             97:f6:b6:f1:7a:70:c8:53:93:cc:08:28:e3:98:25:cf:23:a4:
             f9:de:21:d3:7c:85:09:ad:4e:9a:75:3a:c2:0b:6a:89:78:76:
             44:47:18:65:6c:8d:41:8e:3b:7f:9a:cb:f4:b5:a7:50:d7:05:
             2c:37:e8:03:4b:ad:e9:61:a0:02:6e:f5:f2:f0:c5:b2:ed:5b:
             b7:dc:fa:94:5c:77:9e:13:a5:7f:52:ad:95:f2:f8:93:3b:de:
             8b:5c:5b:ca:5a:52:5b:60:af:14:f7:4b:ef:a3:fb:9f:40:95:
             6d:31:54:fc:42:d3:c7:46:1f:23:ad:d9:0f:48:70:9a:d9:75:
             78:71:d1:72:43:34:75:6e:57:59:c2:02:5c:26:60:29:cf:23:
             19:16:8e:88:43:a5:d4:e4:cb:08:fb:23:11:43:e8:43:29:72:
             62:a1:a9:5d:5e:08:d4:90:ae:b8:d8:ce:14:c2:d0:55:f2:86:
             f6:c4:93:43:77:66:61:c0:b9:e8:41:d7:97:78:60:03:6e:4a:
             72:ae:a5:d1:7d:ba:10:9e:86:6c:1b:8a:b9:59:33:f8:eb:c4:
             90:be:f1:b9
    MIIDQTCCAimgAwIBAgITBmyfz5m/jAo54vB4ikPmljZbyjANBgkqhkiG9w0BAQsF
    ADA5MQswCQYDVQQGEwJVUzEPMA0GA1UEChMGQW1hem9uMRkwFwYDVQQDExBBbWF6
    b24gUm9vdCBDQSAxMB4XDTE1MDUyNjAwMDAwMFoXDTM4MDExNzAwMDAwMFowOTEL
    MAkGA1UEBhMCVVMxDzANBgNVBAoTBkFtYXpvbjEZMBcGA1UEAxMQQW1hem9uIFJv
    b3QgQ0EgMTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBALJ4gHHKeNXj
    ca9HgFB0fW7Y14h29Jlo91ghYPl0hAEvrAIthtOgQ3pOsqTQNroBvo3bSMgHFzZM
    9O6II8c+6zf1tRn4SWiw3te5djgdYZ6k/oI2peVKVuRF4fn9tBb6dNqcmzU5L/qw
    IFAGbHrQgLKm+a/sRxmPUDgH3KKHOVj4utWp+UhnMJbulHheb4mjUcAwhmahRWa6
    VOujw5H5SNz/0egwLX0tdHA114gk957EWW67c4cX8jJGKLhD+rcdqsq08p8kDi1L
    93FcXmn/6pUCyziKrlA4b9v7LWIbxcceVOF34GfID5yHI9Y/QCB/IIDEgEw+OyQm
    jgSubJrIqg0CAwEAAaNCMEAwDwYDVR0TAQH/BAUwAwEB/zAOBgNVHQ8BAf8EBAMC
    AYYwHQYDVR0OBBYEFIQYzIU07LwMlJQuCFmcx7IQTgoIMA0GCSqGSIb3DQEBCwUA
    A4IBAQCY8jdaQZChGsV2USggNiMOruYou6r4lK5IpDB/G/wkjUu0yKGX9rbxenDI
    U5PMCCjjmCXPI6T53iHTfIUJrU6adTrCC2qJeHZERxhlbI1Bjjt/msv0tadQ1wUs
    N+gDS63pYaACbvXy8MWy7Vu33PqUXHeeE6V/Uq2V8viTO96LXFvKWlJbYK8U90vv
    o/ufQJVtMVT8QtPHRh8jrdkPSHCa2XV4cdFyQzR1bldZwgJcJmApzyMZFo6IQ6XU
    5MsI+yMRQ+hDKXJioaldXgjUkK642M4UwtBV8ob2xJNDd2ZhwLnoQdeXeGADbkpy
    rqXRfboQnoZsG4q5WTP468SQvvG5
    openssl x509 -in mqtt_2030_ltsapis_goog_PRIMARY.pem -text
    Certificate:
        Data:
            Version: 3 (0x2)
            Serial Number:
                01:f0:f7:9d:59:dd:6e:50:f7:42:73:71:50
            Issuer: C = US, O = Google Trust Services LLC, CN = GTS LTSR
            Validity
                Not Before: Nov  1 00:00:42 2018 GMT
                Not After : Nov  1 00:00:42 2042 GMT
            Subject: C = US, O = Google Trust Services LLC, CN = GTS LTSR
                    pub:
                        04:cd:f1:8c:8e:da:ef:b2:09:0a:19:77:00:24:50:
                        db:f9:73:77:68:91:f5:0b:7e:b0:3a:40:98:05:57:
                        65:cc:b8:43:6d:41:92:06:e4:75:0e:4b:a8:c5:9f:
                        c7:f4:c9:29:55:78:e4:42:c6:a1:72:8c:32:72:46:
                        7f:3a:77:e2:24
                    NIST CURVE: P-256
            X509v3 extensions:
                    CA:TRUE
                    3E:FE:FF:CC:52:EB:BF:34:3E:3D:F3:40:D0:E4:25:B1:5F:B8:BB:52
             30:45:02:21:00:f2:ae:7f:f5:6d:04:7a:86:c3:74:d4:c1:42:
             2a:ed:37:da:13:1a:77:6c:7e:db:8c:20:66:55:72:6e:a5:3f:
             45:02:20:6b:d1:29:82:b6:cb:a4:9a:21:a0:a5:a8:e3:7f:f8:
             05:8a:01:8c:df:81:7d:d3:6d:5b:09:6b:35:31:b2:f4:48
    MIIBxTCCAWugAwIBAgINAfD3nVndblD3QnNxUDAKBggqhkjOPQQDAjBEMQswCQYD
    VQQGEwJVUzEiMCAGA1UEChMZR29vZ2xlIFRydXN0IFNlcnZpY2VzIExMQzERMA8G
    A1UEAxMIR1RTIExUU1IwHhcNMTgxMTAxMDAwMDQyWhcNNDIxMTAxMDAwMDQyWjBE
    MQswCQYDVQQGEwJVUzEiMCAGA1UEChMZR29vZ2xlIFRydXN0IFNlcnZpY2VzIExM
    QzERMA8GA1UEAxMIR1RTIExUU1IwWTATBgcqhkjOPQIBBggqhkjOPQMBBwNCAATN
    8YyO2u+yCQoZdwAkUNv5c3dokfULfrA6QJgFV2XMuENtQZIG5HUOS6jFn8f0ySlV
    eORCxqFyjDJyRn86d+Iko0IwQDAOBgNVHQ8BAf8EBAMCAYYwDwYDVR0TAQH/BAUw
    AwEB/zAdBgNVHQ4EFgQUPv7/zFLrvzQ+PfNA0OQlsV+4u1IwCgYIKoZIzj0EAwID
    SAAwRQIhAPKuf/VtBHqGw3TUwUIq7TfaExp3bH7bjCBmVXJupT9FAiBr0SmCtsuk
    miGgpajjf/gFigGM34F9021bCWs1MbL0SA==
    Árpád
